Then you need to type in the labels to be the same as the values you push to OH when the button is pressed. This has various uses. for termostat i want to display “25 °C” on the button but you push a command to the setpoint that is is “25” only without °C
Some other use is for the ventilation when I dispay “MAX” but I push to the recuperator “7” as it has 7 preset gears that you select.
