oops… I forgot that. Works now.
ps maybe I should read the readme once more
Hi Massi, I’ve been using your openwebnet binding already a couple of years now without any big issues up till now. So i’m a big fan! Keep up the good work!
Although now, I just did my 6 monthly maintenance of my openhab installation, and after using the tool to upgrade openhab (to the last stable version) it doesn’t work anymore and my logs say:
2020-09-21 14:25:32.483 [hingStatusInfoChangedEvent] - ‘openwebnet:bus_gateway:mybridge’ changed from OFFLINE (COMMUNICATION_ERROR) to UNKNOWN
2020-09-21 14:25:32.484 [ERROR] [org.openwebnet.AbstractOpenGateway ] - ERROR IN Java $MODULE$: connection cannot be established
2020-09-21 14:25:32.489 [me.event.ThingUpdatedEvent] - Thing ‘openwebnet:bus_gateway:mybridge’ has been updated.
2020-09-21 14:25:52.490 [hingStatusInfoChangedEvent] - ‘openwebnet:bus_gateway:mybridge’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR)
any idea what could be the problem? Google and hours of reading didn’t solve it yet
What jar file version do you use? Version 2.5.0.M4 was expired.
I put the latest one indeed, the M4 is what i found?
Hi Peter,
after every system upgrade I need to resolve missing dependencies.
On karaf console enable the dependencies with this command:
feature:install openhab-transport-serial
feature:install openhab-core-io-transport-upnp
This will solve your issue.
By Giovanni
It happened again… PM sent
New release of the “unofficial” binding:
openwebnet
binding Version 2.5.0 (unofficial)
NOTE
This is the last release for the “unofficial” (beta/testing) version of the openwebnet binding.
Main development, new features and issues/bugs fixing will continue on the official OH version of the binding.
This binding version is compatible with openHAB 2.5.x.
To install/upgrade to the new version of the binding, CAREFULLY follow the instructions in the README.
thx! was one of the issue but also the expiry was an issue. I just found out there is an official binding in the meanwhile
Installed that one and works perfectly!
Since sunday there is also a new release of the official binding:
openwebnet
binding Version 2.5.9 (official version)
See: https://www.openhab.org/addons/bindings/openwebnet/
If you install this version, dependencies are automatically handled.
Do not install both testing and official version of the binding on the same OH installation or it will be a mess!
It’s possibile however to have two OH installations, one using binding v2.5.0 and one with v.2.5.9.
@massi: Should I open an issue for the “disconnect problem”? According to your post you wrote that you will open it yourself. I just searched for it, can’t find it.
Where did you search?
New issues should be added to the e main addons OH repo, like this:
oh sorry, I searched here:
https://github.com/mvalla/openhab-addons/issues…
thx again for your work!
this is the place for issues for the v2.5.0 (testing) binding. However since development is now only on the new official binding, I will see how to move some of these issues to the official OH repo.
Updated to 2.5.9 binding. New Automation Things found. Test blind functions. Auto cal seemed to work but was a bit off and so I entered my own value
One thing I noticed my test dimmer was found again but this time as a switch even though its been already set up in openHAB. So, I guess to prevent that all dimmers, even set up ones, must be On before running the discovery. Thats a bit of a pain. Could the discovery exclude devices with the same BUS address?
good point! feel free to open an issue in the official OH repo
@massi
just a report as information (i use a separate raspberry, with no other openwebnet-binding installed):
please let me know if i can do further tests
Just in case someone wants to know how I upgraded the official openwebnet binding from openhabian…
From console:
>sudo openhabian-config
Select option 2 Upgrade system
That’s it. PaperUI addons should now show the latest binding version as installed
This also deletes the cache and tmp files as part of process.
Hi @massi
I configed new official OWN binding from UI with USB stick.
zb_on_off_switch - was where=“7705110”. New right value - “770511000#9”.
zb_on_off_switch2u - was where=“7696059”. New right value - “769605900#9”.
zb_automation - was where=“7706771”. New right value - “770677100#9”. But it have the previous problem - does not read position from Zigbee protocol after stop(I mate the issue for previous binding).
One problem remained. after changing the device, its value changes to null. But the light turns on.
2020-09-22 23:03:12.535 [ome.event.ItemCommandEvent] - Item 'Switch_zal_center' received command ON
2020-09-22 23:03:12.556 [nt.ItemStatePredictedEvent] - Switch_zal_center predicted to become NULL
Thanks for continuing the development. So I updated from 2.5.0.M4 to Openhab 2.5.9 and used that opportunity to test your latest 2.5.9 binding. Unfortunately it does not connect at all for me to MH202, all items were Offline due to “Bridge offline” and logs did not show anything helpful, it just was not able to communicate.
Then I read that the new binding supports only WHO=1 and so I did not even try to fix it. I spent like 3 weeks tweeking automation of temperature control, where I use your binding and rules to read temperature and decide whether to perform cooling or not. I then use another Broadlink IR remote binding to send commands to AC in my room to turn ON/OFF when necessary thus having both AC and heating control through my Bticino (without your binding only heating would work as there is no way to connect any AC to Bticino in my country)
I also use lot of rules with scenario virtual buttons which. When I press a button on my 10screen, it calls a “scenario X” which does nothing. But I have a listener set up in rules thanks to your binding and this calls a custom script. This enabled me to open gates and garage doors straight from my tablet.
– TL;DR @massi
My point being: Since the 2.5.0 works PERFECTLY for my case and it has tons of features which are not supported by the official new reworked version, would you please show us pity and not make that terrible deadline after which the binding expires? Light and automation control are really like 20% of the stuff I use your binding for. I spent days and hours making a working temperature control and extended tablet control which is not possible with the new one so far. Please consider users like me I will not ask for support with old version. I will not bug you that something does not work. I just want to be able to use the binding and openhab AS IS after Jan 2021. I really dont need the latest features. I need something that works.
