Also, when looking at the docs, this and also the maxcurrent values are read only. But I also tried to set the current to i.e. 5 Amps, but this has no effect.
The should indeed be a channel called “charge” that should be able to be switched. Maybe you should post a screenshot of your visible channels (including advanced)?
Do other control channels work for you? For example the channel “climater”
For me the “maxCurrent” is a selection dropdown in the newest version that also works.
(I have a VW Passat GTE)
I will check if the climater control works later, because my car isn‘t sufficiently charged right now. But if I remember correctly, then the „normal“ VW cars use a different part of the binding compared to the ID cars. So maybe that is the reason why those things are not there or not working.
Another new Enyaq here, and I was looking forward to setting up this binding almost as much as I was looking forward to getting the car. Sadly, I am running into the same issues as so many others: first I got the thing online, but got only NULL values. Now, more recently, the bridge doesn’t even go online any longer.
I’m getting this in the trace logs when I enable the bridge (after a lot of other stuff):
last message I got from my eGolf was on 12.02.2022, 10:01.
Before, it worked perfectly since september last year, with one break and similar symptoms as now: the bridge suddenly went offline. But last time it didn’t stay offline that long!
can confirm here as well… Volkswagen ID. Account (WeConnect) bridge error since 12-2
I did notice when logging in to the VW app I needed to login again and that it asked for some new permissions (acces to the driver licence info etc). Dunno if that is causing the issue?
not working here since 14-2… for WeConnect and WeCharge, both bridges offline with API error.
I assume problem is on VW side - when logging on to myVolkswagen the whole car is reported to have mobile online services disabled (whereas in WeConnect ID App on mobile phone everything is working and the car is online!)
It seems, that VW and Audi have actived a new feature which requires a “Release Consens” for providing data to third-party applications (like openHAB) ???
Binding is dead for the ENYAQ now, offline both bridge and thing. I guess the binding needs a complete rework. Unfortunately @markus7017 is not responding anymore… kind of sad cause the binding really rocks (if it works)!
Im still here, but still have no time to work on this. Is there someone who wants to help on the code side?
I expect it’s all about authorizing the account.
VW, Audi, Skoda, Enyaq - all of them share the basic implementation. If VW makes a change all of them are affected.
Hi @markus7017 , great to hear you again :).
I offer my help and time, but I don’t have much experience in programming bindings. I have good Python and C++ knowledge, rather than html or Java. However, programmed my house in Java so it’s not too bad :). Happy to help where I can.
FYI I also have an installation of Home Assistant and there I have a integration to “Volkswagen We Connect” that is working fine. Perhaps it would be possible to get some ideas from that code.
It can be found at github
