milty456
(Rich Smith)
#1
WHen i set the following:
sendCommand(KitchenColorDim, 100)
sendCommand(KitchenColorCol, “251,100,64”)
Then immediately check the values, they are right…if i wait like 3 seconds and check again, the DIM is being set lower(65 ish).
I can’t figure out why.
Anyone else have experience with this?
Oli
(Oliver Stenzel)
#2
This sounds like an issue similar to mine:
Maybe you could do the same tests (send commands via console and check logs) and report the results?
