I tried to install DSCAlarm Binding on OH3.3 but it failed. OH log file has lots of messages and I have no ideas what is causing the problem.
I have DSC 1864 panel with EyezOn Envisalink 4 interface card. I have registered the card on Eyezon website and I have access to the interface with a browser.
I get these messages every time when I restart OH. Any ideas?
2022-10-07 16:26:49.427 [WARN ] [nstance.core.internal.osgi.Activator] - Error starting activator
java.lang.NoClassDefFoundError: org/apache/karaf/shell/support/RegexCommandLoggingFilter
at org.apache.karaf.instance.core.internal.osgi.Activator.doStart(Activator.java:36) ~[bundleFile:4.3.4]
at org.apache.karaf.util.tracker.BaseActivator.start(BaseActivator.java:92) [bundleFile:4.3.4]
at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:813) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:1) [org.eclipse.osgi-3.17.200.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:805) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:762) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1032) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:371) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.Module.doStart(Module.java:605) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:468) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.17.200.jar:?]
Caused by: java.lang.ClassNotFoundException: org.apache.karaf.shell.support.RegexCommandLoggingFilter cannot be found by org.apache.karaf.instance.core_4.3.4
at org.eclipse.osgi.internal.loader.BundleLoader.generateException(BundleLoader.java:529) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass0(BundleLoader.java:524) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:416) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:168) ~[org.eclipse.osgi-3.17.200.jar:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:522) ~[?:?]
... 20 more
2022-10-07 16:26:51.349 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Helsinki'.
2022-10-07 16:26:51.365 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '60.17191425606695,24.729867875576023'.
2022-10-07 16:26:51.365 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_FI'.
2022-10-07 16:26:51.724 [INFO ] [rketplace.MarketplaceBundleInstaller] - Reinstalling missing marketplace bundle: marketplace:131832
2022-10-07 16:26:51.989 [WARN ] [rketplace.MarketplaceBundleInstaller] - Failed reinstalling add-on from cache
org.openhab.core.addon.marketplace.MarketplaceHandlerException: Cannot install bundle from marketplace cache: A bundle is already installed with the name "org.openhab.binding.mybmw" and version "3.3.0.202205281450"
at org.openhab.core.addon.marketplace.MarketplaceBundleInstaller.installFromCache(MarketplaceBundleInstaller.java:99) ~[?:?]
at org.openhab.core.addon.marketplace.MarketplaceBundleInstaller.lambda$3(MarketplaceBundleInstaller.java:156) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183) [?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:177) [?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195) [?:?]
at java.util.Iterator.forEachRemaining(Iterator.java:133) [?:?]
at java.util.Spliterators$IteratorSpliterator.forEachRemaining(Spliterators.java:1801) [?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484) [?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) [?:?]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) [?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) [?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) [?:?]
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:497) [?:?]
at org.openhab.core.addon.marketplace.MarketplaceBundleInstaller.ensureCachedBundlesAreInstalled(MarketplaceBundleInstaller.java:153) [bundleFile:?]
at org.openhab.core.addon.marketplace.internal.community.CommunityBundleAddonHandler.<init>(CommunityBundleAddonHandler.java:52) [bundleFile:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) [?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) [?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:490) [?:?]
at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:316) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1000) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:973) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:776) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-7.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:944) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.17.200.jar:?]
Caused by: org.osgi.framework.BundleException: A bundle is already installed with the name "org.openhab.binding.mybmw" and version "3.3.0.202205281450"
at org.eclipse.osgi.container.ModuleContainer.install(ModuleContainer.java:311) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.storage.Storage.install(Storage.java:724) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.installBundle(BundleContextImpl.java:182) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.openhab.core.addon.marketplace.MarketplaceBundleInstaller.installFromCache(MarketplaceBundleInstaller.java:90) ~[?:?]
... 57 more
2022-10-07 16:26:59.825 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2022-10-07 16:26:59.867 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-dscalarm': Error:
Error downloading mvn:org.ops4j.pax.logging/pax-logging-api/2.0.12
Error downloading mvn:org.ops4j.pax.logging/pax-logging-log4j2/2.0.12
2022-10-07 16:27:02.189 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2022-10-07 16:27:04.105 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
2022-10-07 16:27:04.513 [INFO ] [rt.modbus.internal.ModbusManagerImpl] - Modbus manager activated
2022-10-07 16:27:05.845 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2022-10-07 16:27:08.752 [ERROR] [org.openhab.core.items.GenericItem ] - Tried to set invalid state 0.0 (DecimalType) on item Etuvalot_paalle of type StringItem, ignoring it
2022-10-07 16:27:09.691 [ERROR] [org.openhab.core.items.GenericItem ] - Tried to set invalid state 0.0 (DecimalType) on item Etuvalot_paalle of type StringItem, ignoring it
2022-10-07 16:27:11.786 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2022-10-07 16:27:18.880 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Invalid URI host: null (authority: null)
at org.eclipse.jetty.client.HttpClient.checkHost(HttpClient.java:521) ~[?:?]
at org.eclipse.jetty.client.HttpClient.newHttpRequest(HttpClient.java:506) ~[?:?]
at org.eclipse.jetty.client.HttpClient.newRequest(HttpClient.java:464) ~[?:?]
at org.eclipse.jetty.client.HttpClient.newRequest(HttpClient.java:453) ~[?:?]
at org.openhab.core.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:212) ~[?:?]
at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:155) ~[?:?]
at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:130) ~[?:?]
at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:108) ~[?:?]
at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:89) ~[?:?]
at org.openhab.binding.evcc.internal.api.EvccAPI.httpRequest(EvccAPI.java:57) ~[?:?]
at org.openhab.binding.evcc.internal.api.EvccAPI.getResult(EvccAPI.java:76) ~[?:?]
at org.openhab.binding.evcc.internal.EvccHandler.refresh(EvccHandler.java:195) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
2022-10-07 16:27:19.781 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 03582cc6-8569-4a4f-b305-f7de4d81a350, base URL = http://localhost:8080)
2022-10-07 16:27:59.526 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-dscalarm': Error:
2022-10-07 16:28:59.440 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-dscalarm': Error:
