Can't connect Android device to own openhab cloud instance
Hi!
With help of the community I was able to set up my own openhab cloud instance. Now I want to connect my phone to this cloud instance. Instructions seems to be pretty easy
but when I set this URL the port 443 is automatically removed (what has no further effects, I guess)
and the device will not show up in the list.
What else needs to be configured to make my phone appear in the device list?
In order to make notifications work I need to install FCM, right?
Needs this to be done before registering a device?
Best regards
Is there anything else that I can provide so that anybody can give me a hint?
I haven’t given up hope yet and am still trying to establish a connection. I have created the necessary entries for FCM and entered them in config.json.
The device still does not appear in the overview.
The Android app now shows the following (unfortunately I can’t say whether it was there before):
“Notifications not available: Server for remote access is not an openHAB cloud instance”
Does anyone know why the openHAB cloud instance is not recognized as such?
Best regards
I assume that it’s this check that fails. I’m not sure why that field would be missing, though … in any case, you can easily double check the assumption using e.g. curl.
Thanks for your reply!
I tried to use a curl command but I was not able to escape the password.
Also I did not find anything how a bearer token is generated within openhab cloud.
Fortunately wget worked and gave me an empty JSON.
So firebase is not setup correctly and I will first work on that and get back with further information.
Thanks again and best regards!
I have looked into the issue further and as far as I understand it, the whole problem has nothing to do with Firebase, but with my setup, because Firebase cannot work unless the Android device is listed in openHAB Cloud.
Now the big question: How can I make sure that my local openHAB instance, openHAB Cloud and the openHAB Android app are configured correctly?
Or could it perhaps be a network/firewall problem?
Unfortunately, I don’t know how and where to start. :confused:
Best regards
Someone had a good idea (unfortunately it wasn’t me).
I tried the whole thing with myopenhab and it works perfectly. For me, this means that my local instance, smartphone and network with ports etc. are working correctly and the problem lies with my openHAB Cloud instance.
Does anyone have any ideas on how and/or what to test/check?
I have exactly the same issue - did you find a solution?
No, not yet. I hope to have some time between the years to set up a development environment and debug the setup.
OK - regarding the “Notifications not available: Server for remote access is not an openHAB cloud instance”
I changed my user password from a 15 character password including a “.” to a 9 character password that didn’t include the character “.” and … voila! - android device is shown as a registered device and now it is a valid openHab cloud instance and notifications are back on the menu
list
now it seems I have to compile the android app with my FCM google-services.json file in order to get the android push notifications - tried this and getting errors - ho-hum
