I assume you’re using the official binding from OH3 release. Would be nice to know if somebody has the same problem too in order to check if BMW changed something on Authentication again.
In the meanwhile it’s worth to check if the update for soc_max value is working on your side: BMW ConnectedDrive Binding - #94 by weymann. THis one is currently running on my machine without problems so far.
I’ve been using the OH2 version this past week in preparation for a migration to OH03. It started to fail with authentication errors yesterday morning. So it would appear to be an issue with BMW as I can’t renew my ConnectedDrive subscription either. When I called them yesterday the person I spoke to seemed to be reading a scripted statement to tell me it’s being worked on and will be resolved with 24hours of my call. I called them around 9am yesterday, still not able to renew my subscription.
Same here (MY2021 i3). Also, when you try to retrieve your vehicle details or “car data” report on the myBMW website, you will run into a “400/bad request” situation (“Size of a request header field exceeds server limit.”) and they refer you to customer support. Seems to be a broader issue with their backend.
Isn’t it possible that BMW has stopped service of the connected app. I’m not able to connect to binding nor to the connected app (iphone version). But the iphone App “My BMW” works well.
…seems others have similar issues (e.g. home assistant). Here’s a link to some more infos and further links to what they changed to make the login successful again (at least for row): click
Came here for the obvious same problem. I have to note that on Friday morning, I had to re-authenticate to ConnectedDrive in my car and my “My BMW” Android app. And at that point the OpenHAB binding also broke - but I only noticed it just now.
I can also confirm replacing the binding with the one linked in the previous posts brings things back online!
I had the same Problem:
At 10.08.2021 I restartet my OpenHAB 3.1.0.M4. Since this moment the Connected Drive Binding had Communitications Errors (mostly: COMMUNICATION_ERROR Total timeout 10000 ms elapsed)
Solution:
Delete Connected Drive Things (Bridge and Vehicels)
Deinstall Connected Drive Binding wich comes with the 3.1.0.M4 Release
Create new Connected Drive Bridge and Vehicels Things (in Things configuration page in the UI simply click “+”. There you will see the manual added Binding)
BMW changed server access for authentication and all versions OH2.x and 3 are affected. I applied the changes also in the OH2 binding which accessible in the top post. Simply exchange the jar and it should work again.
Just put org.openhab.binding.bmwconnecteddrive-3.1.0-SNAPSHOT.jar into my addons folder.
Before removed old one, stop oh, cleared cache temp, start oh.
The binding does not show up. No log entry also.
I use docker.
Did open a shell in the container, there is a /addon folder and the .jar file is in the folder. File owner is openhab, changed rights to 777 still no luck.
I did get the addon via wget and the file size is smaller than the version downloaded on my windows machine. Copied it from the windows machine and the addon starts.
At least with an error
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.bmwconnecteddrive [278]
Unresolved requirement: Import-Package: javax.measure; version="[1.0.0,2.0.0)"
