Platform information:
- Hardware: Up Board (specs UP Board Series - Intel® ATOM™ - 16GB/32GB eMMC)
- OS: Ubuntu Server 18.04 64 Bit
- Java Runtime Environment: OpenJDK 8
- openHAB version: current stable 2.4.0
Issue of the topic: I try to use the AVM FRITZ! Binding and the Fritzbox Binding TR064 to connect to my Fritz Box 7560, but it doesn’t work. I updated the Fritz OS to the current version 07.01, the TR064 protocol is activated and I add a new user for openHAB. I assume that’s all I have to set up at the FB
With the AVM FRITZ! Binding I am able to find the FritzBox (with name) and can add it as thing. I edit the Configuration Parameters (port, user, password) (I try to use HTTP and HTTPS). But I get the message “Status: OFFLINE - COMMUNICATION_ERROR Request is invalid”
For the TR064 Binding I edit the file fritzboxtr064.cfg. But if I go to the Inbox and select the TR064 binding nothing happens
I also tried dslf-config as user or with no user, but with the same result
Currently I don’t have any logs because I don’t know where I can find them.
I hope someone can help me
Regards
Markus
