Very nice widget. I am searching the way to remove the whtie lines between the items. I have no idea which item color to adjust to get this fixed. I changed al the white reference to magneta in the styling to no avail. Is there a way to remove them all together?
nvm. It was defined in the default stylesheet. I copied some code to a new custom style sheet and the borders are gone.
First of all, thank you very much for a great widget @martmiwp. I found it very useful in my OpenHAB installation to control numerous items in a small space.
I also needed some tweaks so that the widget is more usable. I’ve released the tweaks in a GitHub project that willl get versions of other widgets I’ve modified.
is there a way to custom change the sort order?I changed the order that i want in my items files but its not changing anything,i also restarted my system but its the same.I tried the
<tr ng-repeat="item in itemsInGroup(config.item_groupid) | orderBy:'name'">
