The widget is super loosely based opon Claudius Ellsel’s Custom Widget: Amazon Echo Music Control (if there even is anything left from the original at this point )
Documentation on the binding can be found over here:
Temporary home for the newest version
Changelog
V1_2
Changed tag descriptions to fit with the milisecond tags in the binding
V1_1
Added a placeholder image when there is no album art
Fixed some html tags for the tables in the document
Looks beautiful! There are actual channels to get time in milliseconds (will that work? it’s the timeformat Spotify reports so it’s a one-on-one copy of that data): trackDurationMs and trackProgressMs but these don’t seem to be documented (yet).. I’ll add it. The latest binary jar version (and any continued development work of this binding until the pr is merged can be found here: Release Spotify Binding (09/12/2019) · Hilbrand/openhab-addons · GitHub P.s the readme_url in your widget still points to the amazon topic
They are implemented and progress updates every second. Not specifically needed to add a pointer I think, if people find this thread they’ll find the binding. It’s temporary till the binding is merged.
I added it anyway
If you tell me when they are merged again, I’l update it
Ahh, correct, the MM:SS are the one I’m currently using.
Do you know if there is a possibility to get it formatted as a SSS too/instead?
I don’t know if there is a simple way to get it as SSS. Maybe something can be done with label formatting or something. The current formatting MM:SS is hard-coded in the binding and another representation directly from the binding would require changing code in the binding. But I’m not sure if these milliseconds give much more information. The minimal update frequency is 1 second anyway. What is the reason you want to show milliseconds?
You don’t need the rules, you can use the milliseconds channels directly. Also because the progress value is not shown it’s only used to display a relative width to a max value that are both in the same unit it will work even if the values are in milliseconds.
2 other things:
You template isn’t completely correct. Some ending tags are missing or incorrect. You can easily see this in habpanel when you edit the panel: In habpanel open a panel → click edit right next to the panel name(will show on hover) → Rights side click add Widgets listobox → click small config button right next to custom widgets → This should shown installed widget and show your widget with by Linda Knudsen → Click on it and it will open edit of widget in Code it will show invalid tags in red (Just added this description because didn’t know if you knew and I did find it hard to find). (I think these invalid html tags caused the widget to not show the progress bar. I did some dirty fixing and that made it work).
In Habpanel If you add a widget and open custom widgets it will list the widgets from the community forum (with links to this forum). You widget is also on it. However it’s not possible to import it. Other widgets show an import button, but yours shows a repository button. This may be caused because in your first post there are also links to repositories. I don’t know what the right way to fix this is, maybe remove urls to repositories in your first post? But if you can fix this people can install it directly from within habpanel.
I cant seem to find the milisecond channels in the spotify binding, only minutes:seconds, where do I find it?
Those would be perfect for the bar!
Did you enable the progress bar in the settings and provided it with its own tags?
I found a fault in the table for the buttons and the progress bar, so it should be fixed now, but the divs still seem to show fault even though they as far as I can tell should be html valid (I’ll gladly stand corrected though )
I also fixed the import feature. Thanks for the headsup!
Thanks for your work on this. i think i may be missing something. The artwork is not pulling through on my setup and there is no option in the spotify bridge to link artwork. Can you point me in the right direction? Had a quick look at the HTML, “unsafe:spotify:album” shows up in the album cover area.
Any help would be appreciated.
Thanks, Mark
I see the progress bar is now working ok! The divs complain due to the <img> tag. While it’s perfectly ok to have only the <img> tag it doesn’t understand it and expects the closing tag. I think this is a bug of the parser in habpanel (You can check by adding a closing tag </img> after the images, then the errors will disappear, but that would be incorrect html, so it should not be left in).
You could inline the missing artwork image and making it independent of the external url: src="data:image/png;base64,..." There are online tools to convert images to this format.
Thanks for your reply. I was using that binding but for some reason it wasn’t showing. I deleted and reinstalled and managed to get it working. Thanks again for your help.
Anyone build off this widget? It’s great but would love to build a more advanced one that has the ability to select devices as well as search for music and select playlists, etc.
