I would be VERY wary of these cheap Chinese video doorbells. The access is though a cloud. And we all know how the Chinese value privacy.
My verdict: Stay away
Itās possible, youāll have to use wireshark. But generally speaking the phone apps are proprietary and access a cloud. Some off the cameras are hackable but not all.
I picked up a few xiaomi Ants cameras, which were a great camera, accessible by rtsp, storing the footage locally on an SD card. The problem was that every notification was being sent to their Chinese servers, and required extensive hacking by the community to eventually cut this off but keep the camera working. In this case, the local retailer was knowingly selling a version intended for the Chinese market to North America. Some of it may have been because the North American version was priced significantly higher, but Iām imagining also the North American version wasnāt allowed to stream/send information to Chinese servers.
I wouldnāt be so sureā¦
If Iād bought one of these, first thing Iād do is connect it to a separate LAN and wireshark the crap out of it to make sure nothing goes out. If it did, Iād return it as faulty.
There is a cheap doorbell that home assistant users have running that is made and re-badged under multiple brands including Hikvision, not sure if Openhab users have gotten onto it yet?
RTSP and snapshot work, but you can not get button push alerts unless u diy and hacked solution.
Edit: Found this ideaā¦
Personally I am thinking of using a Dahua/Amcrest/ hikvision camera hidden up out of view that has alarm INPUT and OUTPUT terminals which Openhab can now control with the ipcamera binding. These relay terminals can be used to connect to any doorbell switch and buzzer/bell.
Result is button, audio and motion alerts direct to openhab and no cloud subscription.
Two way audio is not implemented in the binding but I suspect it can be done with Dahua and amcrest easily enough as the api has this feature.
At the end you all right guys.
Re considering all the variables these kind of cheap chinese stuff could be a messā¦and I donāt want to risk.
BUT:
what I need is
outdoor (outside of garden; 15 m more or less but no wifi signal avaible there) ring button + camera + microphone + speacker + pin or signal for open gate switch
inside fixed monitor + microphone + speacker (in order to have a conversation with the guy outside and let it come in)
Openhab integration
Doorbird Or Ring Is beautyfull (also expensives) but if they are meant to be installed very near to the front-doorā¦where internal wifi is avible and no fixed internal reciver is provided withā¦
At the moment I can not figure out how to implement a good solution for my needsā¦
I have a very similar challenge - my gate doesnāt have reliable wifi signals. One day Iāll probably take the plunge and get a doorbird, and probably run cat6 cable out to the gate to do it all properly.
Other options for you could be to get a wireless repeater to expand your wifi, simply add a wireless access point closer, or perhaps a repeater with a directional antenna pointing at where the doorbell will be. This all adds up, though ($$$)
The monitor/speaker to have the conversation - this is all pretty accessible with most of the companies. They have apps that can be installed on a phone - but could also be installed on a tablet that is accessible inside. The person buzzes the button, the app receives a push notification, and you can start a conversation. This all requires a good network connection.
Found another way that is cheap if you like a camera down at eye level and you have an AC doorbell already or you want to have this out in the garden. 24 volt ac is able to be done diy in most countries and considered safe running through a garden. Hikvision have a whole range of cameras and intercom systems of varying price and features just not sure how many of them work as a normal ip camera and supports their api.
For that price, I recommend getting any of Ring doorbell models. The first generation costs around the same price the model you listed. The rest are bit more expensive but completely worth it.
