edit :
Found a severe bug in the process : the “begin” line of running events is triggered every time the event list is refreshed.
Which in case of controling my heaters is very unfortunate if I have a
long heating event (with begin and end lines), and if in the middle of
the event I manualy shut down the heaters … they switch on by
themselves almost instantaneously ! (because I set the caldavio to
refresh every minute - for testing purpose but I dont control when the caldav will refresh in normal configuration)
Hi, I hope someone will be able to help : something went wrong with caldav, and now it doesnt work even if I delete
userdata/etc/caldav/*
userdata/cache
userdata/tmp
I even have tried to delete the caldendar itself (running with radicale)
everytime I start openhab, this is what I get :
2016-10-10 01:17:41.831 [ERROR] [org.openhab.binding.caldav-personal ] - [org.openhab.binding.caldav_personal(175)] The addBindingProvider method has thrown an exception
java.lang.NullPointerException
at org.openhab.binding.caldav_personal.internal.CalDavBinding.updateItemsForEvent(CalDavBinding.java:225)
at org.openhab.binding.caldav_personal.internal.CalDavBinding.allBindingsChanged(CalDavBinding.java:134)
at org.openhab.core.binding.AbstractBinding.addBindingProvider(AbstractBinding.java:61)
at org.openhab.binding.caldav_personal.internal.CalDavBinding.addBindingProvider(CalDavBinding.java:85)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_101]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_101]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_101]
at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_101]
at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)
at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)
at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)
at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)
at org.apache.felix.scr.impl.helper.BindMethod.invoke(BindMethod.java:41)
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1660)
at org.apache.felix.scr.impl.manager.DependencyManager.open(DependencyManager.java:1495)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:265)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:113)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:866)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:833)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:774)[33:org.apache.felix.scr:2.0.2]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_101]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.apache.felix.metatype.internal.ManagedServiceTracker.addingService(ManagedServiceTracker.java:52)[2:org.apache.felix.metatype:1.1.2]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:869)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:857)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:915)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:715)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:330)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:295)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:120)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:399)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:676)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:360)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.access$000(Activator.java:53)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:260)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[33:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[33:org.apache.felix.scr:2.0.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:393)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:412)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1199)[9:org.apache.karaf.features.core:4.0.4]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:840)[9:org.apache.karaf.features.core:4.0.4]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1089)[9:org.apache.karaf.features.core:4.0.4]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl$1.call(FeaturesServiceImpl.java:985)[9:org.apache.karaf.features.core:4.0.4]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
and on every refresh of the calendar, I get errors
