Hi guys,
I know there are several similar topics but I still cannot solve my problem. I am using OH3.4 on a Pi4 with ZStick Gen5+. I have a couple of Fibaro FGS223 modules added to my zwave network. Some of them are working fine and for some the log shows some troubles.
2023-09-22 19:41:31.619 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 50: Command received zwave:device:e216f68b3e:node50:switch_binary1 --> ON [OnOffType]
2023-09-22 19:41:31.620 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 50: Command class class COMMAND_CLASS_SWITCH_BINARY for endpoint 1 not found
2023-09-22 19:41:31.620 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 50: No messages returned from converter
2023-09-22 19:41:58.501 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 50: Command received zwave:device:e216f68b3e:node50:switch_binary1 --> OFF [OnOffType]
2023-09-22 19:41:58.502 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 50: Command class class COMMAND_CLASS_SWITCH_BINARY for endpoint 1 not found
2023-09-22 19:41:58.503 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 50: No messages returned from converter
I’ve searched for a suitable solution and found the following:
I’ve then compared the node.xml files from a working node (node_61) and one which is not doing so (Node_50). There are major differences.
network_fc386414__node_50.xml (8.6 KB)
network_fc386414__node_61.xml (34.6 KB)
Would it help to “copy/paste” the working xml file to the one which is not working? Or is it possible to help OH to identify the node in the right way?
Would be glad to get some advice.
Thanks a lot in advance!
Regards,
Matthias
