Installed 2.5.0.M2-1 but still have same issue with CENplus addresses with 10 + button_x. This time no response and nothing in the log. Tested 9,11,12 all seem OK and are discovered and work.
Clearing the cache didn’t help either
I do tests
Thing bus_cenplus_scenario_control Cenplus_test "Scenario Test 23" @ "Test" [ where="23", buttons="1,2" ]
Thing bus_cenplus_scenario_control Cenplus_test1 "Scenario+ Test 210" @ "Test" [ where="210", buttons="24,25" ]
String iLR_cen_test11 "CEN+ 23-1" <network> { channel="openwebnet:bus_cenplus_scenario_control:mybridge:Cenplus_test:button_1" }
String iLR_cen_test12 "CEN+ 210-24" <network> { channel="openwebnet:bus_cenplus_scenario_control:mybridge:Cenplus_test1:button_24"}
I ran tests with this configuration and it works correctly.
There is a problem with the cache of OH 2.4, it changes the names of the things and items and tries again
2019-05-01 09:37:23.107 [INFO ] [org.openwebnet.OpenGatewayBus$a ] - MON RECEIVED <<<<<<<<<<< *25*21#24*210##
2019-05-01 09:37:23.112 [DEBUG] [bnet.handler.OpenWebNetBridgeHandler] - ==OWN== ownId=25.210
2019-05-01 09:37:23.116 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== handleMessage() for thing: openwebnet:bus_cenplus_scenario_control:mybridge:Cenplus_test1
2019-05-01 09:37:23.119 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== updateButtonState() for thing: openwebnet:bus_cenplus_scenario_control:mybridge:Cenplus_test1
2019-05-01 09:37:23.230 [vent.ItemStateChangedEvent] - iLR_cen_test12 changed from RELEASED_EXT to PRESSED
2019-05-01 09:37:23.422 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== # 210 updating state to 'RELEASED'...
2019-05-01 09:37:23.485 [vent.ItemStateChangedEvent] - iLR_cen_test12 changed from PRESSED to RELEASED
2019-05-01 09:37:25.558 [INFO ] [org.openwebnet.OpenGatewayBus$a ] - MON RECEIVED <<<<<<<<<<< *25*21#1*23##
2019-05-01 09:37:25.563 [DEBUG] [bnet.handler.OpenWebNetBridgeHandler] - ==OWN== ownId=25.23
2019-05-01 09:37:25.567 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== handleMessage() for thing: openwebnet:bus_cenplus_scenario_control:mybridge:Cenplus_test
2019-05-01 09:37:25.570 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== updateButtonState() for thing: openwebnet:bus_cenplus_scenario_control:mybridge:Cenplus_test
2019-05-01 09:37:25.671 [vent.ItemStateChangedEvent] - iLR_cen_test11 changed from RELEASED_EXT to PRESSED
2019-05-01 09:37:25.873 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== # 23 updating state to 'RELEASED'...
2019-05-01 09:37:25.933 [vent.ItemStateChangedEvent] - iLR_cen_test11 changed from PRESSED to RELEASED
2019-05-01 09:37:30.585 [INFO ] [org.openwebnet.OpenGatewayBus$a ] - MON RECEIVED <<<<<<<<<<< *#13**22*09*37*30*000*03*01*05*2019##
2019-05-01 09:37:30.606 [DEBUG] [org.openwebnet.OpenGatewayBus ] - ##gw-openwebnet-BUS## handleManagementDimension not processed
2019-05-01 09:37:30.611 [DEBUG] [bnet.handler.OpenWebNetBridgeHandler] - ==OWN== GatewayManagement WHAT = null
Thanks Michele,
I cleared the cache , changed the the thing name to test and re-installed transport serial and UPNP
One of those did something
2019-05-01 09:50:24.300 [DEBUG] [bnet.handler.OpenWebNetBridgeHandler] - ==OWN== ownId=25.210
2019-05-01 09:50:24.308 [hingStatusInfoChangedEvent] - 'openwebnet:bus_cenplus_scenario_control:Screen10:test' changed from UNKNOWN: waiting state update... to ONLINE
2019-05-01 09:50:24.309 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== handleMessage() for thing: openwebnet:bus_cenplus_scenario_control:Screen10:test
2019-05-01 09:50:24.311 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== updateButtonState() for thing: openwebnet:bus_cenplus_scenario_control:Screen10:test
2019-05-01 09:50:24.330 [vent.ItemStateChangedEvent] - WestPIRLights4hrs_CENplus changed from NULL to PRESSED
2019-05-01 09:50:24.624 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== # 210 updating state to 'RELEASED'...
2019-05-01 09:50:24.633 [vent.ItemStateChangedEvent] - WestPIRLights4hrs_CENplus changed from PRESSED to RELEASED
Great
I think it’s the name
I changed the name back to 210… it still works
2019-05-01 10:01:05.947 [INFO ] [org.openwebnet.OpenGatewayBus$a ] - MON RECEIVED <<<<<<<<<<< *25*21#24*210##
2019-05-01 10:01:05.951 [DEBUG] [bnet.handler.OpenWebNetBridgeHandler] - ==OWN== ownId=25.210
2019-05-01 10:01:05.956 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== handleMessage() for thing: openwebnet:bus_cenplus_scenario_control:Screen10:210
2019-05-01 10:01:05.958 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== updateButtonState() for thing: openwebnet:bus_cenplus_scenario_control:Screen10:210
2019-05-01 10:01:05.958 [hingStatusInfoChangedEvent] - 'openwebnet:bus_cenplus_scenario_control:Screen10:210' changed from UNKNOWN: waiting state update... to ONLINE
2019-05-01 10:01:05.968 [vent.ItemStateChangedEvent] - WestPIRLights4hrs_CENplus changed from RELEASED to PRESSED
2019-05-01 10:01:06.260 [DEBUG] [et.handler.OpenWebNetScenarioHandler] - ==OWN:ScenarioHandler== # 210 updating state to 'RELEASED'...
2019-05-01 10:01:06.275 [vent.ItemStateChangedEvent] - WestPIRLights4hrs_CENplus changed from PRESSED to RELEASED
The problem is not the numeric name, but when you keep changing the parameters of the same things and / or items, something gets stuck in the cache
There is a OH Comunity Survery going on that will help maintainers understand priorities about the future and evolution of OH.
I suggest to participate in the Survery!
Massi
Hi Michele, could you give me some indication on how to configure the scenario control unit. I can’t figure out how to use OH with F420.
Thank you
what would you like to manage?
Currently the binding does not support any type of scenario management.
Eventually open a new topic and explain better what you would like to do, we can evaluate and give you support
Hi @massi,
have you seen that a patch for rollershutter management through Google Assistant has been published?
How this affects the binding behaviour?
Yes, it has ben (finally) added to the Google Assistant adaptor.
However there is bug at the moment: open/close commands from Google are not correctly mapped to OH UP/DOWN commands.
Regarding the openwebnet binding: it’s already compatible since items created automatically with PaperUI (Simple Mode item linking: Configuration > System > Item Linking > Simple mode > SAVE ) will get automatically the correct tag from the binding: in particular items associated with shutter
channels will have the Blinds
tag.
If you configured items with text file (.item) you can add the tag following the example in the README.
After the Blinds
tag is set, just say “Sync my devices” and Google Assistant will find the Rollershuter.
Thank you massi,
I have done some tests after implementing the new tag:
I also noticed this.
Maybe you can explain the problem in the main Google assistant thread to see feedback from others.
It has been experienced also by other users in that thread, I added my own to understand if it is like that for everyone.
Is there a way to send command to the groups created in the bticino gateway? (e.g. turning off all the lights)
Is there a way to use a bticino button (not actuator) to do something in Openhab? (e.g. sending an email)
This has been discussed in the past but maybe in the last version of the binding it became possible
currently not possible.
We are evaluating a new bus called bus_command, but I don’t know the timing, we are stuck with implementations for changes to the new build system.
Momentarily, if you have a scenario module type MH202, you can create a rules in the MH and start it using the CEN or CEN + command and configure the CEN or CEN + command in OH
If you configure it as CEN or CEN + you can use a rules to send notifications or emails
Interesting thank you!
I will give it a try, just for fun because I have an unused button
I noticed that in my inbox is appearing a new discovered device (switch) with where 51:
the odd thing is that I already have that thing/item configured:
any idea why?
