The old version worked, but did not correctly show the status of the washing machine. I installed a new one and now it doesnât connect. How do I enable debugging mode?
log
2023-09-22 17:45:03.151 [ERROR] [nding.lgthinq.internal.api.RestUtils] - ExecutionException occurred during POST execution: javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:732) ~[?:?]
at org.openhab.binding.lgthinq.internal.api.RestUtils.postCall(RestUtils.java:170) ~[?:?]
at org.openhab.binding.lgthinq.internal.api.RestUtils.postCall(RestUtils.java:145) ~[?:?]
at org.openhab.binding.lgthinq.internal.api.OauthLgEmpAuthenticator.loginUser(OauthLgEmpAuthenticator.java:219) ~[?:?]
at org.openhab.binding.lgthinq.internal.api.TokenManager.oauthFirstRegistration(TokenManager.java:104) ~[?:?]
at org.openhab.binding.lgthinq.internal.handler.LGThinQBridgeHandler$PollingRunnable.run(LGThinQBridgeHandler.java:125) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
at java.lang.Thread.run(Thread.java:833) ~[?:?]
Caused by: javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
at sun.security.ssl.Alert.createSSLException(Alert.java:131) ~[?:?]
at sun.security.ssl.Alert.createSSLException(Alert.java:117) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:365) ~[?:?]
at sun.security.ssl.Alert$AlertConsumer.consume(Alert.java:293) ~[?:?]
at sun.security.ssl.TransportContext.dispatch(TransportContext.java:204) ~[?:?]
at sun.security.ssl.SSLTransport.decode(SSLTransport.java:172) ~[?:?]
at sun.security.ssl.SSLEngineImpl.decode(SSLEngineImpl.java:736) ~[?:?]
at sun.security.ssl.SSLEngineImpl.readRecord(SSLEngineImpl.java:691) ~[?:?]
at sun.security.ssl.SSLEngineImpl.unwrap(SSLEngineImpl.java:506) ~[?:?]
at sun.security.ssl.SSLEngineImpl.unwrap(SSLEngineImpl.java:482) ~[?:?]
at javax.net.ssl.SSLEngine.unwrap(SSLEngine.java:679) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.unwrap(SslConnection.java:429) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:718) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:168) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:80) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:172) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) ~[?:?]
Update the binding with 4.1.0 version I left in my repo. Then, send me again the log generated aftger trying to enable the bridge. Some more information will come up to help me undertand better the situation.
If do not delete the bridge and replace the file.
Log:
2023-09-23 07:23:52.680 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.lgthinq-4.1.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.lgthinq [329]
Unresolved requirement: Import-Package: javax.measure; version="[2.2.0,3.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) ~[?:?]
Looks like you guys are using the binding with incompatible version of OH. Since the binding is a WIP, I work with the SNAPSHOT trunk compatible with the lastest release of OH4.
That correspond to openHAB 4.1.0.M1
Please, verify if you guys are playing with the same milestone and if not, upgrade it. If you need some instruction in how to do it, let me know.
Youâre right @nemer. I tried to use 4.1 snapshot on 4.0.3. I downloaded and installed the latest 4.0 version of the binding and I can see that you added the dishwasher thing. I tried it (both with scan and manualli adding thing) but it seems itâs not workingâŠ
2023-09-23 16:10:16.590 [ERROR] [ng.lgthinq.internal.api.TokenManager] - Error logging with gateway: LGThinqGateway{empBaseUri='https://ru.emp.lgsmartplatform.com', loginBaseUri='https://ru.m.lgaccount.com/spx', apiRootV1='https://ruic.lgthinq.com:46030/api', apiRootV2='https://ruic-service.lgthinq.com:46030/v1', authBase='https://ru.m.lgaccount.com', language='RU', country='RU', username='', password='', alternativeEmpServer='', accountVersion=0}
2023-09-23 16:10:17.680 [ERROR] [nding.lgthinq.internal.api.RestUtils] - ExecutionException occurred during POST execution: javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
at org.openhab.binding.lgthinq.internal.api.TokenManager.oauthFirstRegistration(TokenManager.java:108) ~[?:?]
... 1 more
2023-09-23 16:10:17.699 [ERROR] [ng.lgthinq.internal.api.TokenManager] - Error logging with gateway: LGThinqGateway{empBaseUri='https://ru.emp.lgsmartplatform.com', loginBaseUri='https://ru.m.lgaccount.com/spx', apiRootV1='https://ruic.lgthinq.com:46030/api', apiRootV2='https://ruic-service.lgthinq.com:46030/v1', authBase='https://ru.m.lgaccount.com', language='RU', country='RU', username='', password='', alternativeEmpServer='', accountVersion=0}
Hi, I have a LG Therma V Monoblok HM 163M U33 air/water heat pump. I am using LG ThinQ app. but I am not able to see energy consumption on the graph . Is it possible that my heat pump does not support this option if yes, is there any way i can add something additional to it? Thank you!
We donât give support to LG ThinQ App. You can ask to LGâs support to see if your device has the energy consumption feature and how to see it in the App.
I have some problem with the ver1 AC in my home. May be the LG API changed?
2024-03-12 18:39:24.129 [ERROR] [ices.LGThinQAbstractApiClientService] - Error reading resource from URI: https://eic.lgthinq.com:46030/api/webContents/modelJSON?modelName=modelJSON_401&countryCode=KR&contentsId=d27c0210-7149-11d3-80b1-a06faae546f9&authKey=thinq
java.net.SocketException: Unexpected end of file from server
at sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:954) ~[?:?]
at sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:761) ~[?:?]
at sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:951) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1688) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1589) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:224) ~[?:?]
at java.net.URL.openStream(URL.java:1161) ~[?:?]
at org.openhab.binding.lgthinq.lgservices.LGThinQAbstractApiClientService.loadDeviceCapability(LGThinQAbstractApiClientService.java:118) [bundleFile:?]
at org.openhab.binding.lgthinq.lgservices.LGThinQAbstractApiClientService.getCapability(LGThinQAbstractApiClientService.java:268) [bundleFile:?]
at org.openhab.binding.lgthinq.internal.handler.LGThinQAbstractDeviceHandler.getCapabilities(LGThinQAbstractDeviceHandler.java:271) [bundleFile:?]
at org.openhab.binding.lgthinq.internal.handler.LGThinQAbstractDeviceHandler.updateThingStateFromLG(LGThinQAbstractDeviceHandler.java:465) [bundleFile:?]
at org.openhab.binding.lgthinq.internal.handler.LGThinQAbstractDeviceHandler$UpdateThingStateFromLG.run(LGThinQAbstractDeviceHandler.java:458) [bundleFile:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
And then:
2024-03-12 18:39:24.129 [ERROR] [handler.LGThinQAirConditionerHandler] - Error updating thing Nappali/d27c0210-7149-11d3-80b1-a06faae546f9 from LG API. Thing goes OFFLINE until next retry: Error parsing capability registry
org.openhab.binding.lgthinq.internal.errors.LGThinqApiException: Error parsing capability registry
at org.openhab.binding.lgthinq.lgservices.LGThinQAbstractApiClientService.getCapability(LGThinQAbstractApiClientService.java:274) ~[bundleFile:?]
at org.openhab.binding.lgthinq.internal.handler.LGThinQAbstractDeviceHandler.getCapabilities(LGThinQAbstractDeviceHandler.java:271) ~[bundleFile:?]
Caused by: org.openhab.binding.lgthinq.internal.errors.LGThinqApiException: Error reading IO interface
at org.openhab.binding.lgthinq.lgservices.LGThinQAbstractApiClientService.loadDeviceCapability(LGThinQAbstractApiClientService.java:124) ~[bundleFile:?]
at org.openhab.binding.lgthinq.lgservices.LGThinQAbstractApiClientService.getCapability(LGThinQAbstractApiClientService.java:268) ~[bundleFile:?]
... 9 more
Caused by: java.net.SocketException: Unexpected end of file from server
at org.openhab.binding.lgthinq.lgservices.LGThinQAbstractApiClientService.loadDeviceCapability(LGThinQAbstractApiClientService.java:118) ~[bundleFile:?]
... 9 more
Something about WorkId not present:
2024-03-12 19:42:25.832 [ERROR] [handler.LGThinQAirConditionerHandler] - Error updating thing GarĂĄzs/d27bb3f0-7149-11d3-80af-a06faae627a8 from LG API. Thing goes OFFLINE until next retry: Error starting device monitor in LG API for the device:d27bb3f0-7149-11d3-80af-a06faae627a8
org.openhab.binding.lgthinq.internal.errors.LGThinqApiException: Error starting device monitor in LG API for the device:d27bb3f0-7149-11d3-80af-a06faae627a8
at org.openhab.binding.lgthinq.internal.handler.LGThinQAbstractDeviceHandler.getSnapshotDeviceAdapter(LGThinQAbstractDeviceHandler.java:667) ~[bundleFile:?]
Caused by: java.lang.NullPointerException: Unexpected StartMonitor json result. Node 'workId' not present
at java.util.Objects.requireNonNull(Objects.java:235) ~[?:?]
at org.openhab.binding.lgthinq.lgservices.LGThinQAbstractApiClientService.startMonitor(LGThinQAbstractApiClientService.java:433) ~[bundleFile:?]
at org.openhab.binding.lgthinq.internal.handler.LGThinQAbstractDeviceHandler.getSnapshotDeviceAdapter(LGThinQAbstractDeviceHandler.java:656) ~[bundleFile:?]
... 8 more
My ver2 devices are working as expected. All devices are correct in Thinq App.
I donât think the API v1 has been changed because if so, itâs break previous version of the LG Thinq App and the mining of the API versioning itself. If they changes the API, then the changes come in a new version, not in some current released one.
I have V1 & V2 devices and for me, there are no problems. But, LG have regional APIâs serving the world and bugs/instabilities happens regionally.
Other point is the API V1 donât work properly when you have more then one source (LG Thinq APP & This Bingind) consulting the devices status at the same time and may cause unexpected behavior in the binding because the binding doesnât handle this case of racing.
Then, I suggest you to:
Stop (hardly) the LG App
wait 10 minutes
Stop the AC Thing and the Bridge in the sequence
Restart the Bridge and the AC Thing.
See if the problem persist or is fixed.
Just to Clarify the error, this Exception occurs when the server open the connection and stop in the sequence without sending any payload. This is most likely a bug in the server or network traffic problems (firewall, router, etc).
