LaurentiuB
(Laurentiu B)
October 20, 2020, 8:48pm
#21
Ok, let’s do a test
Items
Number TestItem
Sitemap
Frame label=“Test” icon=“settings” {
Slider item=TestItem label=“TestItem”
And the logs
23:45:56.131 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘TestItem’ received command 30
23:45:56.140 [INFO ] [smarthome.event.ItemStateChangedEvent] - TestItem changed from 0 to 30
You should have the same results if you copy this configuration.
And if that doesn’t work - restart openHAB completely and try again!
What is this stray “]” about?
When you are saving your things, items and sitemaps, are you checking the logs to make sure that there are no errors, and that they have loaded correctly?
mohamed
(abou radia )
October 20, 2020, 9:04pm
#25
i just copy and paste the commands
but it seems to have a problem in sitemap file . this what i have obtained
mohamed
(abou radia )
October 20, 2020, 9:13pm
#27
for this fault
i modified it , and this what i have obtained
mohamed
(abou radia )
October 20, 2020, 9:15pm
#28
i modified the qoutes and this is what i have obtained :
I think a big problem in this thread is that you’re providing screenshots which are difficult to analyse, and cut off some information. It also prevents copy/pasting for testing purposes.
Please use code fences:
like this
LaurentiuB
(Laurentiu B)
October 20, 2020, 9:18pm
#30
You should have only one bridge definition.
mohamed
(abou radia )
October 20, 2020, 9:26pm
#31
//This is the Things
Bridge mqtt:broker:MosquittoMqttBroker “Mosquitto MQTT Broker” [host=“192.168.1.5”, secure=false]
// Switch Mohamed Light
Thing mqtt:topic:sonoffbasicmo “sonoffbasicmo” {
Channels:
Type switch : switch “Power Switch” [
stateTopic=“stat/sonoffbasicmo/POWER”,
commandTopic=“cmnd/sonoffbasicmo/POWER”,
on=“ON”,
off=“OFF”
Type string : reachable “Reachable” [
stateTopic = “tele/sonoffbasicmo/LWT”
// fire sensor
Thing mqtt:topic:mofiresensor "mofiresensor" {
Channels:
Type string : string "string1" [
stateTopic="mofiresensor"
// blinds system
Thing topic Mblinds "Mblinds" {
Channels:
Type number:Rollershutter1 "Rollershutter" [
commandTopic="Mblinds"
like that ?
LaurentiuB
(Laurentiu B)
#32
Mqtt should be like
Bridge
Thing topic
Channels
Type
Type
Thing topic
Channels
Type
Type
LaurentiuB
(Laurentiu B)
October 20, 2020, 9:28pm
#33
It looks ok, but It’s hard to follow all the brackets.
LaurentiuB
(Laurentiu B)
October 20, 2020, 9:35pm
#34
Now try with
Items
Number TestItem { channel="mqtt:topic:Mblinds:Rollershutter1" }
and see what happens
mohamed
(abou radia )
October 20, 2020, 9:39pm
#35
you mean add the part { channel="… } to the test item i have made , right ?
mohamed
(abou radia )
October 20, 2020, 9:45pm
#37
i made it
mohamed
(abou radia )
October 20, 2020, 9:50pm
#39
but there is is something wrong .
look at that
i move the test item slider , but it returns to the same value (62) !
also the servo motor still not moving
LaurentiuB
(Laurentiu B)
October 20, 2020, 9:56pm
#40
Is there other way you can post to that topic? I suspect that the “slider” is getting the value from the mqtt channel not sending to it.
