What is the best feature of this thermostat? Can anyone guide me in buying thermostats?
Work in progress to implement Smarther in Sdomotica
Hello!
I am new about this world, so I got 3 smarter thermostat x8000.
Iâd like to create something (maybe by browser) that can (for example) connect every minute to my thermostat and record temperature and state of that and report it to a graph?
Or, how can I know how many times my home temperature drop down during last day?
thanks a lot
Marco
Hi @Mr_Ronfo,
Iâm trying to integrate the Smarther in OpenHab2.
Following your instructions on GitHub I had to change the url used, inserting it without the webserver port, as I had installed already a webserver and got a error message with the port.
Now everything ok till point 3.3 - 5, where in executing smarther-api.sh
script with get_status
I have the following error message:
./smarther-api.sh: line 117:jq: command not found {ârsptypeâ:ââ,ârspcodeâ": 500,âerrormsgâ:"OAuth2 code is missing or invalid. To restore the authentication flow call the following Url from a browser:http://âŚ
Could you please help?
Thanks!
Hi @Tommyshome, just saw your comment, hope youâve made some progress since then
From the posted error msg, it seems that your Linux distribution has no bash jq
command installed.
On Raspbian/Debian distros you can install it via sudo apt install jq
If you need more help, you can also drop me an issue on GitHub and Iâll be happy to assist.
Cheers
@Mr_Ronfo I know itâs not the right place and I apologize but I donât know how to contact her.
Can you bring this integration to Home Assistant please?
Thank you!
Hi @Mr_Ronfo!
Thanks for the answer! Meanwhile I have resetted the webserver and now I have everything on OpenHab!
I still used the url without the webserver port, but itâs not updating the infos from the Smarther except the first time and when I send a command.
You are asking for someone who uses openHAB and developed a solution using openHAB on an openHAB forum to build something for Home Assistant?
Yes, and first of all I apologized.
Feel free to delete the message if you want, I donât want to create controversy.
Sorry.
There is nothing wrong with the post and itâs not controversial. But I donât know what you expect to come of it. Any home automation is a challenge to learn to use let alone code for and openHAB and HA are so different in that regard that itâs a really big ask.
Hi Fabio,
Thank you so much for the wonderful work.
I would be more than happy if you could help me with the following issue. Iâve completed the setup up to the point where i dowwload the authendication.json file and the script has generated the refresh.json file.
The error i am getting from the get_staus script option is the following:
{âstatusCodeâ:401, âmessageâ:âUnauthorized. Supplied access token is invalid or doesnât include required scope(s).â}
Any idea?
Thanks you,
Makis
Welcome Makis!
Looks like the application youâve created on Legrand dev portal has no comfort.read and comfort.write scopes selected. Could you please double check that?
Cheers,
Hi Fabio,
Yes that was the issue. I have edited my application now in legrandâs portal and waiting for approval/update.
Thanks a lot
Ciao Fabio,
Thanks again for your great work!
As I wrote you some time ago, I don´t get automatic updates.
When I run
./smarther-api.sh set_subscription
I got that error:
{ârsptypeâ:âset_subscriptionâ,ârspcodeâ:409,âerrormsgâ:â(set_subscription) Conflictâ}
What could be wrong?
Hi @Tommyshome, the error 409 in set_subscription usually means you already have a subscription already set for your plantId.
Unfortunately you cannot just âchange itâ or set it twice, so you have to delete the current one first, then you can set a new one:
List the existing subscriptions, to get the value of
subscriptionId
attribute associated to yourplantId
, calling:./smarther-api.sh get_subscriptions
Delete the current subscription, calling:
./smarther-api.sh delete_subscription <subscriptionId>
Now you should be able to set a new subscription for the same
plantId
, via:./smarther-api.sh set_subscription
Cheers,
Thanks @Mr_Ronfo!
Unfortunately the delete subscription is not workingâŚ
{ârsptypeâ:âdelete_subscriptionâ,ârspcodeâ:500,âerrormsgâ:"(delete_subscription) "}
Hi @Tommyshome, sounds a bit strange to me. Would you mind posting what is:
- the full result of your call to get_subscriptions, and
- the full command youâve executed to delete the subscription ?
Use generic labels instead of the actual values of your plantId and subscriptionId if you prefer, as long as you replace same value with the same label
Cheers,
Hi @Mr_Ronfo,
The result is:
{ârsptypeâ:âget_subscriptionsâ,ârspcodeâ:200,âsubscriptionsâ:[{âplantIdâ:âXXXXX-YYYYY-XXX-XXX-YYYYYYYYYYYâ,âsubscriptionIdâ:âyxyxyx-yxyx-yxxy-yxyx-yxyxyxyxâ,âEndPointUrlâ:âhttps://192.168.1.11/smarther/smarther-c2c.phpâ}]}
./smarther-api.sh delete_subscription yxyxyx-yxyx-yxxy-yxyx-yxyxyxyx
Hi @Tommyshome,
Iâve tried myself the same Delete command for my plant, even on API testbed on Legrand portal, and it seems theyâre experimenting a server side issue.
Iâve posted a support request on Legrand Dev forum, will update here when they reply.
Cheers,
Grazie mille!
