I’m trying to switch my OH instance from my Pi 3B+ to a Pi 4B.
Because of some trouble with a device I’m running OH 4.0.0M3 on the RP3B+.
I read the best way would be a clean install and importing the configuration.
So I did the following:
Clone of sd card just to be sure I won’t break anything
Backup of razberry controller with Z-Way (installed on a separate sd card)
Backup of openhab config with openhabian-config
Used baleneEtcher to create a sd card with the latest openhabian image
Installation of OH4.0.0M4
Restoring backup of razberry controller
Restoring backup of openhab config.
First I would like to mention, that I was not prompted to add a user after installing OH, but that was the case when I installed the fresh instance on the Pi3B+. Is that the new behavior or did something go wrong?
After restoring the razberry backup dashboard was still accessible.
After restoring the openhab config backup dashboard is not accessible anymore.
If you restored your config, the user information is a part of that restored config. If it asked you to create a user it’s be an indication that the restore did not work.
Not without a good deal more details and some logs from openHAB (openhab.log). Particularly the logs around the time of the restoring the backup.
In general, restoring the backup from an older version of OH over a newer version of OH is problematic. So either restore your RPi 3 backup, upgrade to 4.0 M4 there and then create your backup from that to restore, or install OH 4.0 M3 on the RPi 4 first, restore the backup, and then upgrade to 4.0 M4.
I apologize for my misleading wording. After installing OH3 on RP3B+ I was asked to add/create a user but not when I installed OH4 today. Should I create the same user on OH4 which I created on OH3 back then?
I’ll give this a try and report back later, if necessary then also with log outputs
@rlkoshak Thank you very much! Updating to 4.0 M4 did the trick.
I finally understand what you mean. The openhab user will be restored but when I initially installed OH3 I was prompted to add a system user for openhabian witch was not restored of course.
Is there any specific reason why it is not necessary anymore to create a system user after installation?
The image I downloaded was openhabian-pi-raspios64-202306251519-gitb1e94d8-crc92121974.img.xz.
I flashed it on the sd-card and booted the RP4 with it. After some time and reboots it stopped at openhabian login:
That is not unattended, right?
Best regards
