Hi, since i upgraded my openhab installation to the snapshot oh 2.3 #1220, the integrated charts functionality is not working any more like before.
I had a charts.cfg in the services-directory to make the chart bigger for my full hd screen. This worked very good, until i made the upgrade to snapshot #1220. Formerly i was on the build #1210 or something around this.
On my android phone inside habdroid charts are now very ugly, they look like ms-dos style. Before they were white and in high resolution, now they have low resolution, black background and big font.
In basic ui i get a very small chart. in classic ui, the small chart is only zoomed to look bigger, but you can see this, the graphs and fonts are very blurry.
You set the provider twice, this is not normal.
You should not set this setting, as default is the only available chart provider. Or set it only to default.
i can see my chart settings in Paper UI in the third section in configuration / system.
I just installed the snapshot 1224 and I can confirm that the chart settings have disappeared.
They are present with the snapshot 1212. So they disappeared after.
Issue opened:
I made a snapshot upgrade to #1231. The new eclipse smarthome release is included.
Now i get the charts-settings inside PaperUI.
But it doesnĀ“t seem to work.
The charts look the same like before. Inside Basic UI and inside habdroid also. No change.
Do i have to keep the charts.cfg file or do i have to remove it? Which settings will be used if i have both positions configured with different values?
