Here is my code.
import java.util.concurrent.ConcurrentLinkedQueue
val ConcurrentLinkedQueue<String> commands = new ConcurrentLinkedQueue()
var String commandToQuery
var Timer timer = null
var lastCommand = now.minusSeconds(1).millis
rule "Arduino 433Mhz Send Command. Query."
Member of gSocket3All received command
commandToQuery = triggeringItem.name + "-" + receivedCommand.toString
commands.add(commandToQuery)
logInfo("arduino", "Add to queue: " + commandToQuery + "// Timer State: " + timer)
if (timer === null) {
logInfo("arduino", "No timer. Creating.")
timer = createTimer(now, [|
if(commands.peek !== null) {
val cmd = commands.poll
logInfo("arduino", "Sending command to Arduino 433Mhz: " + cmd + " and transformed: " + transform("MAP", "arduino2.map", cmd))
Arduino.sendCommand(transform("MAP", "arduino2.map", cmd))
lastCommand = now.millis
val deltaTime = now.millis - lastCommand
timer.reschedule(now.plusMillis(if(deltaTime<100) 100-deltaTime else 0)) // 0 will reschedule the timer to run immediately
And after the first use it crashes with
2019-12-15 19:38:14.858 [INFO ] [lipse.smarthome.model.script.arduino] - Add to queue: Socket3N2-ON// Timer State: null
2019-12-15 19:38:14.861 [INFO ] [lipse.smarthome.model.script.arduino] - No timer. Creating.
2019-12-15 19:38:14.871 [INFO ] [lipse.smarthome.model.script.arduino] - Sending command to Arduino 433Mhz: Socket3N2-ON and transformed: 10;NewKaku;02a0ec00;3;ON;
2019-12-15 19:38:14.877 [ome.event.ItemCommandEvent] - Item 'Arduino' received command 10;NewKaku;02a0ec00;3;ON;
2019-12-15 19:38:14.882 [vent.ItemStateChangedEvent] - Arduino changed from 20;82;GlobalTronics;ID=0010;TEMP=0000;HUM=91;BAT=OK;
to 10;NewKaku;02a0ec00;3;ON;
2019-12-15 19:38:14.891 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Arduino 433Mhz Receiver': 6
2019-12-15 19:38:14.895 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 1197 2019-12-15T19:38:14.864+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@f84189
val deltaTime
<XFeatureCallImplCustom>.reschedule(<XMemberFeatureCallImplCustom>)
} ] threw an unhandled Exception:
java.lang.IllegalStateException: Could not invoke method: org.joda.time.DateTime.plusMillis(int) on instance: 2019-12-15T19:38:14.877+01:00
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1103) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1061) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1047) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:772) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1116) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy519.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:48) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [182:org.openhab.core.scheduler:2.5.0.M4]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [182:org.openhab.core.scheduler:2.5.0.M4]
Caused by: java.lang.IllegalArgumentException
at sun.reflect.GeneratedMethodAccessor197.invoke(Unknown Source) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1086) ~[?:?]
... 27 more
2019-12-15 19:38:15.018 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.Timer 1197 2019-12-15T19:38:14.864+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
val deltaTime
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [182:org.openhab.core.scheduler:2.5.0.M4]
Caused by: java.lang.IllegalStateException: Could not invoke method: org.joda.time.DateTime.plusMillis(int) on instance: 2019-12-15T19:38:14.877+01:00
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
... 1 more
And timer do not run in loop after this.
