Platform information:
- Hardware: Raspberry pi 3
- OS: Linux / Volumio debian
- Java Runtime Environment: java version “1.8.0_191”
- openHAB version: 2.3 or 2.4
Issue of the topic: Not able to succesfully upgrade from 2.3 to 2.4
If logs where generated please post these here using code fences:
2019-04-19 09:45:24.815 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-package-demo': No matching features for openhab-package-demo/0.0.0
2019-04-19 09:45:24.906 [ERROR] [url.mvn.internal.AetherBasedResolver] - invalid repository URLs
java.net.MalformedURLException: no protocol: system/
at java.net.URL.<init>(URL.java:593) [?:?]
at java.net.URL.<init>(URL.java:490) [?:?]
at java.net.URL.<init>(URL.java:439) [?:?]
at org.ops4j.pax.url.mvn.internal.config.MavenRepositoryURL.<init>(MavenRepositoryURL.java:191) [4:org.ops4j.pax.url.mvn:2.5.4]
at org.ops4j.pax.url.mvn.internal.config.MavenConfigurationImpl.getDefaultRepositories(MavenConfigurationImpl.java:234) [4:org.ops4j.pax.url.mvn:2.5.4]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.selectDefaultRepositories(AetherBasedResolver.java:427) [4:org.ops4j.pax.url.mvn:2.5.4]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:617) [4:org.ops4j.pax.url.mvn:2.5.4]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:600) [4:org.ops4j.pax.url.mvn:2.5.4]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:567) [4:org.ops4j.pax.url.mvn:2.5.4]
at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:47) [10:org.apache.karaf.features.core:4.1.5]
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60) [10:org.apache.karaf.features.core:4.1.5]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2019-04-19 09:45:25.319 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-hue, openhab-binding-exec, openhab-misc-restdocs, openhab-misc-openhabcloud, openhab-binding-network, openhab-ui-habpanel, openhab-misc-hueemulation, openhab-binding-denonmarantz, openhab-transformation-map, openhab-binding-rfxcom, openhab-binding-kodi, openhab-transformation-exec, openhab-ui-paper, openhab-binding-wol1, openhab-binding-samsungtv, openhab-voice-voicerss, openhab-binding-weather1, openhab-transformation-regex, openhab-action-telegram, openhab-persistence-rrd4j, openhab-ui-basic, openhab-binding-ntp, openhab-misc-homekit, openhab-binding-astro, openhab-binding-expire1': Error:
Error downloading mvn:org.apache.karaf.shell/org.apache.karaf.shell.ssh/4.2.1-sp1
Hi Guys,
I wanted to upgrade Openhab 2.3 to 2.4 but i’m failing. I’m running a manual installation of Openhab because it runs on a raspberry pi 3 with Volumio installed which is my internet radio in my house. Volumio cannot be installed manually so i have to install openhab manually on the Volumio image which is linux debian.
Openhab 2.3 was running without any problems but i wanted to use geofencing and wanted to use the new openweather binding. I tried to upgrade by simply copying the 2.4 files to /opt/openhab2 folder. It copied succesfully but when i started openhab, the homescreen showed in the bottom version 2.3.0, so something went wrong. After reading the manual installation for linux I saw the upgrade was just executing the command: sudo runtime/bin/update 2.4.0. But when I try that, it says I’m already on 2.4.0. Now the problem is, my logfile is filled with the error i posted above, problems with the binding. And my Bindings window in paper ui doesn’t show any bindings anymore.
Does anyone have a sollution for this, or should I uninstall openhab 2.3 and install 2.4 again. I copied all my rules files to my computer, so I guess I won’t lose any of my 1300 lines of code ![]()
