Custom Widget: Switch-Dim-Color
yeap that did the job,thank you
I imported this widget. Wanting to use it to control my wiz WiFi bulbs and smart plug. Made a new item and found it on the network and it says online . Linked the Chanel’s but I’m not getting a response from the light. Wiz app controls it but openHAB doesn’t. Although it shows on and off state
Do you have a suggestion of a good way to learn the CSS that is applicable to its use within habpanel? I’ve got pluralsight subscription access but there are of course a multitude of courses available - I could spend days on all of them :slight_smile:
See here.
the good news is, CSS is used the same way for all websites and it is not unique for just habpanel. You learn it and it will help you if you ever want to do web design.
Actually I more meant the CSS specifics relating to habpanel. Luckily I was searching around and found this link which was very helpful
