My OpenHAB installation is running more or less. But it appears some other services are not. I had noticed that logs were not being rotated. I have tried rebooting the Pi, but that didn’t make any difference.
I would appreciate some direction on how to troubleshoot this. All that I know about Linux comes from playing around with OpenHAB, so I have limited knowledge.
Platform information:
Hardware:Pi 4B 4 GB
OS: _openhabian
Release = Raspbian GNU/Linux 10 (buster)
Kernel = Linux 5.10.103-v7l+
Platform = Raspberry Pi 4 Model B Rev 1.2
Java Runtime Environment: which java platform is used and what version
openHAB version: 3.4.0 SNAPSHOT 3033
Issue of the topic: I noticed that systemctl status showed that openhab was degraded. Systemctl -a —failed shows the following:
openhabian@openhab:~ $ systemctl -a --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
● certbot.service loaded failed failed Certbot
● hciuart.service loaded failed failed Configure Bluetooth Modems connected by UART
● logrotate.service loaded failed failed Rotate log files
● nginx.service loaded failed failed A high performance web server and a reverse proxy server
● systemd-timesyncd.service loaded failed failed Network Time Synchronization
Searching the Internet, I wonder if I’m seeing SD card wear, but I’m not sure. The next step I’m thinking of trying is to back up OpenHAB and start with a fresh openHABian load on a new SD card, to which I would restore the back up. (I have mirroring running, but that is to a bigger card.
That could be long output. It should give more information about why the different services failed to load. Could be permission problems of directories; could be missing directories or other root causes but more info about the reason should be there.
I tried restarting one of the services that was failing, logrotate. Here is what I found:
openhabian@openhab:~ $ systemctl restart logrotate
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to restart 'logrotate.service'.
Authenticating as: ,,, (openhabian)
Password:
==== AUTHENTICATION COMPLETE ===
Job for logrotate.service failed because the control process exited with error code.
See "systemctl status logrotate.service" and "journalctl -xe" for details.
openhabian@openhab:~ $ journalctl | grep logrotate
Aug 08 14:09:26 openhab polkitd(authority=local)[7568]: Operator of unix-process:4998:15715719 FAILED to authenticate to gain authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.282 [systemctl restart logrotate] (owned by unix-user:openhabian)
Aug 08 14:13:46 openhab polkitd(authority=local)[7568]: Operator of unix-process:5269:15741918 successfully authenticated as unix-user:openhabian to gain ONE-SHOT authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.285 [systemctl restart logrotate] (owned by unix-user:openhabian)
Aug 08 14:13:46 openhab logrotate[5285]: error: skipping "/var/log/exim4/mainlog" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
Aug 08 14:13:46 openhab logrotate[5285]: error: skipping "/var/log/exim4/rejectlog" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
Aug 08 14:13:46 openhab logrotate[5285]: error: skipping "/var/log/exim4/paniclog" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
Aug 08 14:13:46 openhab systemd[1]: logrotate.service: Main process exited, code=exited, status=1/FAILURE
Aug 08 14:13:46 openhab systemd[1]: logrotate.service: Failed with result 'exit-code'.
Seems like you are right about permissions being an issue. But I’m not sure what to do about it
Thanks for the help. I appreciate the specific instructions.
Adding sudo didn’t help:
openhabian@openhab:~ $ systemctl status logrotate
● logrotate.service - Rotate log files
Loaded: loaded (/lib/systemd/system/logrotate.service; static; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2022-08-08 18:11:58 CDT; 15s ago
Docs: man:logrotate(8)
man:logrotate.conf(5)
Process: 21672 ExecStart=/usr/sbin/logrotate /etc/logrotate.conf (code=exited, status=1/FAILURE)
Main PID: 21672 (code=exited, status=1/FAILURE)
Aug 08 18:11:58 openhab systemd[1]: Starting Rotate log files...
Aug 08 18:11:58 openhab logrotate[21672]: error: skipping "/var/log/exim4/mainlog" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to teAug 08 18:11:58 openhab logrotate[21672]: error: skipping "/var/log/exim4/rejectlog" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to
Aug 08 18:11:58 openhab logrotate[21672]: error: skipping "/var/log/exim4/paniclog" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tAug 08 18:11:58 openhab systemd[1]: logrotate.service: Main process exited, code=exited, status=1/FAILURE
Aug 08 18:11:58 openhab systemd[1]: logrotate.service: Failed with result 'exit-code'.
Aug 08 18:11:58 openhab systemd[1]: Failed to start Rotate log files.
This is the result of the ls command:
openhabian@openhab:~ $ ls -ld /var/log/exim4
drwxrws--- 1 Debian-exim adm 4096 Jan 4 2022 /var/log/exim4
I’m not sure how to tell which user/group the directory belongs to, but since I don’t see openhabian in the output, I think I don’t have that issue.
When I tried restarting systemd-timesyncd.service, the error was that the file had changed. I did the systemclt daemon-reload command, and then it successfully loaded.
openhabian@openhab:~ $ systemctl restart systemd-timesyncd.service
Authentication is required to restart 'systemd-timesyncd.service'.
Password:
Warning: The unit file, source configuration file or drop-ins of systemd-timesyncd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
openhabian@openhab:~ $ systemctl daemon-reload
==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
Authentication is required to reload the systemd state.
Password:
Password:
openhabian@openhab:~ $ systemctl status systemd-timesyncd.service
● systemd-timesyncd.service - Network Time Synchronization
Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled; vendor preset: enabled)
Drop-In: /lib/systemd/system/systemd-timesyncd.service.d
└─disable-with-time-daemon.conf
Active: active (running) since Mon 2022-08-08 19:46:24 CDT; 23s ago
Docs: man:systemd-timesyncd.service(8)
Main PID: 28211 (systemd-timesyn)
Status: "Synchronized to time server for the first time 192.241.146.233:123 (0.debian.pool.ntp.org)."
Tasks: 2 (limit: 4915)
CGroup: /system.slice/systemd-timesyncd.service
└─28211 /lib/systemd/systemd-timesyncd
Aug 08 19:46:24 openhab systemd[1]: Starting Network Time Synchronization...
Aug 08 19:46:24 openhab systemd[1]: Started Network Time Synchronization.
Aug 08 19:46:24 openhab systemd-timesyncd[28211]: Synchronized to time server for the first time 192.241.146.233:123 (0.debian.pool.ntp.org).
openhabian@openhab:~ $ sudo systemctl restart nginx.service
Job for nginx.service failed because the control process exited with error code.
See "systemctl status nginx.service" and "journalctl -xe" for details.
openhabian@openhab:~ $ systemctl status nginx
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2022-08-08 19:51:59 CDT; 14s ago
Docs: man:nginx(8)
Process: 28569 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE)
Aug 08 19:51:59 openhab systemd[1]: Starting A high performance web server and a reverse proxy server...
Aug 08 19:51:59 openhab nginx[28569]: nginx: [alert] could not open error log file: open() "/var/log/nginx/error.log" failed (2: No such file or directory)
Aug 08 19:51:59 openhab nginx[28569]: 2022/08/08 19:51:59 [emerg] 28569#28569: open() "/var/log/nginx/access.log" failed (2: No such file or directory)
Aug 08 19:51:59 openhab nginx[28569]: nginx: configuration file /etc/nginx/nginx.conf test failed
Aug 08 19:51:59 openhab systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE
Aug 08 19:51:59 openhab systemd[1]: nginx.service: Failed with result 'exit-code'.
Aug 08 19:51:59 openhab systemd[1]: Failed to start A high performance web server and a reverse proxy server.
A while ago I tried using the reverse proxy for remote access. I ended up going another route, so I’m not aware of anything I need it for at this time, but I’m not sure
Re-installing nginx should fix it.
In case the directory is missing after a reboot again then I would temporarily stop ZRAM and then re-install nginx after that ZRAM needs to be enabled again.
Now that I have Tailscale working well, I don’t use the Nginx to reverse proxy any more, so I plan to remove it following this procedure at Openhabian: How to remove Nginx?
I would think I should also remove the Certbot service because I think it was installed with nginx, but I’m out sure.
Yes, certbot is part of the nginx_setup() routine in openhabian-config.
As the standard setup ( there are other methods as well ) of certbot uses a reverse proxy to setup/renew certificates it will fail once the reverse proxy is removed.
