Hi all,
I am trying to do a clean docker install on a rapberry pi 4. I cannot install any add ons. I get the following message over and over in my logs:
2021-04-21 17:26:39.544 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-persistence-mapdb, openhab-binding-exec, openhab-voice-mactts, openhab-voice-marytts, openhab-misc-openhabcloud, openhab-ui-habot, openhab-transformation-bin2json, openhab-voice-picotts, openhab-binding-network, openhab-persistence-influxdb, openhab-binding-hdpowerview, openhab-ui-habpanel, openhab-binding-buienradar, openhab-binding-chromecast, openhab-binding-mqtt, openhab-transformation-map, openhab-binding-logreader, openhab-binding-enocean, openhab-transformation-xslt, openhab-binding-homematic, openhab-transformation-exec, openhab-binding-systeminfo, openhab-transformation-jinja, openhab-transformation-scale, openhab-binding-samsungtv, openhab-voice-voicerss, openhab-binding-hyperion, openhab-binding-wled, openhab-transformation-javascript, openhab-binding-openthermgateway, openhab-transformation-regex, openhab-binding-openuv, openhab-binding-weatherunderground, openhab-transformation-jsonpath, openhab-binding-zwave, openhab-binding-miio, openhab-binding-wifiled, openhab-transformation-xpath, openhab-ui-basic, openhab-binding-openweathermap, openhab-binding-http, openhab-binding-astro, openhab-binding-squeezebox': Error:
Error downloading mvn:org.samba.jcifs/jcifs/1.3.17
I looked all over the forum. I only found this post
Unfortunately no resolution. Does anyone have an idea? Is some kind of resource down?
EDIT
I checked, my container is able to download files. So doesn’t look like a internet connection issue. I can access bash by using
sudo docker exec -it openhab /bin/bash
from there I can issue
wget https://openhab.jfrog.io/openhab/libs-release/jcifs/jcifs/1.3.17/jcifs-1.3.17.jar and i get the file
