Hi there! My first post here. Newly migrated to openhab from Pimatic. Spent lots of time setting up my system and loving openhab.
I use the rflink binding to control various switches and sockets and it works very nicely. The issue I am having is when sending commands to multiple devices it doesnt activate all the switches / sockets. Checking the logs reveals nothing as the commands seem to send properly.
I have added the “repeats=x” variable to the binding config for each thing and tested higher values but it seems to make no difference.
I have a feeling it is to do with the interval between commands. I think they are processed too quickly to be sent correctly. But as i said, the logs reveal nothing to me.
Can anyone help? Below is my setup
Things:
Bridge rflink:bridge:usb0 "RFLink Bridge" [ serialPort="/dev/ttyACM0", baudRate=57600, disableDiscovery=false ] {
switch ChristmasLight1 "Christmas Light 1" [deviceId="Unitec-9159-01", repeats=15]
switch ChristmasLight2 "Christmas Light 2" [deviceId="Unitec-9159-02", repeats=15]
switch ChristmasLight3 "Christmas Light 3" [deviceId="Unitec-9159-03", repeats=15]
switch ChristmasLight4 "Christmas Light 4" [deviceId="Unitec-9159-04", repeats=15]
switch ChristmasLightALL "Christmas Lights ALL" [deviceId="Unitec-9159-00", repeats=15]
switch LoungeLight1 "Lounge Light 1" [deviceId="TriState-8a22a1-10", repeats=15]
switch LoungeLight2 "Lounge Light 2" [deviceId="TriState-8a22a4-10", repeats=15]
switch LoungeLight3 "Lounge Light 3" [deviceId="TriState-8a2290-10", repeats=15]
switch PIR1 "Downstairs PIR" [deviceId="NewKaku-0000007b-3"]
switch PIR2 "Upstairs PIR" [deviceId="NewKaku-0000007b-2"]
temperature TempSensor1 "Temp Sensor 1" [deviceId="AlectoV4-5018"]
temperature TempSensor2 "Temp Sensor 2" [deviceId="AlectoV4-5028"]
humidity Humidity1 "Humidity Sensor 1" [deviceId="AlectoV4-5018"]
humidity Humidity2 "Humidity Sensor 2" [deviceId="AlectoV4-5028"]
switch BedroomLight "Bedroom Light" [deviceId="Conrad-5a10ef-06", repeats=15]
Items:
Switch AllLights "All Lights" ["Lighting"]
Dimmer 3KitchenLights_Level "3 Kitchen Lights Level"
Color 3KitchenLights_Hue "3 Kitchen Lights Hue" ["Lighting"]
Switch ChristmasLight1 "Christmas Light 1" ["Lighting"] {channel="rflink:switch:usb0:ChristmasLight1:command"}
Switch ChristmasLight2 "Christmas Light 2" ["Lighting"] {channel="rflink:switch:usb0:ChristmasLight2:command"}
Switch ChristmasLight3 "Christmas Light 3" ["Lighting"] {channel="rflink:switch:usb0:ChristmasLight3:command"}
Switch ChristmasLight4 "Christmas Light 4" ["Lighting"] {channel="rflink:switch:usb0:ChristmasLight4:command"}
Switch ChristmasLightALL "Christmas Light ALL" ["Lighting"] {channel="rflink:switch:usb0:ChristmasLightALL:command"}
Contact ChristmasLight1_Contact "Christmas Light 1 Contact" {channel="rflink:switch:usb0:ChristmasLight1:contact"}
Contact ChristmasLight2_Contact "Christmas Light 2 Contact" {channel="rflink:switch:usb0:ChristmasLight2:contact"}
Contact ChristmasLight3_Contact "Christmas Light 3 Contact" {channel="rflink:switch:usb0:ChristmasLight3:contact"}
Contact ChristmasLight4_Contact "Christmas Light 4 Contact" {channel="rflink:switch:usb0:ChristmasLight4:contact"}
Contact ChristmasLightALL_Contact "Christmas Light ALL Contact" {channel="rflink:switch:usb0:ChristmasLightALL:contact"}
Switch LoungeLight1 "Lounge Light 1" ["Lighting"] {channel="rflink:switch:usb0:LoungeLight1:command"}
Switch LoungeLight2 "Lounge Light 2" ["Lighting"] {channel="rflink:switch:usb0:LoungeLight2:command"}
Switch LoungeLight3 "Lounge Light 3" ["Lighting"] {channel="rflink:switch:usb0:LoungeLight3:command"}
Contact LoungeLight1_Contact "Lounge Light 1 Contact" {channel="rflink:switch:usb0:LoungeLight1:contact"}
Contact LoungeLight2_Contact "Lounge Light 2 Contact" {channel="rflink:switch:usb0:LoungeLight2:contact"}
Contact LoungeLight3_Contact "Lounge Light 3 Contact" {channel="rflink:switch:usb0:LoungeLight3:contact"}
Switch BedroomLight "Bedroom Light" ["Lighting"] {channel="rflink:switch:usb0:BedroomLight:command"}
Contact BedroomLight_Contact "Bedroom Light Contact" {channel="rflink:switch:usb0:BedroomLight:contact"}
Switch PIR1 "Downstairs PIR" {channel="rflink:switch:usb0:PIR1:command"}
Switch PIR2 "Upstairs PIR" {channel="rflink:switch:usb0:PIR2:command"}
Number TempSensor1 "Temp Sensor 1" {channel="rflink:temperature:usb0:TempSensor1:temperature"}
Number TempSensor2 "Temp Sensor 2" {channel="rflink:temperature:usb0:TempSensor2:temperature"}
Number Humidiy1 "Humidity Sensor 1" {channel="rflink:humidity:usb0:Humidity1:humidity"}
Number Humidiy2 "Humidity Sensor 2" {channel="rflink:humidity:usb0:Humidity2:humidity"}
Thanks in advance!
