Chamberlain MyQ Binding
I’m looking at the Aeon Labs Garage Door Controller Gen5 or a Aideepen 4 Channel DC 5V Relay Module and wire them to the push button switch on the wall controller. The Aeon Labs controller has an audio and visual signal when operated so it meets code and adds that safety factor, but it’s $60. The Aideepen relay doesn’t but it’s only $15 for 4 relays. I would need to flash it with Tasmodo to control it through OpenhHAB. Either way I would get away from MyQ’s apparent opposition to the home automation hobbyist community as this isn’t the first time they broke the binding and most likely will not be the last.
