Which OH version
3.0 .. 3.0.2 so have Problems because of shutdown of bintray maven repo.
Version In development Max have other problems. In case of stabile version it could be a problem of your network.
I’m running OH version 3.3.0. Unfortunately I haven’t had time to look at this problem but when restarting OH I do get these errors constantly so OH is trying to install the InfluxDB persistence.
Yes, I have turned off the Windows Defender and F-Secure Client Security. I have also tried now to install Miele Cloud binding but this fails also. Something strange with my OH.
EDIT: Just remembered that I got a new cable modem some weeks ago so I need to check that the cable modem is not blocking.
You stated that you run OH 3.3.0. I am running that version on a Pi and I checked the installation for the above mentioned jar library.
As far as I can see on my system that library ( pax-logging-log4j2 ) should come with the basic installation but instead of 2.0.12 version 2.0.16 is provided with the core installation:
Was this OH 3.3.0 installation updated based on an earlier installation ?
To be more precise my installation is 3.3.0-1. Most probably pax-logging-log4j2 was updated due to dependencies to log4j2 which is vulnerable to specific attack vectors.
Although this may explain why an older version is being tried to installed/downloaded this does not explain why it is not installed - apart if there would be software that refuses to download the older version.
Wolfgang, it could be that something is preventing now installation of any binding because I have now tried to install Miele Cloud binding which also fails. Only change I have made in my home LAN is that I got a new cable modem some weeks ago. Unfortunately I don’t have access now to it from work with VNC because I can’t remember the admin password for the cable modem.
