Rule for deleting and rediscovering Things
OH2 does not currently have a mechanism for updating Thing types. When a binding update includes new or modified Channel definitions, the Thing needs to be manually deleted and recreated in order to use the new/modified Channel. For most bindings, it is not too cumbersome to do this manually. But when you are using the Zwave binding with ~120 devices, this can be a real headache. Here is an example of how I have automated the deletion, rediscovery, and reconfiguration of my Zwave Things. I run this after every Zwave binding update, in case there was a change to one of my devices. This is also very important to do when migrating to or from the master and dev branches.
CONSIDERATIONS
  • I am currently running OH 2.3 snapshot 1218. This includes a change in ESH that completely crippled the JSONPATH transform. To work around this, I have used jq, which is very handy to have in the toolbox. I have left some of the original lines using JSONPATH as reference for those who do not wish to use jq.
  • This rule is functioning well for me, but I still monitor it closely. Originally, I had some sleeps to slow the process down, but my system seemed to perform well without them so they were removed. I welcome feedback for better approaches to accomplish this task… but it’s working! The one area that may still need some tuning is where I change the temperature scale. Every now and then I was seeing a couple devices where the change did not get set properly, but after the last changes I made to the rule, I haven’t noticed any failures.
  • This is stating the obvious, but if a binding update removes channels, any Items using the old channels will no longer function.
  • Using an outdated Thing type can cause issues. I have had trouble with Leviton dimmers and switches that provide instant status updates, where they just stop reporting. In my case, deleting and rediscovering the Things resolved this.
[EDIT: since the dev binding now supports UoM for temperature, I commented out those lines. I think there were some other changes to clean things up.]
ITEM
Switch Delete_Zwave_Things "Delete Z-Wave Things" <error> (gVirtual,gNetwork) ["Switchable"] {autoupdate="false"}
RULE
// IMPORTS (put these at the top of the rule file)
import java.util.LinkedHashMap
import java.util.List
rule "Delete zwave Things, start discovery, and add all zwave Things from Inbox"
    Item Delete_Zwave_Things received command
    var LinkedHashMap<String,Integer> statusMap = newLinkedHashMap(
        "DeletionSuccess"  -> 0,
        "DeletionFailure"  -> 0,
        "DiscoveryFailure" -> 0,
        "ThingsAdded"      -> 0,
        "ThingsNotAdded"   -> 0//,
        //"TempScaleSuccess" -> 0,
        //"TempScaleFailure" -> 0
    //val String thingResult = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -s --connect-timeout 10 -m 10 -X GET --header \"Accept: application/json\" \"http://localhost:8080/rest/things\"",5000)// get Things
    //val List<String> zwaveThingList = transform("JSONPATH","$..[?(@.UID =~ /zwave:device.*/)].UID",thingResult).replace("[","").replace("]","").replace("\"","").split(",")// filter out everything but zwave Things and convert to List
    logDebug("Rules", "Delete zwave Things: Start")
    var List<String> thingUIDList = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -s --connect-timeout 10 -m 10 -X GET --header \"Accept: application/json\" \"http://localhost:8080/rest/things\" | /usr/bin/jq '.[].UID | select(contains(\"zwave:device\"))'",10000).split("\n")//get List of Things and filter out everything but Zwave device Thing UIDs
    if (!thingUIDList.contains("")) {
        logDebug("Rules", "Delete Zwave Things: {} Zwave Things",thingUIDList.size)
        for (thing : thingUIDList) {// delete Zwave Things
            val String deletionResponse = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -o /dev/null -s -w \"%{http_code}\" --connect-timeout 10 -m 10 -X DELETE --header \"Accept: application/json\" \"http://localhost:8080/rest/things/" + thing + "?force=false\"",10000)//delete Thing
            if (deletionResponse == "200" || deletionResponse == "202") {
                statusMap.put("DeletionSuccess",statusMap.get("DeletionSuccess") + 1)
            else {
                statusMap.put("DeletionFailure",statusMap.get("DeletionFailure") + 1)
            logDebug("Rules", "Delete Zwave Things: Thing deletion: Response=[{}], thing=[{}]",deletionResponse,thing)
    thingUIDList = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -s --connect-timeout 10 -m 10 -X GET --header \"Accept: application/json\" \"http://localhost:8080/rest/things\" | /usr/bin/jq '.[].UID | select(contains(\"zwave:device\"))'",10000).split("\n")//get List of Things and filter out everything but Zwave device Thing UIDs (if deletion was successful, this should be empty)
    if (thingUIDList.size == 1 && thingUIDList.contains("")) {
        logDebug("Rules", "Delete Zwave Things: All Zwave Things were deleted, so starting Zwave Discovery")
        val String discoveryResponse = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -o /dev/null -s -w \"%{http_code}\" --connect-timeout 10 -m 10 -X POST --header \"Content-Type: application/json\" --header \"Accept: text/plain\" \"http://localhost:8080/rest/discovery/bindings/zwave/scan\"",10000)//start discovery
        logDebug("Rules", "Delete Zwave Things: Started Discovery, Response=[{}]",discoveryResponse)
        if (discoveryResponse != "200") {
            statusMap.put("DiscoveryFailure",1)
        Thread::sleep(10000)// rules restart after discovery, but this may help
        val List<String> inboxList = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -s --connect-timeout 10 -m 10 -X GET --header \"Accept: application/json\" \"http://localhost:8080/rest/inbox\" | /usr/bin/jq -r '.[] | {thingUID:(.thingUID | select(contains(\"zwave:device\"))), label:.label} | .[]'",10000).split("\n")//get List of Thing UIDs and labels from Inbox
        logDebug("Rules", "Delete Zwave Things: inboxList.size=[{}]",inboxList.size)
        for (var index = 0 ; index < inboxList.size ; index += 2) {
            val String approvalResponse = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -o /dev/null -s -w \"%{http_code}\" --connect-timeout 10 -m 10 -X POST --header \"Content-Type: text/plain\" --header \"Accept: application/json\" -d \"" + inboxList.get(index + 1) + "\" \"http://localhost:8080/rest/inbox/" + inboxList.get(index) + "/approve\"",10000)//approve Thing in Inbox
            logDebug("Rules", "Delete Zwave Things: Inbox approval: Response=[{}], thing=[{}], label=[{}]",approvalResponse,inboxList.get(index),inboxList.get(index + 1))
            if (approvalResponse == "200") {
                statusMap.put("ThingsAdded",statusMap.get("ThingsAdded") + 1)
            else {
                statusMap.put("ThingsNotAdded",statusMap.get("ThingsNotAdded") + 1)
        thingUIDList = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -s --connect-timeout 10 -m 10 -X GET --header \"Accept: application/json\" \"http://localhost:8080/rest/things\" | /usr/bin/jq -r '.[].UID | select(contains(\"zwave:device\"))'",10000).split("\n")//get List of Things and filter out everything but Zwave device Thing UIDs
        logDebug("Rules", "Delete Zwave Things: thingUIDList.size=[{}]",thingUIDList.size)
        val String scaleCelcius = "\"config_scale\":\"0\""
        val String scaleFahrenheit = "\"config_scale\":\"1\""
        for (var index = 0 ; index < thingUIDList.size ; index++) {
            var String zwaveThing = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -s --connect-timeout 10 -m 10 -X GET --header \"Accept: application/json\" \"localhost:8080/rest/things/" + thingUIDList.get(index) + "\"",10000)//get Thing
            if (zwaveThing.contains(scaleCelcius)) {
                zwaveThing = zwaveThing.replace(scaleCelcius,scaleFahrenheit).replace("\"","\\\"")
                val String updateResponse = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -o /dev/null -s -w \"%{http_code}\" --connect-timeout 10 -m 10 -X PUT --header \"Content-Type: application/json\" --header \"Accept: application/json\" -d \"" + zwaveThing + "\" \"http://localhost:8080/rest/things/" + thingUIDList.get(index) + "\"",10000)//update temperature scale
                logDebug("Rules", "Delete Zwave Things: Configured temperature scale: Response=[{}], thing=[{}]",updateResponse,thingUIDList.get(index))
                if (updateResponse == "200") {
                    statusMap.put("TempScaleSuccess",statusMap.get("TempScaleSuccess") + 1)
                else {
                    statusMap.put("TempScaleFailure",statusMap.get("TempScaleFailure") + 1)
                //Thread::sleep(200)
    else {
        logDebug("Rules", "Delete zwave Things: {} zwave Things were not deleted, so did not start zwave Discovery. thingUIDList=[{}]",thingUIDList.size,thingUIDList)
    logDebug("Rules", "Delete zwave Things: End: {}",statusMap.toString)
    //val String thingResultFinal = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -s --connect-timeout 10 -m 10 -X GET --header \"Accept: application/json\" \"http://localhost:8080/rest/things\"",5000)// get Things again
    //val List<String> zwaveThingListFinal = transform("JSONPATH","$..[?(@.UID =~ /zwave:device.*/)].UID",thingResultFinal).replace("[","").replace("]","").replace("\"","").split(",")// filter out everything but zwave Things and convert to List
    //if (zwaveThingListFinal.get(0) == "") {// if deletion of all zwave Things was successful, start zwave discovery
        //logDebug("Rules", "Delete zwave Things: All zwave Things were deleted, so starting zwave Discovery")
        //executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -s --connect-timeout 10 -m 10 -X POST --header \"Content-Type: application/json\" --header \"Accept: text/plain\" \"http://localhost:8080/rest/discovery/bindings/zwave/scan\"",5000)//start discovery
    //else {
        //logDebug("Rules", "Delete zwave Things: {} zwave Things were not deleted, so did not start zwave Discovery [{}]",zwaveThingListFinal.size,zwaveThingListFinal)
Here is the Jython version…
https://github.com/OH-Jython-Scripters/openhab2-jython/blob/master/Community/Delete%20and%20Rediscover%20Z-Wave%20Things/automation/jsr223/community/deleteZwaveThings.py
I made a few fixes and some changes to the logging. Specifically, the deletion response can be 202, which is also a success. And I changed to a LinkedHashMap to preserve the order of the status messages.
Oddly, the rule file seems to be getting reloaded while this rule is running. I’m not sure if it is the deletion or discovery causing triggering the reload. The rule seems to complete most of the time, but I have also seen it error after the rule file is being reloaded. I need to look up if this is expected behavior (currently using 2.2.0 snapshot 1224).
I just had a short overlook regarding jsontransform and the reason you are using jq. what is the state with official 2.3 stable? because your script wont work with any other OS than linux. Like me I’m running OH on Windows.
Severely crippled… at least when trying to use it with indefinite paths. A quick search for jq on Windows came up with some Windows binaries for it… Redirecting to jqlang.github.io. But you could also use a JS or possibly REGEX transform too.
I try to rewrite your script for windows. first executecommandline I successfully got rewriten. but here I dont know how linux does handle this and what the output is:
-s -m 10 -X GET --header \"Accept: application/json\" \"http://localhost:8083/rest/inbox\" | /usr/bin/jq -r '.[] | {thingUID:(.thingUID | select(contains(\"zwave:device\"))), label:.label}
especially its regarding
can you explain this part a bit more?
some parts before I got already successful rewritten like
powershell.exe d:\Programme\curl\curl.exe -s -m 10 -X GET --header 'Accept: application/json' 'http://localhost:8083/rest/things' | D:\Programme\jq\jq-win64.exe .[].UID | where {$_ -like '*zwave*'}
but now I’m hanging a bit because I dont know what linux is doing with the part you have done
Everything in the single quotes is being sent to jq. Have you tried it just like it is? This is returning a string of UIDs for just the zwave devices, separated by newlines. Like…
"zwave:device:55555:node214"
"zwave:device:55555:node213"
"zwave:device:55555:node212"
"zwave:device:55555:node183"
"zwave:device:55555:node7"
Specifically, this does not include the controller, which would be something like zwave:serial_zstick:55555. The rule then splits this string on newlines and converts it to a list. Have you tried passing the same arguments to jq?
My wife was asking what I was doing and showed me this too, for use in Powershell (no curl or jq needed!) which will return the same…
try {
$jsonRequest = Invoke-RestMethod -Uri "http://<oh server or localhost>:8080/rest/things"
$jsonRequest.UID | where {$_ -like 'zwave:device*'}
} catch {
    Write-Host "Something went wrong"
I just realized you were at the Inbox search, so this will need some modification for that piece.
At the Inbox search, my script returns this…
zwave:device:55555:node38
Z-Wave Node 038: VRMX1 Scene Capable Push On/Off Dimmer
zwave:device:55555:node37
Z-Wave Node 037: VRMX1 Scene Capable Push On/Off Dimmer
zwave:device:55555:node39
Z-Wave Node 039: VRMX1 Scene Capable Push On/Off Dimmer]
I couldn’t do it with jq without the labels being in there too. The Powershell version should get just what you need, just modify the loop where it’s iterating over the list.
Hi Scott,
good to know your hints for powershell (especially invoke-restmethod :slight_smile: ).
But especially for the inbox I dont know what you did in your script and what results are of
when you can show me a finished result of this, I’m pretty sure that I’ll find a way to solve it with powershell
I was still editing my post… check the updates.
Is there a typo in your items definition with the ` character near the closing } of autoupdate?
I have known this issue for a long time. Thanks for creating a discussion thread.
Yes, but not any more! Thank you!
Actually I have been using a hack to solve this issue. You can copy existing thing’s config and props to a TreeMap (for compare purpose), check config change on every initialize(), if config changed - serialize it using StorageService to some known storage file. And then delete the thing or ask user to delete it when you upgrade to the binding version that includes new channels. During discovery, you can look at the file and populate the result with earlier config. Instead of discovery I usually send a deleted thing back to Inbox after 10 seconds, you can use handleThingRemoval() callback in your thing handler or gateway or factory.
This way you don’t loose the thing config. Saves a lot of typing. You need to serialize Thing Label in special propery in TreeMap, something like -label-. Because label is not part of thing config or thing props.
All my things have a custom names, is it possible to save the names, so the script names the things what they was before
You should be able to store the labels to a HashMap (UID → ā€œThing labelā€} while iterating over the Z-Wave Things. After they are rediscovered, iterate over them again and configure their labels to match what they were before. I have a lot of things up in the air at the moment, and I’ve gotten pretty good at guessing the right Thing, so I doubt I would ever get around to putting this together. But it’s all there for you in the rule and REST API.
Dezito,
I have all custom names too. I don’t understand mooist of what is written in the last few posts, so I am not going to rewrite this rule.
Did you by any chance give it a try?
No not yet i am thinking of making something that uses rest api instead
I thought it would be a problem using this script and changing the names of things. But last weekend I had to change all my things and realised that items are linked to chanels which don’t change. So all my things changed names, and everything still works!
A ton of errors have been thrown by the above rule. Here is my log
2019-03-09 15:46:04.973 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
	at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.Server.handle(Server.java:531) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: org.eclipse.jetty.io.EofException
	at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:286) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:429) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:323) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:380) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:804) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:538) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:795) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:846) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:240) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:216) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:515) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:325) ~[?:?]
	at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:229) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:299) ~[?:?]
	at org.glassfish.jersey.message.internal.ReaderWriter.writeTo(ReaderWriter.java:116) ~[?:?]
	at org.glassfish.jersey.message.internal.AbstractMessageReaderWriterProvider.writeTo(AbstractMessageReaderWriterProvider.java:79) ~[?:?]
	at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:105) ~[?:?]
	at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:60) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[?:?]
	at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
	at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
	... 53 more
Caused by: java.io.IOException: Die Verbindung wurde vom Kommunikationspartner zurückgesetzt
	at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
	at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
	at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:?]
	at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:?]
	at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:266) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	... 53 more
2019-03-09 15:46:05.252 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
	... 53 more
	at
	at ...
	... 53 more
Which version of OH, and which rule (DSL or Jython)? Are there other rule related errors?
What log entries are coming from the rule? These will help troubleshoot where in the rule this is occurring.
I am on OH 2.4 and its the dsl rule. Alle errors you see in the log are coming from the rule
