Configurable rule that has the cron specification parameterized
  • Platform information:
    • Hardware: RPI3B
    • OS: OPENHABIAN
    • openHAB version: openHAB 2.5.10-1
  • Issue of the topic:
    Please let me know how I can use a variable inside a CRON expresion. I want to have the option to configure the starting time and ending time from the user interface perspective.
    So, for example a have this rule:
rule “All lamps on”
when Time cron “0 0 6 ? * MON-FRI *”
then all_lights_on_on.sendCommand(“ON”)
logInfo(“info”,“all lights on rule fired”)
And I want to modify the value 6 - (rule to be considered from 6 AM).
Until now I found this post / solution that is from '15. Maybe do you know other approach / workaround:
Thank you in advance
You cannot.
Thank you for prompt answer!
With the Jruby scripting addon, you can!
dynamic_rule.tems:
String Cron_Expr "Cron expression for dynamic rule"
dynamic_rule.rb
require 'openhab'
def dynamic_rule(name, cron_expr, &block)
  remove_rule(name)
  rule name do
    cron cron_expr
    run block
def remove_rule(name)
  rules = $se.get('ruleRegistry')
  rules.get_all.select { |rule| rule.name.match?(name) }.each { |rule| rules.remove(rule.uid) }
rule 'Update cron rule' do
  changed Cron_Expr
  run do
    dynamic_rule('Dynamic cron rule', Cron_Expr) do
      # Rule body here
Update the Cron_Expr Item with a valid cron expression and the rule will be recreated with the new value.
Just make sure you use unique names for your rules, otherwise you might delete the wrong one.
This is brilliant!
