solomalee
(Sol O'Malee)
January 30, 2021, 11:27am
1
Hi folks,
Hope someone can help me out with this, I’ve searched everywhere and can’t find any advice to address this issue.
Problem:
I upgraded from OpenHAB2 to OpenHAB 3 and have difficulty to access the OpenHAB webUI on some of my devices…
I have several iPads
Newer ones (eg: iOS14), I can access my OpenHAB server via http://openhab:8080/#!/
Older ones (iOS 9), I use as a wall mounted controller and I cannot access and get this message:
A problem repeatedly occurred on "http://openhab:8080/#!/
What have I tried?
I’ve tried to connect to:
the server name
ip address
with and without the trailing /#!/.
I have also tried to access via Safari and Chromeniether are able to connect
Any advice? is iOS 9.3.5 not supported?
Jorgensen
(Jørgensen)
February 4, 2021, 7:41pm
3
I’m having problems with Login in as well. Mostly because i want to use my old habpanels.
Dont know if it the same issue as yours.
I can connect with the main 192.x.x.x:8080 but i can not press the login in the bottom left.
I am on an older iPad with IOS 10.3.3.
Wondering if it has something to do with Java 11.
Eric_P
(Eric)
February 22, 2021, 10:49pm
4
I have the same problem too.
romain
(Romain)
March 5, 2021, 2:30pm
5
And me too, both with the web browser and the native app
Is there a plan to support IOS 9.3 ? It would be nice as it gives a second life to some old ipads that work perfectly well.
crnjan
(Crnjan)
March 5, 2021, 2:36pm
6
Please check OH3 webapp does not work on iOS 9.3.5 · Issue #759 · openhab/openhab-webui · GitHub
Long story short
Framework7 (v5) needs Safari 9.1 and iOS 9.3.5 ships with Safari 9.0 so unfortunately MainUI will not run on iOS 9.3.5 - iOS 10 is required as minimum.
romain
(Romain)
March 5, 2021, 2:39pm
7
but thanks for the answer !
bazza1024
(Bazza1024)
April 26, 2021, 5:15pm
8
Are there any work arrounds so I can still use ipad2 as panels.
Accepting it cant use the new ui, habpanel says they need to login which takes me to the ui and doesn’t load.
Failing that I guess I could run a 2.5 instance with some dummy controls which the oh3 instance monitors.
bazza1024
(Bazza1024)
April 26, 2021, 8:05pm
9
Oh a search lead me here and down a rabbit hole, when it was actually just a simple issue that I hadn’t set the habpanel as the default.
Ipad2 running kiosk Pro displaying habpanel fine.
borazslo
(Laszlo Elek)
February 9, 2023, 10:38pm
10
Thank you! You saved my … everything.
how did you manage to install kiosk pro when apple does not let the ipad register at the store?
