Your problem is that you are logging in with a usename unknown to the SysAp / username without installer rights (as set within the SysAp interface).
Some more log details would be required to identify your issue.
I had the same problem with my busch jƤger sysapā¦
I have to restart the bundle manually after the openhab container was booted from my Synology NASā¦
bundle:restart org.openhab.binding.freeathome in the console, otherwise the bridge would not go online.
My bridge is created via .thing file
Bridge freeathome:bridge:sysap "SysAP_Bridge" @ "Room" [ host="yx", ipAddress="xy", port="5280", login="<username_withInstallerRights>", password="<pw>", log_dir="/tmp/", log_enabled=false, dummy_things_enabled=true ] {
//PC
Thing raffstore Raff_PC_Doppel "Raff_PC_Doppel" @ "PC" [ DeviceId="<..>", ChannelId="ch0003", InputIdComplete="idp0000", InputIdPercentage="idp0002", InputIdStepwise="idp0001", OutputIdPercentage="odp0001" ]
Thing raffstore Raff_PC_Klein "Raff_PC_Klein" @ "PC" [ DeviceId="<..>", ChannelId="ch0003", InputIdComplete="idp0000", InputIdPercentage="idp0002", InputIdStepwise="idp0001", OutputIdPercentage="odp0001" ]
Hello all,
I have installed OpenHAB 3.3.0 on Ubuntu and downloaded freeathome binding from GitHub - andrasU/openhab-free-home-binding: OpenHAB free@home binding.
My SysAP is version 3.1.0 and Freeathome bridge in OH is online.
Unfortunately when I try to add thing - scan doesnt find any item. I dont see any messages in /var/log/openhab/openhab.log or event.log.
Any idea where problem could be? Or how to enable debub logging?
at frist you have to setup the bridge manually.
Afterwards the scan will work.
I just updated my SysAP to the new Version 3.1.0 Revision 9754, and the binding still works fine.
thanks for quick response.
I have Free@Home Bridge already configured. Please see screenshot:
Bridge is online but scan cannot find any device. Is there any way how to track down communication with SysAP?
I am new in this area so I hope I installed freeathome binding properly (just downloaded to specific folder in linux). I will try to investigate if did something wrong during installation.
I see you are using the swagger version of the binding created by @UhA, so then I am uncertain what is the problem.
The other version of the binding could be downloaded:
https://community.openhab.org/t/busch-jaeger-free-home/31043/599?u=kjoglums
Thanks a lot. I installed version you shared and now it works very well.
Have a nice day
Is it possible to get/see the source code of that binding? I want to learn, how to create a binding.
PS: My special issue is, that Iām at 3.1.0 of my SysAP2 and get an connection error. I believe the XMPP protocol changed in some way, that the addon canāt used.
I wanted to upload the openapi.json, but as new user I was not allowed to do that. Because of that, I posted the YAML file inline.
openapi: 3.0.1
info:
title: free@home API
description: free@home is the leading Smart Home System from ABB.
version: v1
servers:
- url: https://{hostname}/fhapi/v1
variables:
hostname:
default: 192.168.2.1
description: Hostname of the System Access Point or IP Address
paths:
/api/rest/configuration:
get:
tags:
- api
summary: Get configuration
description:
"Get configuration for all user registered System Access Points, this
includes the schema for all devices, channels and data points, the floorplan and
current user information.
\n\n
The response body is a JSON object that uses the SysAP UUID of each SysAP of the
requesting user account as key. The configuration of that SysAP is the corresponding
value and is again a JSON object.
\n\n
You can find further description and an example of the returned data model in the
[documentation](https://developer.eu.mybuildings.abb.com/fah_cloud/concepts/#data-model)
and an example of this request in the
[samples](https://developer.eu.mybuildings.abb.com/fah_cloud/samples/#query-the-configuration)."
operationId: getconfiguration
responses:
"200":
description: Configuration
content:
application/json:
schema:
$ref: "#/components/schemas/Configuration"
"502":
description: free@home error
content:
text/plain:
schema:
$ref: "#/components/schemas/ApiRestConfigurationGet502TextPlainResponse"
"401":
$ref: "#/components/responses/UnauthorizedError"
/api/rest/devicelist:
get:
tags:
- api
summary: Get devicelist
description: "Get list of devices for all System Access Points.
\n\n
This endpoint is similar to the /api/rest/configuration endpoint,
but only provides access to the list of Device IDs that are known
by each SysAP, not their corresponding configuration."
operationId: getdevicelist
responses:
"200":
description: Devicelist
content:
application/json:
schema:
$ref: "#/components/schemas/Devicelist"
"502":
content:
text/plain:
schema:
$ref: "#/components/schemas/ApiRestDevicelistGet502TextPlainResponse"
"401":
"/api/rest/device/{sysap}/{device}":
get:
tags:
- api
summary: Get device
description: "Get configuration information for given device.
\n\n
but except for returning the full configuration of all SysAPs,
it returns the configuration of a single device in a single SysAP
only and therefore is much faster and requires less bandwidth.
\n\n
The response body is a JSON object that maps the (single) SysAP
UUID to an object that contains \"devices\" object (only) which
in turn holds the specified device object (only).
\n\n
See also the [documentation](https://developer.eu.mybuildings.abb.com/fah_cloud/concepts/#data-model)
for the meaning of the contents of the device object."
parameters:
- name: sysap
in: path
description: SysAP UUID
required: true
schema:
$ref: "#/components/schemas/SysapUuid"
example: "00000000-0000-0000-0000-000000000000"
- name: device
in: path
description: Device Serial
required: true
schema:
$ref: "#/components/schemas/DeviceSerial"
example: "6000D2CB27B2"
responses:
"200":
description: Success
content:
application/json:
schema:
$ref: "#/components/schemas/ApiRestDevice_sysap__device_Get200ApplicationJsonResponse"
"502":
content:
text/plain:
schema:
$ref: "#/components/schemas/ApiRestDevice_sysap__device_Get502TextPlainResponse"
"401":
"/api/rest/datapoint/{sysap}/{device}.{channel}.{datapoint}":
get:
tags:
- api
summary: Get datapoint value
description: "Get the current value of a given datapoint.
See the
[documentation on datapoints](https://developer.eu.mybuildings.abb.com/fah_cloud/concepts/#input-and-output-datapoints)
for further information and the
[samples](https://developer.eu.mybuildings.abb.com/fah_cloud/samples/#query-a-datapoint)
for an example."
operationId: getdatapoint
parameters:
- name: sysap
in: path
required: true
schema:
- name: device
in: path
description: "Datapoint Serial.
as obtained from e.g. a
/api/rest/configuration call."
required: true
schema:
- name: channel
in: path
description: "Channel of a device.
Selects a channel in a device, as obtained from e.g. a
required: true
schema:
$ref: "#/components/schemas/ChannelSerial"
example: "ch0000"
- name: datapoint
in: path
Selects a datapoint in a channel of a device."
required: true
schema:
$ref: "#/components/schemas/DatapointSerial"
example: "odp0000"
responses:
"200":
content:
application/json:
schema:
$ref: "#/components/schemas/ApiRestDatapoint_sysap__serial_Get200ApplicationJsonResponse"
"401":
put:
tags:
- api
summary: Set datapoint value
description: "Set a new value for a given datapoint.
See the
[samples](https://developer.eu.mybuildings.abb.com/fah_cloud/samples/#set-a-datapoint)
for an example."
operationId: putdatapoint
parameters:
- name: sysap
in: path
required: true
schema:
- name: device
in: path
required: true
schema:
- name: channel
in: path
required: true
schema:
example: "ch0000"
- name: datapoint
in: path
required: true
schema:
example: "odp0000"
requestBody:
description: New value
content:
text/plain:
schema:
$ref: "#/components/schemas/ApiRestDatapoint_sysap__serial_PutRequest"
responses:
"200":
content:
application/json:
schema:
$ref: "#/components/schemas/ApiRestDatapoint_sysap__serial_Put200TextPlainResponse"
"502":
content:
text/plain:
schema:
$ref: "#/components/schemas/ApiRestDatapoint_sysap__serial_Put502TextPlainResponse"
"401":
/api/ws:
get:
summary: Websocket connection
description: "This endpoint is used to open a websocket connection.
In order to use this endpoint, you must use a websocket implementation and use the \"wss://\"
protocol schema instead of \"https\",a normal http request on this URL will fail.
\n\n
When the websocket has been opened successfully, the client will receive events from the
free@home cloud for all registered SysAPs in the account of the requester.
\n\n
Also note that this call can NOT be tested by using the swagger ui frontend (the \"Try it\" button).
You must use a websocket implementation for this request, the portal does not support this.
See the [websocket section](https://developer.eu.mybuildings.abb.com/fah_cloud/concepts/#websocket) in the documentation for an example."
operationId: ws
responses:
"101":
description: "Switching protocols (websocket success).
This response code is sent to indicate that the connection is upgraded from an HTTP to a websocket connection.
You should normally not see this response code, the library/code that implements the websocket should have handled this."
"418":
description: "This code will never replied from the server.
This response code only exists to document the schema of messages that are send by the server on the websocket."
content:
application/json:
schema:
$ref: "#/components/schemas/WebsocketMessage"
"401":
"/api/rest/virtualdevice/{sysap}/{serial}":
put:
tags:
- api
summary: Create virtual device
description: "Create a virtual device inside free@home.
You can choose a serialnumber freely.
The following devices can be created:
<ul>
<li>BinarySensor</li>
<li>SwitchingActuator </li>
<li>CeilingFanActuator </li>
<li>RTC </li>
<li>DimActuator </li>
<li>WindowSensor </li>
<li>ShutterActuator </li>
<li>WeatherStation </li>
<li>Weather-TemperatureSensor </li>
<li>Weather-WindSensor </li>
<li>Weather-BrightnessSensor </li>
<li>Weather-RainSensor </li>
<li>CODetector </li>
<li>FireDetector</li>
<li>KNX-SwitchSensor</li>
<li>MediaPlayer</li>
<li>EnergyBattery</li>
<li>EnergyInverter</li>
<li>EnergyMeter</li>
<li>EnergyInverterBattery</li>
<li>EnergyInverterMeter</li>
<li>EnergyInverterMeterBattery</li>
<li>EnergyMeterBattery</li>
<li>AirQualityCO2</li>
<li>AirQualityCO</li>
<li>AirQualityFull</li>
<li>AirQualityHumidity</li>
<li>AirQualityNO2</li>
<li>AirQualityO3</li>
<li>AirQualityPM10</li>
<li>AirQualityPM25</li>
<li>AirQualityPressure</li>
<li>AirQualityTemperature</li>
<li>AirQualityVOC</li>
</ul>
\n\n
As response you should recieve a success message with internal serialnumber granted by the SysAP for that virtual device.
Now you can continue working with that virtual device as with any other native free@home component via free@home API.
\n\n
This endpoint is also used to update the TTL regularly per device.
When the application does not call this endpoint every TTL seconds (defaults to 180),
the SysAP will mark the virtual device as unresponsive until a newlife sign is send.
Changes to the datapoints can be sent via the /api/rest/datapoint/ endpoint.
\n\n
Please find further description in the [virtual device documentation](https://developer.eu.mybuildings.abb.com/fah_cloud/concepts/#virtual-devices)
and an example in the [samples](https://developer.eu.mybuildings.abb.com/fah_cloud/samples/#how-to-register-a-virtual-device)."
operationId: create-virtual-device
parameters:
- name: sysap
in: path
required: true
schema:
- name: serial
in: path
description: serialnumber for virtual device (choose freely)
required: true
schema:
$ref: "#/components/schemas/NativeSerial"
example: "abcd12345"
requestBody:
description: Optional description in *JSON*
required: true
content:
application/json:
schema:
$ref: "#/components/schemas/VirtualDevice"
responses:
"200":
description: successful
content:
application/json:
schema:
$ref: "#/components/schemas/VirtualDevicesSuccess"
"502":
"401":
"/api/rest/proxydevice/{sysap}/{class}/{device}/action/{action}":
get:
tags:
- "experimental api"
summary: Trigger proxy device
description: "Trigger proxy device"
operationId: proxydevice
parameters:
- name: sysap
in: path
required: true
schema:
- name: class
in: path
description: "device class"
required: true
schema:
$ref: "#/components/schemas/DeviceClass"
example: "pushbutton"
- name: device
in: path
description: "individual device ID"
required: true
schema:
example: "shelly"
- name: action
in: path
description: "action to execute"
required: true
schema:
type: string
enum:
- "shortpress"
- "doublepress"
responses:
"200":
content:
application/json:
schema:
"502":
content:
text/plain:
schema:
"401":
"/api/rest/proxydevice/{sysap}/{class}/{device}/value/{value}":
put:
tags:
summary: Set proxy device value
description: "Set proxy device value"
operationId: proxydevice_value
parameters:
- name: sysap
in: path
required: true
schema:
- name: class
in: path
required: true
schema:
example: "temperaturesensor"
- name: device
in: path
required: true
schema:
example: "shelly"
- name: value
in: path
description: "value to be set"
required: true
schema:
type: string
enum:
- "temperature"
- "alarm"
responses:
"200":
content:
application/json:
schema:
"502":
content:
text/plain:
schema:
"401":
components:
schemas:
Error:
type: object
properties:
code:
type: string
detail:
type: string
title:
type: string
nullable: true
example:
code: "2010"
detail: FreeAtHome connection timeout
title: Connection Error
SysapUuid:
type: string
pattern: "^0{8}-0{4}-0{4}-0{4}-0{12}$"
DeviceSerial:
type: string
pattern: "^[0-9A-Fa-f]{12}$"
ChannelSerial:
type: string
pattern: "^ch[0-9A-Fa-f]{4}$"
DatapointSerial:
type: string
pattern: "^[io]dp[0-9A-Fa-f]{4}$"
DeviceAndEndPontSerial:
type: string
pattern: "^[0-9A-Fa-f]{12}.ch[0-9A-Fa-f]{4}.[io]dp[0-9A-Fa-f]{4}$"
NativeSerial:
type: string
pattern: "^[a-zA-Z0-9\\-_]{1,64}$"
DeviceClass:
type: string
enum:
- "doorring"
- "pushbutton"
- "smokedetector"
- "temperaturesensor"
Rooms:
type: object
additionalProperties:
type: object
properties:
name:
type: string
Floors:
type: object
type: object
properties:
name:
type: string
rooms:
$ref: "#/components/schemas/Rooms"
InOutPut:
type: object
properties:
pairingID:
type: integer
value:
type: string
Channel:
properties:
displayName:
type: string
functionID:
type: string
room:
type: string
floor:
type: string
inputs:
type: object
$ref: "#/components/schemas/InOutPut"
outputs:
type: object
type:
type: string
Devices:
$ref: "#/components/schemas/Device"
Device:
type: object
properties:
displayName:
type: string
room:
type: string
floor:
type: string
interface:
type: string
nativeId:
type: string
channels:
type: object
$ref: "#/components/schemas/Channel"
Users:
type: object
type: object
properties:
enabled:
type: boolean
flags:
type: array
items:
type: string
grantedPermissions:
type: array
items:
type: string
jid:
type: string
name:
type: string
requestedPermissions:
type: array
items:
type: string
role:
type: string
example:
foobar-fhapi:
enabled: true
flags:
- oauth
- randomPassword
- system
grantedPermissions:
- oauth
- randomPassword
- system
- oauth
- randomPassword
- system
role: switch
jid: foobar-fhapi@busch-jaeger.de
SysAP:
type: object
properties:
devices:
$ref: "#/components/schemas/Devices"
floorplan:
type: object
properties:
floors:
$ref: "#/components/schemas/Floors"
sysapName:
type: string
users:
$ref: "#/components/schemas/Users"
error:
$ref: "#/components/schemas/Error"
description: SysAP
Configuration:
type: object
$ref: "#/components/schemas/SysAP"
description: Configuration for all SysAPs
Devicelist:
type: object
type: array
items:
type: string
description: Device Serial Number
example:
3c542979-abe2-43ad-9ce0-f7d2b14b8d48:
- ABB700000000
VirtualDeviceType:
type: string
enum:
- "BinarySensor"
- "BlindActuator"
- "SwitchingActuator"
- "CeilingFanActuator"
- "RTC"
- "DimActuator"
- "evcharging"
- "WindowSensor"
- "simple_doorlock"
- "ShutterActuator"
- "WeatherStation"
- "Weather-TemperatureSensor"
- "Weather-WindSensor"
- "Weather-BrightnessSensor"
- "Weather-RainSensor"
- "WindowActuator"
- "CODetector"
- "FireDetector"
- "KNX-SwitchSensor"
- "MediaPlayer"
- "EnergyBattery"
- "EnergyInverter"
- "EnergyMeter"
- "EnergyInverterBattery"
- "EnergyInverterMeter"
- "EnergyInverterMeterBattery"
- "EnergyMeterBattery"
- "AirQualityCO2"
- "AirQualityCO"
- "AirQualityFull"
- "AirQualityHumidity"
- "AirQualityNO2"
- "AirQualityO3"
- "AirQualityPM10"
- "AirQualityPM25"
- "AirQualityPressure"
- "AirQualityTemperature"
- "AirQualityVOC"
VirtualDevice:
type: object
required:
- "type"
properties:
type:
$ref: "#/components/schemas/VirtualDeviceType"
properties:
type: "object"
properties:
ttl:
type: "string"
displayname:
type: "string"
example:
"type": "SwitchingActuator",
"properties": { "ttl": "180", "displayname": "Virtual switch" },
ScenesTriggered:
type: object
type: object
required:
- "channels"
properties:
channels:
type: object
type: object
required:
- "outputs"
properties:
outputs:
type: object
type: object
required:
- "value"
- "pairingID"
properties:
value:
type: string
pairingID:
type: integer
WebsocketMessage:
type: object
type: object
required:
- datapoints
- devices
- devicesAdded
- devicesRemoved
- scenesTriggered
properties:
datapoints:
type: object
type: string
devices:
type: object
devicesAdded:
type: array
items:
type: string
devicesRemoved:
type: array
items:
type: string
scenesTriggered:
$ref: "#/components/schemas/ScenesTriggered"
ApiRestConfigurationGet502TextPlainResponse:
type: string
example: FreeAtHome Connection Timeout
ApiRestDevicelistGet502TextPlainResponse:
type: string
ApiRestDevice_sysap__device_Get200ApplicationJsonResponse:
type: object
type: object
properties:
devices:
example:
"00000000-0000-0000-0000-000000000000":
"devices":
"600028E1ED13":
"channels":
"ch0000":
"displayName": "Test",
"functionID": "0007",
"inputs":
"idp0000": { "pairingID": 1, "value": "0" },
"idp0001": { "pairingID": 2, "value": "0" },
"idp0002": { "pairingID": 3, "value": "0" },
"idp0003": { "pairingID": 4, "value": "0" },
"idp0004": { "pairingID": 6, "value": "0" },
"idp0005": { "pairingID": 48, "value": "" },
"idp0006": { "pairingID": 323, "value": "" },
"idp0007": { "pairingID": 333, "value": "" },
"idp0008": { "pairingID": 334, "value": "" },
"outputs":
"odp0000": { "pairingID": 256, "value": "0" },
"odp0001": { "pairingID": 257, "value": "0" },
"odp0002": { "pairingID": 273, "value": "" },
"odp0003": { "pairingID": 305, "value": "" },
"odp0004": { "pairingID": 321, "value": "" },
"odp0005": { "pairingID": 335, "value": "" },
"odp0006": { "pairingID": 336, "value": "" },
"nativeId": "47110815AA",
"unresponsive": false,
ApiRestDevice_sysap__device_Get502TextPlainResponse:
type: string
ApiRestDatapoint_sysap__serial_Get200ApplicationJsonResponse:
type: object
type: object
properties:
values:
type: array
items:
type: string
example: { "00000000-0000-0000-0000-000000000000": { "values": ["1"] } }
ApiRestDatapoint_sysap__serial_PutRequest:
type: string
example: "1"
ApiRestDatapoint_sysap__serial_Put200TextPlainResponse:
type: object
example: { "00000000-0000-0000-0000-000000000000": { "result": "OK" } }
ApiRestDatapoint_sysap__serial_Put502TextPlainResponse:
type: string
VirtualDevicesSuccess:
description: payload contains new generated device id
type: object
type: object
properties:
devices:
type: object
type: object
properties:
serial:
type: string
example:
{ "devices": { "abcd12345": { "serial": "6000D2CB27B2" } } },
responses:
UnauthorizedError:
description: Authentication information is missing or invalid
securitySchemes:
basicAuth:
type: http
scheme: basic
security:
- basicAuth: []
tags:
- name: api
description: Main API
- name: "experimental api"
description: Experimental API
Does this work with Firmware 3.1.0? Because I canāt get any connection. My user isnāt the āinstallerā account, and the API setting created some long username.
As I wrote above:
It works fine with the 3.1.0 Firmware
Yes, I am running this version of the binding, being the source code as referred to above under SysAp FW version 3.1.0. Although, you need to be using a SysAp account set up with āinstallerā rights to get the binding working.
Also, as @ML1982 points out: You need to manually set up the bridge first (using correct IP and account with installer rights), and once the bridge is online, you can scan for things for autodiscovery.
Iāve uploaded the JAR into the /usr/share/openhab/addons folder and changed via chown the user to openhab. My free@home system has an activated API. The used user has all rights within free@home (compared to the āinstallerā).
But itās always initializing. I donāt know why.
Is there a way to see any logs? (sorry, but Iām new to openHAB).
Uncertain what you are trying to achieve with the chown feature, which only is used for permissions of the file system itself. Also uncertain what the Activated API is.
As part of manual configuration of the bridge within openHAB, you need to use username/password for a SysAp account registerred with installer rights. Under SysAp, you could for instance create a new installer account to be used by openHAB only.
Also, you should try restarting OH if you are getting only Initializing
Oh, you are not using the official API, because for that I get another username (not my real one).
I canāt post more then one image (new user). Maybe I should use Photoshop to show my setup.
At first, I will try my real username.
Edit: With my real username:
Something is real strange.
I have SysAp v1, FW 3.1.0. I am also using the official API, although being the cloud API as local API is only supported by SysAp v2. The cloud API is integrated in the binding by means of auto discovery of devices (recognized by the device type ID), so I am not relying on API input in the F@H / openHAB interface itself. So, I also have a API user registered in SysAp, but I still use my username (with installer rights) used to log in to the SysAp from browser, to log in to the bridge from openHAB.
To troubleshoot further why you only get your bridge Initializing
and Offline
you should:
- Reboot openHAB a couple of times
- Provide debug logs to show what is happening during startup
Your explanation sounds strange. I have a SysAP 2 and want to use the local API (not the cloud API). My current problem is that I broke my Raspberry SD card and need to get a new one to test again.
In the meantime, I will check your source code and try to reproduce the calls with postman (or other tools). I didnāt find any reference to XMPP in the documentation for my SysAP 2, so Iām confused.
I will reply on Wednesday when I have new hardware.
Edit: I search for XMPP and found out, that XMPP is an undocumented feature and for SysAP 2 you could use the local API. Does anybody has a SysAP 2 to confirm, that the addon is working (and Iām too stupid to configure it)?
@kjoglums Iām trying to create a local API binding addon, so we donāt need any cloud to get the data.
The binding from kjoglums is using an undocumented XMPP interface of free@home and NOT the official REST API from Busch-Jaeger!
