Compass card
Widget to display wind speed and direction or some other “directional” data. Basic usage:
 - component: widget:compass_card
      title: Wind
      direction: gOutdoor_WeatherStation_WindDirection
      value: gOutdoor_WeatherStation_WindSpeed
Screenshots
Changelog
Version 0.1
  • initial release
Resources
uid: compass_card
tags: []
props:
  parameters:
    - label: title
      required: false
      type: TEXT
    - context: item
      description: Direction in deg
      label: Direction
      required: true
      type: TEXT
    - context: item
      description: Value
      label: Value
      required: false
      type: TEXT
    - default: "180"
      label: Rotate arrow deg
      required: false
      type: INTEGER
      advanced: true
    - default: if:mdi:arrow-compass
      label: Arrow image
      required: false
      type: TEXT
      advanced: true
    - default: red
      label: Arrow color
      required: false
      type: TEXT
      advanced: true
    - default: 44px
      label: Arrow height
      required: false
      type: TEXT
      advanced: true
    - default: 4px
      label: Circle width
      required: false
      type: TEXT
      advanced: true
    - default: "#34e5eb"
      label: Circle color
      required: false
      type: TEXT
      advanced: true
    - default: "true"
      label: Show direction text
      required: false
      type: BOOLEAN
      advanced: true
    - label: Background image url
      required: false
      type: TEXT
      advanced: true
    - default: 40%
      label: Background image width
      required: false
      type: TEXT
      advanced: true
  parameterGroups: []
timestamp: Jan 21, 2023, 7:45:58 AM
component: f7-card
  title: =props.title
slots:
  default:
    - component: f7-card-content
      config: {}
      slots:
        default:
          - component: div
              style:
                margin: 14px auto
                border-radius: 50%
                border-style: solid
                border-width: =props.circleWidth
                border-color: =props.circleColor
                aspect-ratio: 1/1
                width: 60%
            slots:
              default:
                - component: oh-link
                    action: analyzer
                    actionAnalyzerItems:
                      - =props.value
                    style:
                      border-radius: 50%
                      aspect-ratio: 1/1
                      position: absolute
                      width: 60%
                - component: oh-image
                    style:
                      position: absolute
                      top: 50%
                      left: 50%
                      transform: translate(-50%, -50%)
                    url: =props.backgroundImageUrl
                    visible: =props.backgroundImageUrl
                    width: =props.backgroundImageWidth
                - component: Label
                    style:
                      font-size: 28px
                      left: 50%
                      position: absolute
                      top: 36%
                    text: =["N","NNE","NE","ENE","E","ESE","SE","SSE","S","SSW","SW","WSW","W","WNW","NW","NNW", "N"][Math.round((Number.parseFloat(@props.direction) % 360) / 22.5)]
                    visible: =props.showDirectionText
                - component: Label
                    style:
                      color: var(--f7-list-item-after-text-color)
                      font-size: 18px
                      font-weight: var(--f7-list-item-after-font-weight)
                      left: 50%
                      line-height: var(--f7-list-item-after-line-height)
                      position: absolute
                      top: 55%
                    text: =@props.value
                    visible: =@props.value != "-"
                - component: Label
                    style:
                      font-size: 16px
                      left: 50%
                      position: absolute
                      top: 64%
                      transform: translate(-50%, 50%)
                    text: =@props.direction
                - component: div
                    style:
                      height: 100%
                      transform: ="rotate(" + Number.parseFloat(@props.direction) + "deg)"
                  slots:
                    default:
                      - component: oh-icon
                          color: =props.arrowColor
                          height: =props.arrowHeight
                          icon: =props.arrowImage
                          style:
                            transform: ="translate(0, -50%) rotate(" + Number.parseInt(props.rotateArrow) +"deg)"
                            width: 100%
Learning alote with the code you posted, many thanks. Continuing on that path I tried to have 2 icons traveling along the circle, solar tracking head pointing at the sun. Maybe you can point me on the right path to have the sun position. So far, i have not found a way to “transform” to each icon the rotation value. Any suggestion would be cool :slight_smile:
                - component: div
                    style:
                      transform: = ("rotate(" + Number.parseFloat(@props.trk_az) + "deg)") &&
                        ("rotate(" + Number.parseFloat(@props.sun_az) + "deg)")
                      height: 100%
                  slots:
                    default:
                          style:
                            transform: ="translate(0%, 10%) rotate(" + Number.parseInt(props.rotateArrow)
                              +"deg)"
                            width: 100%
                          color: =props.sunColor
                          height: =props.sunHeight
                          icon: =props.sunImage
                          style:
                            transform: ="translate(0%, -220%)"
                            width: 100%
your code goes here
