Thank you !
I am still running open 2.4, it should be ok ?
my suggestion for everybody is:
- stay with openHAB 2.4 (OH 2.5.x is going under a big change in the build system)
- if you want to test OpenWebNet binding follow carefully the Installation instructions on the README here: https://github.com/mvalla/openhab2-addons/tree/openwebnet-old/addons/binding/org.openhab.binding.openwebnet#installation
- the latest suggested OpenWebNet binding version to use is 2.5.0.M2-1; the JAR can be found here: https://github.com/mvalla/openhab2-addons/releases.
2.5.0.M2-1 is compatible with OH 2.3 & 2.4
bye Massi
Thank you Massi for your clear explanations and all your great work.!
GitHub link is now back .
Hi Enrico,
This is the application that offered me a firmware update
My app version is 2.3.9 under android
Regards,
Arnaud
You can add [“Blinds”] tag for rollershutter control via Google assistant?
The Blinds tag is already present in the shutter channel
I am trying to figure out why CEN plus from phone (atMyHome app) doesn’t work.
This doesn’t work
String WestPIRLights4hrs_CENplus "CENplus West PIR 4hrs - phone" <light> {channel="openwebnet:bus_cenplus_scenario_control:Screen10:210:button_24" }
but if I change the address in the phone app then to point to another cenplus item then it works.
String NightLights_CENplus "CENplus Night light - switch" <light> {channel="openwebnet:bus_cenplus_scenario_control:Screen10:23:button_1" }
I used discovery by activation and checked the log to see what the response is to new cen plus addresses from my phone
Cenplus address 9.1
[INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'openwebnet:bus_cenplus_scenario_control:Screen10:29' to inbox.
As expected
Cenplus address 10.1 I get a different response
[WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key openwebnet:bus_cenplus_scenario_control:Screen10:210 in ManagedThingProvider, because it does not exists.
Checking double digit button number seems OK Cenplus address 4.30
[INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'openwebnet:bus_cenplus_scenario_control:Screen10:24' to inbox.
[home.event.InboxAddedEvent] - Discovery Result with UID 'openwebnet:bus_cenplus_scenario_control:Screen10:24' has been added.
It seems to be a bug with double digit cen plus addresses like 10 but not 11!
M
It seems to me that you use the WHERE in the channel, why?
I am not sure what you mean. Could you please highlight the bit that is an issue. Thanks.
I don’t understand 210, you can publish the configuration of your things
Thing bus_cenplus_scenario_control 23 "CENplus Night lights" @ "CEN" [ where ="23", buttons ="1" ]
Thing bus_cenplus_scenario_control 210 "CENplus West PIR 4hrs - phone" @ "CEN" [ where ="210", buttons ="24" ]
OK, you use the things name is a number
Tomorrow I run tests for your problem
Oh that bit… yeah I could use a name. Thanks. Probably will make it mre ‘readable’ when I get it working. I also tested address 11 and it gets discovered but 10 and any button number does not.
Are you using the latest version of the 2.5.0.M2-1 binding?
org.openhab.binding.openwebnet-2.5.0-M2
All the links in this thread to Github give 404 error… So, I haven’t checked if it was the latest.
Got it, Will install tomorrow.
Hi @massi,
could you add a new chapter to the first post with the link to download the latest version of the binding?
Maybe add a release date.
So we have a fixed post, much more practical
To correct the two links that do not work Installation
and README
let me know.
the 2.5.0.M2-1 has a correction for the touchscreen
