i use an intel NUC with an internal BLuetooth Adapter.
Openhab2 is the latest stable version.
I would like to create a Bluetooth Bridge. I have read the BLUEZ latest Version was not compatible with openhab2. So i installed the 5.43 Version.
On my UBUNTU 16.04 i can start bluetooth an it seems to work.
Now i create a BLUEZ Bridge in OH2. Add the MAC Address from the Adapter in the properties.
After that i receive the following error in the log:
10:27:17.636 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.eclipse.smarthome.binding.bluetooth.bluez.handler.BlueZBridgeHandler@1d731bac': BlueZ JNI connection cannot be established.java.lang.IllegalStateException: BlueZ JNI connection cannot be established.
at org.eclipse.smarthome.binding.bluetooth.bluez.handler.BlueZBridgeHandler.initialize(BlueZBridgeHandler.java:89) [230:org.eclipse.smarthome.binding.bluetooth.bluez:0.10.0.oh230]
at sun.reflect.GeneratedMethodAccessor32.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.oh230]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.oh230]
Caused by: java.lang.UnsatisfiedLinkError: tinyb.BluetoothManager.getNativeAPIVersion()Ljava/lang/String;
at tinyb.BluetoothManager.getNativeAPIVersion(Native Method) ~[?:?]
at tinyb.BluetoothManager.getBluetoothManager(BluetoothManager.java:304) ~[?:?]
at org.eclipse.smarthome.binding.bluetooth.bluez.handler.BlueZBridgeHandler.initialize(BlueZBridgeHandler.java:87) ~[?:?]
… 9 more
10:27:17.655 [ERROR] [home.core.thing.internal.ThingManager] - Exception occurred while initializing handler of thing ‘bluetooth:bluez:f1fbc682’: BlueZ JNI connection cannot be established.
… 9 more
The Bridge is not “online”.
Can anybody help?
Thanks.
Regards
Hermann
