Did that too and no cigar In many posts I read to delete that one since it gets rebuild anyway. Mine indeed got rebuild too. Not everything was in it because I guess some ‘features’ are unable to install
I had not heard of is getting rebuilt.
If that is the case shut down OpenHAB and edit the file to remove the probleM addons. Restart OpenHAB and then reinstall those addons.
That’s the problem. They are kinda ‘basic’ stuff like openhab-ui-basic, openhab-ui-classic…They get added when I select Expert mode in the start screen (which you get once you delete the config)
The part after the dot is config not cfg. Some people have posted their file contents here for advice.
EDIT I do not log in to my openHAB install much but here are my files. /etc/openhab/services/addons.cfg
# The installation package of this openHAB instance
# Note: This is only regarded at the VERY FIRST START of openHAB
# Note: If you want to specify your add-ons yourself through entries below, set
the package to "minimal"
# as otherwise your definition might be in conflict with what the installation p
ackage defines.
# Optional. If not set, the dashboard (https://<yourserver>:8080/) will ask you
to choose a package.
# Valid options:
# - minimal : Installation only with dashboard, but no UIs or other add-ons.
Use this for custom setups.
# - simple : Setup for using openHAB purely through UIs - you need to expect
MANY constraints in functionality!
# - standard : Default setup for normal users, best for textual setup
# - expert : Setup for expert users, especially for people migrating from op
enHAB 1.x
# - demo : A demo setup which includes UIs, a few bindings, config files e
tc.
# See https://www.openhab.org/docs/configuration/packages.html for a detailed ex
planation of these packages.
#package = minimal
# Access Remote Add-on Repository
# Defines whether the remote openHAB add-on repository should be used for browsi
ng and installing add-ons.
# This not only makes latest snapshots of add-ons available, it is also required
for the installation of
# any legacy 1.x add-on. (default is true)
#remote = true
# Include legacy 1.x bindings. If set to true, it also allows the installation o
f 1.x bindings for which there is
# already a 2.x version available (requires remote repo access, see above). (def
ault is false)
#legacy = true
# A comma-separated list of bindings to install (e.g. "binding = sonos,knx,zwave
#binding =
# A comma-separated list of UIs to install (e.g. "ui = basic,paper")
#ui =
# A comma-separated list of persistence services to install (e.g. "persistence =
rrd4j,jpa")
#persistence =
# A comma-separated list of actions to install (e.g. "action = mail,pushover")
#action =
# A comma-separated list of transformation services to install (e.g. "transforma
tion = map,jsonpath")
#transformation =
# A comma-separated list of voice services to install (e.g. "voice = marytts,fre
etts")
#voice =
# A comma-separated list of miscellaneous services to install (e.g. "misc = myop
enhab")
#misc =
Yes, removing the dashboard did it. I still get the error line but everything started. I will monitor closely but still, I do expect a bit more ‘stable-ness’ from the latest stable release
Thanks Bruce for helping!
