README Link not working… and can’t find it.
Massimo is performing maintenance on his system, he is offline for a few days.
Sorry for the inconvenience
yes there are some changes in progress due to the new openHAB build system for the 2.5 release ( a big change going on) and at the moment the README files are offline
They should be back within a few days
massi
hi, i don’t understand where i can download the last version, and where i can find instruction forn install in my openhab device… can you give me link?
Hi Massimo!
Thanks for the great work and the continuous improvements.
One question. Is it possible to comand the F430 through a H4652 to switch it on and off? The actor isn’t connected to a LN4691.
I was trying with rules, but till now without success…
Thanks!
What do you want to do exactly?
Thanks for the quick answer!
There is an additional radiator in the bath room, not connected to the LN691 that I want to switch on occasionally with a H4652.
Directly with home suite I don’t think it’s working
Below the gateway bus modifies the discoverByActivation parameter by entering true
If you use the configuration via file you must use example:
Bridge openwebnet:bus_gateway:mybridge "MyHOMEServer1" [ host="192.168.1.35", passwd="abcde", discoverByActivation="true" ]
Press the button on the H4652 and see if it creates things whith discovery.
Publish the log, so we can better understand.
Remember to enable debug mode for the log
Grazie Michele!
I tried to configure it through MyHomeUp (I’m using a MyHomeServer1 gateway), but it’s not working as I don’t want to associate a LN4691.
Actually it’s not a problem related to the discovery of the H4652, but maybe of the F430.
Now I’ll try and let you know.
Unfortunately it’s not working…
Now it seems that I got the F430 configured.
things:
bus_thermostat RadiatoreBagnoPicc “Radiatore Bagno Piccolo” [ where=“12” ]
items:
Switch Radiatore_BagnoPicc “Riscaldamento” (Thermo) [ “homekit:heating” ] { channel=“openwebnet:bus_thermostat:mybridge:RadiatoreBagnoPicc” }
When I push the button on the F430 I see in the events it changes to ON, also when I push the H4652, the rule is working and it shows ON on the event, but it does not switch to the actor to on.
Rule:
rule “Radiatore Bagno Piccolo ON”
Item Radiatore_Bagno_Picc received command ON
sendCommand(Radiatore_BagnoPicc, ON)
Thread::sleep(1800000)
sendCommand(Radiatore_BagnoPicc, OFF)
…Maybe the only solution is to connect the radiator to a F411 and configure it as rullershutter… :-(
Thank you
Does it work if you turn it on or off using the button on the f430?
If yes, does it work using paper ui?
It works when i physically push the button on the actor!
Maybe you can’t send a write command to that item.
So connecting it to a F411 would be probably the only solution and actually I don’t see any point against it
You should also check if using paper ui if it turns on or off, if yes you have an issue with the rule
Publish the log to see which OWN code passes from the bus when you press the key.
The channel name is missing
I sent you a message in private
Hello All,
Hello everyone,
since the last firmware update 2.14.10 on MyhomeServer
the syntax error for automation is gone.
Regards,
Arnaud
Hi Massi,
Thanks a lot for all your work.
I am running Beta 9. I wanted to get latest beta to reinstall after a crash, but it looks like the github link is no more available. Could you help ?
Thank you very much.
Bflat
