Hi, I used the binding since yesterday. It works fine for my VW Arteon SB (2021)! Only the control of the preheater or climate is creating an error.
[ar.internal.handler.ThingBaseHandler] - WVWxxxxxxxxxxxxxx: Status from service rheating_v1.P_QSTOPACT: API call failed POST https://fal-3a.prd.eu.dp.vwg-connect.com/fs-car/bs/rs/v1/VW/DE/vehicles/WVWxxxxxxxxxxxxxx/climater/actions (HTTP 400 Bad Request), result = {"error":{"errorCode":"gw.error.parameter","description":"Disallowed query parameters"}}
⊠and donât forget that the â#lastUpdateâ channel/item will show a new value only if any of the other channels got updated values, not every time when a poll has been made.
They wrote they decided preemptively, following some worldwide jurisdiction which considered primary users not being assisted well enough in informing 3rd party or guest drivers on such privacy concern. The added that they might consider bringing such service back in case they have a better idea how to sort this out⊠(sure)
Hi Markus,
great job and improvements of this Binding. Iâm looking forward to get my ID.3 soon and share my experience with this binding here.
Therefore my ID.Charger Pro is installed, but I can not connect it.
What is the correct Identifier of ID.Charger (because it has no VIN)?
Must it be connect to local WiFi, or is the cennection by LTE enough?
The ID.Charger Pro needs to be connected to WiFi or Ethernet. Then you need to add it in the We Connect ID. App (not We Cpnnect). Add a thing in the binding an enter your credentials (Volkswagen ID). The binding will then pull all wallboxes registered to the account and adds things in the inbox.
thx, then I have todo the wifi connection, tomorrow. I thought the LTE connection and registration in WeConnectID App is enough.
30 min later: Now I was outside (fucking cold :-)) The Wallbox is connected to WiFi, registered in WeConnectID App. But no connection possible;
2021-12-02 19:44:54.676 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'connectedcar:wcwallbox:ID-ChargerPro' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2021-12-02 19:44:54.688 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'connectedcar:wcwallbox:ID-ChargerPro' changed from INITIALIZING to UNKNOWN: Initializing
2021-12-02 19:44:57.690 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'connectedcar:wcwallbox:ID-ChargerPro' changed from UNKNOWN: Initializing to OFFLINE (BRIDGE_UNINITIALIZED): Account Thing is not initialized!
Just to clarify, what you meen with credentials? I stored my Volkswagen ID account (Mail Adress) in the field âIdentification Numberâ of the new thing. There is no password field, correct?
For my VW car I have to set up the volkswagen bridge with UserID and password. Then I can create for every car a spearte thing which is connect to this bridget.
When adding the ID.Charger thing (connectedcar:wcwallbox) there is only the âidentification numberâ but no passwort.
Question: is the wcwallbox an own bridge or will this thing have to be connected to volkswagen bridge.
