@RGroll Thanks, this is close to what I thought about. But for thermostat control, I would be very happy to
see and change the desired temperature
see vaule and trend of the current temperature.
If I get it right, I can only adress one value in the widget for control and trend, right? Can this be split in the widget without causing too much work for you?
Sorry for putting so much work for you, but up to now, these proof-of-concepts are all that beginners like me have. A library (for dimmer, for thermostat) would be of really great help.
I’ve been trying to work through you version of the Chromecast widget and make sure I totally understand what you’ve done and why. I think it makes sense so far. But I’m running into a problem.
I the 3rd row you defined a Label. But as far as I can tell, that doesn’t work with an Item. In this case, the app is a String held in a String Item. So I looked around and there is no oh-label. And when I tried to use =props.prefix+"_App" for the text in the Label nothing shows up. I also tried an oh-label-card (out of desperation) but it doesn’t show anything either (because it’s a card?).
I appreciate any pointers. Everything else about the widget makes sense to me so far. I’m not sure how I would have figured out to do it that way on my own but at least now I’m starting to get it and may be able to start getting that part of the tutorial filled out more.
The Label component is nothing documented I think (or at least I don’t know where) - I saw it in one of the Yannick’s widgets some time ago I think, so I just began to use it. It doesn’t have the oh- prefix.
This should also work.
I tried your code and didn’t found the error at first until I see the very small (but decisive) faux-pas - the slots: is not aligned with the config: of the f7-row component - the YAML structure is kinda evil.
Yep, I just discovered that right before your reply. Now I’m just struggling with how to center justify the column. You showed how to do the row but that doesn’t appear to flow on down into the f7-cols. And justify-content-center doesn’t seem to do anything as a class under the config for the f7-col. But that’s more for my own knowledge and not something I’m trying to actively do.
are there any news on that? Just asking, to be sure that I don’t miss anything while creating a widget where this feature would be usefull.
And one more questions on the same topic - you’ve introduced a feature some time ago, to set parameters for a selected widget within the action configuration.
Is there a way to use that function in custom widgets?
Yes you define a parameterGroup with a context: action in your props (this will replace the group props with the standard dynamic action form), and then instead of the action* propertes in widgets, you specify actionPropsParameterGroup instead and it will normally take all the action parameters from that group.
Thanks for your quick answer - this is exactly what I’m looking for! Awesome, will start right away to implement this.
To be honest, I haven’t thought about, that this context:action could already include the external component configuration (which makes sense) and thought every action configuration setting has its own context parameter. The soloution like this is even better (and much easier to implement)
After searching a number of posts, I am still unable to determine if it is possible to change the default grid spacing and element size in the overview page, or any other pages such as location and equipment. For example if I want the standard element size to be only half as tall as the default, is this possible to do on a global or eleven element by element basis. Any help here is appreciated.
Can I access the groupParameter like a normal parameter to hide the link-component if nothing is specified as action? (you seems to do that in all the standard widgets)
For the Overview page, it’s a layout so you can do a lot with CSS variables. For the other pages, you can only customize the order, grouping, header, but not the layout.
They are regular props with a little bit of logic to deal with prefixes etc. It’s a little complex to explain accurately.
Use something like this temporarily to inspect the props object:
This is enough explanation for now - got it working! TY
Maybe we both misunderstood something here - I can set the ‘actionModal’ parameters on the widget YAML manually, to open the widget with them, yes.
My naive expectation was, that the available parameters of the widget to open, would be loaded automatically after setting the widget/page - but it looks like this on my side…
