First of all, it looks like the “Repeat” option must be set to 1 or greater. Otherwise, I can not see any output at all when I send to a group of 433Mhz devices via RFLink Gateway.
When sending to a group of 7 units, I only get 3 OK from RFLink Gateway. I think the binding must wait for an answer or at least slow down.
This is notices when using this binding in openHAB 3.1.0 (Docker container)
Installed binding is: https://github.com/Pshatsillo/org.openhab.binding.rflink/releases/tag/3.0.1
So what could be best workaround for this issue or can someone fix the bug?
It do work if I control a item manually so maybe a script that send the command to all devices in a group one by one with a small break between could be a fix? Any suggestions?
