Just wondering if anyone has had this error before just by sending a device(zwave) a status update?
I have a bunch of simple sends that happen when other events happen and I realized today that none of those events seem to be working. Checking things out I am doing this in a rule :
DiningLights1_StatusModeLED7Colour.sendCommand(3)
Which results in this :
23:27:06.959 [ERROR] [nding.zwave.handler.ZWaveThingHandler] - NODE 95: Command received with no implementation (QuantityType).
I assume your item is a ColorType.
And the system can not distinguish what you try to achieve when setting this value. To properly set a colorType you would need to define the type of the value so the system knows what you like to achieve, e.g. setting it to 3 percent.
Please refer to the documentation on how to properly set this.
It’s not. I’m actually setting the color of the HomeSeer 200 dimmer, which has I think 7 values(0-7). This worked in the past, and worked for a few months but now none of them work.
And I’m sorry, this is the HomeSeer HD-200+'s, I have 26 of them which all do the same thing. I’m simply setting one of the status LED’s on the unit to a color when there is motion in the room. (sort of an indicator that motion was detected).
Check through those threads. I’ve browsed them but didn’t read them thoroughly. I thought I saw this as resolved, but I’m not sure if that involved both a binding update and an update to the device. Actually, it looks like it may have been for temperature. I bet @chris knows.
Yea, that’s for number. I have these items set to Number:Dimensionless, as I don’t know what else I would set them to. I guess I’ll play around in that area and see if I can guess what it’s supposed to be. Maybe Chris knows, that’d be great!
Figured it out, I think. It’s the dimensionless setting. Once I remove that things start working the way they are supposed to again. When I first got these, I didn’t have the option to leave that blank, so I had to pick something. I see now that is changed, so I can just have it be a number with no dimension setting.
Did you install it through PaperUI? If so and with that date, it would be a snapshot. Development is available here and installed by dropping it into the addons directory.
Okay, then certainly snapshot. I would put in the development, but I just don’t have the time to remove and re-add all my things. I have over 100 zwave devices, so that would take a bit.
