since many many months I use “Thread::sleep(180000)” in one of my rules.
This worked find until now … but in one of the last builds there seems to be a different behaviour.
Now the whole rule engine seems to “sleep” for that time. Before it was only that single rule that executed the sleep (even if 2 or more rules where in 1 file it affected only that specific rule and not all of them).
will try that…
but I have a thread sleep for 3min in one specific rule… the system stops all rules for exactly 3 minutes… so I’m 99,9999% sure of a direct relation
Hi All,
after upgrading from OH1.7 to OH2.2 I am also affected by the issue of THREAD::SLEEP() stopping the whole rule engine. I’ve got two rules which slowly ramp up two lights in the sleeping room in the morning. Both rules are running for 20 minutes and are triggered with a 10 minute delay between each other. So the first rule now blocks the second rule and there is no overlap.Instead of total runtime of 30 minutes for both rules it now takes 40 minutes to execute and during that time all other rules are blocked as well.
Strangely two other rules which change the colortemperature of my lighting which are also using THREAD::SLEEP() don’t seem to block the whole engine. Main difference is that these rules are triggered via cron while the ramp-up rules are triggered by a switch item.
I don’t consider using timers instead of THREAD::SLEEP() as a solution because each rule is running for considerable time and takes 100 steps, so each rule would (re)create 100 timers during execution.
