Colored graph support for switch, contact and text items
Hi all,
I am currently setting up some graphs for my items with OpenHAB 3 Pages. I noticed that there is no possibility to make graphs for e.g. switch, contact or text items. It would be nice to make some of these, for example to display a presence (home/away) history.
Homeassistant for example has a nice feature to make such graphs:
(source: Home Assistant | MySensors - Create your own Connected Home Experience)
Is something like this already possible? Or do you think this feature could be added in future?
Thanks for your help :slight_smile:
If you press the “Analyze” button on the configuration page of a switch item it should give you a (full-screen) page of the switch.
For switches (and also for contact items) it is possible to create a chart page like the one in your screenshot, but it requires some additional work:
Create a standard line chart with your switch item
In the chart editor switch to “Code” Tab
In the - component: oh-time-series section replace the line item: xxxx with
        markArea:
          - component: oh-mark-area
              item: xxxx
where “xxxx” is the ID of the switch
or contact item you want to chart. This gives you a full-page chart for one item.
If you want something like in your screenshot, with multiple switches or contacts, it gets a bit more cumbersome: You need to add a grid for each item and in the Configure Grid properties dialog change the top (or bottom) and height properties for each grid so they do not overlap.
(Perhaps somebody will eventually write a nice widget with a repeater to automate this, but so far the only way I know is to do this manually). I use this to get an overview of the presence of the family members over the last two weeks:
There is a more detailed description in this thread: OH3: Charts/Graphs/Plots - #14 by jensflorian
This is not as nice as a Grafana solution, but it does not require the additional installation of InfluxDB and Grafana. However, if you do use Grafana, a (much simpler, IMHO) solution is described here: Grafana InfluxDB - Help with queries and creating graphs and charts - #6 by Fleck
Thanks. This is exactly what I was looking for :+1:
Can you share your code please?
@Fleck could you share your code please?
Sure. I have meanwhile created a UI script to generate the code. I‘ll see if I can create a short tutorial.
Meanwhile, here is the code for a widget which has 5 timelines for 5 switches. The widget looks like this:
This is the widget code:
uid: Widget_Chart_OnlineTimeline
tags:
  - chart
  - widget
  - timeline
props:
  parameters:
    - description: Title
      label: Title
      required: false
      type: TEXT
    - description: Icon on top of the card (only f7 icons (without f7:))
      label: Icon
      required: false
      type: TEXT
  parameterGroups: []
timestamp:
component: f7-card
  key: =Math.random() + items["EspGarageDoor_DeviceStatus"].state.split(" ")[0] + items["Wifilight03_DeviceStatus"].state.split(" ")[0] + items["Wifilight06_DeviceStatus"].state.split(" ")[0] + items["Wifiplug10_DeviceStatus"].state.split(" ")[0] + items["Zigbeeplug01_DeviceStatus"].state.split(" ")[0]
  style:
    background-color: rgba(0,0,0,0)
    box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
    margin-left: 5px
    margin-right: 5px
    noShadow: false
    padding: 0px
slots:
  content:
    - component: f7-block
        style:
          display: flex
          flex-direction: row
          left: 16px
          position: absolute
          top: -5px
      slots:
        default:
          - component: f7-icon
              f7: =props.icon
              style:
                margin-right: 10px
              visible: "=props.icon ? true : false"
          - component: Label
              style:
                font-size: 12px
                margin-top: 0px
              text: "=props.title ? props.title : ''"
  default:
    - component: oh-chart
        options:
          color:
            - rgba(255,0,0,1)
            - rgba(0,255,255,1)
            - rgba(0,255,0,1)
        period: W
      slots:
        grid:
          - component: oh-chart-grid
              bottom: 68.6%
              show: true
              height: 15.4%
              left: 91px
              bottom: 53.2%
              show: true
              height: 15.4%
              left: 91px
              bottom: 37.8%
              show: true
              height: 15.4%
              left: 91px
              bottom: 22.4%
              show: true
              height: 15.4%
              left: 91px
              bottom: 7%
              show: true
              height: 15.4%
              left: 91px
        series:
              gridIndex: 0
              type: line
              xAxisIndex: 0
              yAxisIndex: 0
              service: influxdb
            slots:
              markArea:
                    item: EspGarageDoor_DeviceStatus
              gridIndex: 1
              type: line
              xAxisIndex: 1
              yAxisIndex: 1
              service: influxdb
            slots:
              markArea:
                    item: Wifilight03_DeviceStatus
              gridIndex: 2
              type: line
              xAxisIndex: 2
              yAxisIndex: 2
              service: influxdb
            slots:
              markArea:
                    item: Wifilight06_DeviceStatus
              gridIndex: 3
              type: line
              xAxisIndex: 3
              yAxisIndex: 3
              service: influxdb
            slots:
              markArea:
                    item: Wifiplug10_DeviceStatus
              gridIndex: 4
              type: line
              xAxisIndex: 4
              yAxisIndex: 4
              service: influxdb
            slots:
              markArea:
                    item: Zigbeeplug01_DeviceStatus
        xAxis:
          - component: oh-time-axis
              gridIndex: 0
              splitLine:
                show: true
              axisLabel:
                show: false
              axisLine:
                show: false
              axisTick:
                show: false
              gridIndex: 1
              splitLine:
                show: true
              axisLabel:
                show: false
              axisLine:
                show: false
              axisTick:
                show: false
              gridIndex: 2
              splitLine:
                show: true
              axisLabel:
                show: false
              axisLine:
                show: false
              axisTick:
                show: false
              gridIndex: 3
              splitLine:
                show: true
              axisLabel:
                show: false
              axisLine:
                show: false
              axisTick:
                show: false
              gridIndex: 4
              splitLine:
                show: true
              axisLabel:
                show: true
              axisLine:
                show: true
              axisTick:
                show: true
        yAxis:
          - component: oh-value-axis
              gridIndex: 0
              nameLocation: center
              nameGap: 5
              nameRotate: "0"
              gridIndex: 1
              nameGap: 5
              nameRotate: "0"
              gridIndex: 2
              nameGap: 5
              nameRotate: "0"
              gridIndex: 3
              nameGap: 5
              nameRotate: "0"
              gridIndex: 4
              nameGap: 5
              nameRotate: "0"
I know this is an old thread, but wanted to make this thread aware of a potential new feature for the MainUI. If you have time to try it out, any feedback would be great!
https://community.openhab.org/t/mainui-widget-with-graphical-timeline-of-item-historical-states/163889/5
