OK but the problem is that as it stands now the whole Bluez Binding is broken.
So what has happened is that a change has been made with no way to test the effects (no Bluetooth hardware available). So logically the way forward is to back out the change and re-test it when changes have been made to the calling code and hardware is available. I am happy to test for you.
Cant be reverted unfortunately, the change was part of the buildsystem migration. Someone with hardware must now need to test and fix the binding
David, is this the normal way that changes are managed in the OpenHab community? It seems a major and irreversible change has been introduced without any possibility of testing or rollback?
No that’s not normal. But a buildsystem change itself is not normal and usually only happens if inevitable. Please bear with the maintainers that not everything could be tested. The migration took already 2 month and the 2.5 release is still delayed.
Please help if you can.
I’ve had a look through the code, although it’s been a good few years since I’ve worked on Java. It seems to be a combination or poor error handling and the Native libraries, libtinyb.so and libjavatinyb.so, not installing. If you could tell me where the libraries are supposed to be, I’ll try manually putting them in place and re-testing.
Hm. As far as I know native libraries do not work yet with the new buildsystem, at least we have problems in Allplay and other bundles. @J-N-K, that’s still correct isn’t it?
Please.
Hi did you have a look at this
Natlive libraries are included but not properly referenced in the bundle manifest. Please open an issue for this. My plan is to get rid of all wrapped libraries in the first place and then remove all embedded libraries, this will also help with the native code.
No because I specially needed support for RuuviTags which has turned into a complete nightmare.
I assume this request (for a issue to be opened) was not directed at me but rather the guy that broke it all?
Who ever discovers a bug should enter an issue.
Bluetooth BlueZ Binding fails as Native Libraries not deployed #5680 submitted.
Hi the problem loading the Tinyb libraries has now been resolved and RuuviTag support is there now. However, of the three tags I have only one is being recognised as a RuuviTag, the other two are only showing as generic Bluetooth devices.
F7:9C:78:D0:51:61 not recognised
EA:2D:46:F5:83:8E not recognised
CD:21:B7:E1:6E:DF recognised
Hi @communig8, good testing there.
The devices are detected using using manufacturer ID as reported by the devices.
Let’s try to troubleshoot what is going on:
- please output
bundle:list -s |grep bluetooth
output from the karaf console, specify openHAB version - can you please enable verbose logging to whole
org.openhab.binding.bluetooth
? - check the properties of the thing, and share them here (we should see the manufacturer ID)
- see if the official python library is able to discover the devices properly,
python3 /usr/local/lib/python3.5/dist-packages/ruuvitag_sensor -f
(installation guide: https://github.com/ttu/ruuvitag-sensor) - use e.g. core beacons iOS app to find out Manufacturer ID of the devices (expecting 0x0499 (hex) or 1177 as decimal)
239 │ Active │ 80 │ 2.5.0.201906131930 │ org.openhab.binding.bluetooth
240 │ Active │ 80 │ 2.5.0.201906131930 │ org.openhab.binding.bluetooth.bluegiga
241 │ Active │ 80 │ 2.5.0.201906201458 │ org.openhab.binding.bluetooth.bluez
242 │ Active │ 80 │ 2.5.0.201906131930 │ org.openhab.binding.bluetooth.blukii
243 │ Active │ 80 │ 2.5.0.201906131930 │ org.openhab.binding.bluetooth.ruuvitag
244 │ Active │ 80 │ 1.3.3 │ org.sputnikdev.bluetooth-manager-tinyb
openHAB 2.5.0~S1611-1 (Build #1611)
Recognised Tag Things shows vendor Ruuvi Innovations Ltd (Oy)
Unrecognised Tags show no vendor information
pip install ruuvitag_sensor
worked ok but “/usr/local/lib/python3.5/dist-packages/ruuvitag_sensor” is a directory not an executable.
What logging level do you mean by “verbose”? (TRACE, DEBUG, INFO, WARN, ERROR)
All right, so everything is bleeding edge.
This is interesting indeed. Logs should tell something hopefully.
Do all the sensors have the same firmware version? or any other difference? Are they in “raw” mode?
Thanks, did you notice the python3
before the folder:
Let’s try with TRACE
to be sure we do not miss anything.
It had to be to get Bluetooth working with TinyB.
All 3 bought as a 3-pack so all the same Firmware and raw.
Obviously not
Finding RuuviTags. Stop with Ctrl+C.
Start receiving broadcasts (device hci0)
End Of File (EOF). Exception style platform.
Stop receiving broadcasts
I’ll do that and post the results
Just to make certain I get a clean start for the logging, I rebooted all three tags.
I’m now getting them recognised as RuuviTags.
