Those are WiFi channels - not ZigBee channels, or Bluetooth channels, or any other definition - just WiFi.
Is this supposed to work now with 2.5.1 as the pull request was merged?
I can discover the Thermostat with my BitronVideo Stick and it is shown in Paper UI as “ONLINE”, but the thermostat itself is showing “Err” and tries to join again after pressing the “Boost” button. I have reset the Thermostat numerous times, but it makes no difference.
Should this work now and it’s a problem on my side or is this still a work-in-progress and I just need to be patient?
(I’m using the 2.5.1-2 Debian package on a Raspberry Pi 4 with standard Raspbian.)
No - it won’t work still.
I’ve in the process of finalising the libraries (today/tomorrow) and once this is done I’ll try and get this merged into OH as quickly as possible.
Thank you for your lightning fast response and all the work you put into this.
I would appreciate it if you could drop a quick comment here when your changes are merged so I can try again with the latest snapshot.
I probably won’t find this thread again in a weeks time, so I’d suggest to monitor the following PRs -:
Once both of these are merged, and the binding rebuilt, then please update to the latest 2.5.x snapshot.
Just tried out the 2.5.2-SNAPSHOT from 8 hours ago and joining worked fine.
If somebody is interested in these thermostats there are five channels available:
- Occupied Cooling Setpoint
- Unoccupied Heating Setpoint
- Local Temperature
- Occupied Heating Setpoint
- System Mode
Although I don’t know what all these channels except Occupied Heating Setpoint and Local Temperature are for. And unfortunately the battery status and the local temperature calibration is not accessible although those attributes are described in the documentation.
Great - thanks for the feedback.
I would have expected battery state channel, but I will need to look at what service this actually providing as there are a few ways to provide this information.
Temperature calibration is not something that I’ve supported at the moment but please raise an issue and I can take a look at it when I get a chance.
Can I do something to assist you with this? The Cluster Id, Attribute Id and data type are described in the manual on page 14/15. (https://eurotronic.org/wp-content/uploads/2019/11/Spirit_ZigBee_BAL_web_DE_Okt.-2019.pdf)
I could also post a logfile of the device joining if this would help. Although the attribute 0x21 (33) <name>Battery Percentage Remaining</name>
is present in the XML file, but is listed as <implemented>false</implemented>
. Well, OK, maybe that does not mean anything as all attributes in the XML file are marked as not implemented.
That’s really not that important. It’s just a convenience if somebody is adjusting the temperature on the thermostat itself. Everything else could be handled inside OpenHAB.
It’s ok, I have one of these devices so I can take a look at this.
if it is possible, also provide
TRV Mode (0x40000x02 (MANU Mode) 0x30 (8-bit enum) R/W) and
Set Valve Position (0x40010x00 0x20 (int8u) R/W)
If TVR Mode is set to “Unknown2” (seen in Deconz), it is possible to set the valve Position. So we are able to pogram an own heating control with an external thermostat.
By now… thanks for the work… since 2.5.2 Snapshot the values for the available channels are send/received correct.
Regards
Thanks - I’ve marked it as an enhancement although that’s less critical. Getting it on the list means it won’t get lost at least (although it doesn’t mean it will get done immediately ).
Thanks! Should be the same as in the Eurotronic ZWave Spirit.
In some Smart Home software it is possible to change do “manuel Mode” and set the valve position.
So it is possible to start/stop heating by comparing the temp from an external thermosat
Question about the implementation:
Is creating the chanels generic by reading the whole cluster?
Well, ZigBee is totally different, so while the function on the device might be the same, the actual implementation in the binding is 100% different.
I’m not sure I understand. The binding has a definition of channels, and a “converter” that it uses to translate the data between the OH world, and the ZigBee world. Once this is written, then the binding will create channels dynamically based on the clusters, commands and attributes that it detects in the device.
Ok, I thought it is similar. The same Hardware is also used by Rademcht, with another frequency and protocol.
Ok, thanks for explenation. I thought ther is a handshake between device and software. So the device says… look, her are all my possible clusters and in the culster you can use the following chanells. Seems that in Thermostat cluser the IDs > 0x002x are device/manufacture sepecific.
Maybe I will have a look into the implementation…
Found it… ok, now I understand
Yes, fundamentally, this is what happens. The only difference here really is the “channels” part of you comment. The binding learns about the clusters, and then has to detect what “stuff” within the cluster is actually supported (ie knowing the cluster is not enough). The binding then needs to add a “channel converter” that handles any commands, or processes attributes that the device might send and make them available in the openHAB world.
Thanks a lot… saw it in …/internal/converter/ and found the actually supported channels. When I find the time, I will look at the existing ones
Hi there, see there is something happened in between.
I switched to Z#a#e with Eurotronic Spirit Thermostats in meantime, they worked out of box for me.
But have a little problems with it also, sometimes some thermostats are falling back to “install mode” so i have to put out batterie and put them back in and press button of it to let it learn valve position again. Suggest? If its not a short answer i will add a new thread in z#a#e categorie. And yesterday something strange happend with thermostats in living room (two of them in same room), they were´nt back in setup mode and in openhab they were shown as online and setpoint was set to 22°C and mode to heat, but they did not close valve as they reached set point, but heating further more instead to around 27°C. Did the same trick to it like the other ones, by cycling battery and now seam to work again.
Back to Zigbee: Joining should work now? I kept my Zigbee Thermostats also, maybe reuse them at my families home. Is there a compiled package for redhat linux for 2.5.2-snapshot, so i may try if the problem really was an error of crowded radio around my place. If it works i think this thread can be closed.
