I finally found the time to test and it seems you’re right, the chart settings defined in a cfg file are now ignored. I opened an issue:
Settings inside paper UI are also not working for me. I renamed my charts.cfg to .txt but nothing changed. Still only default charts.
I have now fixed the issue.
Please be patient, this will require a review and merge, a new ESH build and then finally a new OH snapshoit.
Please read the content of my issue, you will discover that path ofr settings was updated, use now org.eclipse.smarthome.chart rather than org.eclipse.smarthome.ui.chart
Thank you very much. I hope i will see an announcement somewhere in the forum, when there is a new esh build in the snapshots available.
With this fix, can i remove my charts.cfg file and do all settings inside paper ui or can i keep it and openhab will use only my charts.cfg? Or will OH only use the values from the charts.cfg and all other non declared values from the paper ui?
Now → distro 1253!
Thanks!
Now i´m on #1253 and now i don´t get charts anymore.
Many erros in the log…
2018-04-10 10:37:54.120 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: Could not get chart provider.
at org.eclipse.smarthome.ui.internal.chart.ChartServlet.doGet(ChartServlet.java:281) [151:org.eclipse.smarthome.ui:0.10.0.201804091757]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) [32:j
... and so on ...
It makes no difference if i remove my charts.cfg-file and only make paper ui settings or if i change something in the charts.cfg-file.
I can confirm that it’s working with paper ui settings. But first time I couldn’t see any chart (upgrade to 1253)…a reboot did help and everything is fine now
For me it is not working. Now i made 2 reboots. Still the same warnings like i posted above.
Any idea?
I renamed the charts.cfg to charts.cfg_txt but still not working.
Where can i make settings for default charts provider?
When i want to open only the icon for the broken image inside my browser, i get this:
HTTP ERROR 500
Problem accessing /chart. Reason:
Server Error
Caused by:
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:534)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589)
at java.lang.Thread.run(Thread.java:748)
How do i have to configure the charts.cfg-file?
org.eclipse.smarthome.chart:defaultHeight=800
org.eclipse.smarthome.chart:defaultWidth=1500
org.eclipse.smarthome.chart:scale=0.8
This way or with .ui. inside?
–> org.eclipse.smarthome.ui.chart:defaultHeight=
I don’t have a charts.cfg…did you try to delete this file and change the setting directly in the paper ui to something different? Maybe a change is needed to save something in a config-file…but I’m not sure.
Probably because you defined a chart provider different from default ?
Erase your files chart.config and chart.cfg and restart OH.
If I correctly remember, you insisted to set the provider to rrd4j while only default is a valid value.
I have tested with provider:default too, but with no success.
Where is the chart.config saved? I only know the charts.cfg-file?
EDIT:
I removed the charts.cfg completely, made settings inside paper ui charts section, server reboot, changed settings inside paper ui charts, openhab service restart
Still no success. Same error as before.
EDIT2:
After another server reboot, now it works!
But with habdroid android app the charts are still ugly. No such charts like on the webbrowser, only black background with ms-dos like (text style, no graphic ui) descriptions.
Is there a way to get the charts style back to the style of the webbrowser-charts?
Maybe someone can tell me, if the ugly charts on habdroid is an error (or feature?) of habdroid (openhab android app) or of the openhab-software itself?
On former versions i got the same charts like on the webbrowser. White background and so on.
Now it looks this way:
If I’m not mistaken the “ugly” chart shown is not from HABPanel! IMHO it is the actual way charts are displayed on HABDroid.
Yes, my mistake… i corrected my post.
It´s from habdroid.
But some time ago i got the same charts inside habdroid like on the webbrowser view.
Where has this changed? Inside habdroid? I can´t remember exactly, but i thought it was after an openhab snapshot update some time ago, so it has to be an openhab server side thing? Not a client side (habdroid)?
IMHO, Yes.
Have a look now, habdroid has been updated.
I was on 2.0.48 beta and now on 2.1 stable , but it looks the same for me. Charts in Webbrowser are still different.
