When a timer is timing, no thread is used.
When a timer has expired and is executing it’s little code block, it uses a thread until it has exited that code.
rossko57 is correct. That is why I use Timers in that example. Timers use no resources beyond a tiny bit of ram while they are awaiting their time to execute.
Before the code block within timer = createTimer(now, [ | ... ]) can be exit, the timer is rescheduled. That’s why I’m wondering if the thread is running forever. Or almost forever.
That’s fine. Awaiting a scheduled time uses no thread.
When the timer’s little code block has completed the reschedule task, it exits. So releasing the execution thread.
Okay thank you very much. That’s reassuring.
The Gatekeeper (python) version is not (yet) in the community openhab helper libraries. Would be nice to have it there.
Regards S
That’s the plan. I’ve still some unit tests to write and documentation to flesh out before I submit the PR. I’ll update the OP when it’s merged. Most of the DPs I hope to similarly submit most of the DPs and tutorials.
I used this pattern to help out with turning on/off wifi for my kids.. I’m using the Unifi binding and I put all my kids devices into a separate group (gDevicesToBlock). The problem was that when I did a set on the group, all commands where sent to the binding without any delays and it didn’t catch all devices. Same problem that’s described in the design pattern above for 433 Mhz devices.
Anyway, I updated the pattern and I just want to share it, as it took some time to get right.
Items:
Switch UnifiBlockController "Block wireless" <switch>
Group gDevicesToBlock "Devices to block"
Switch NilsPhoneBlock "Nils phone block" <switch> (gDevicesToBlock)
{channel="unifi:wirelessClient:home:nilsPhone:blocked"}
Switch IvarsPhoneBlock "Ivar phone block" <switch> (gDevicesToBlock)
{channel="unifi:wirelessClient:home:ivarsPhone:blocked"}
Rule:
import java.util.concurrent.ConcurrentLinkedQueue
val deviceQueue = new ConcurrentLinkedQueue()
var Timer timer = null
val delay = 1000 // Delay in milliseconds between commands
rule "Block unblock Unifi"
Item UnifiBlockController received update
gDevicesToBlock.members.forEach[ device |
deviceQueue.add(device)
if (timer === null) {
timer = createTimer(now.plusMillis(delay), [ |
if (deviceQueue.peek !== null) {
val device = deviceQueue.poll as SwitchItem
device.sendCommand(UnifiBlockController.state)
timer.reschedule(now.plusMillis(delay))
} else {
timer = null
The problem that you will still pass (((
This pattern is not usable for group switches, that are most used.
If you try to turn on or off the group from example on the top. This one
Group WirelessDevices
It will fail because of basic fault of setting timers at one time.
It means that the group switch just forces all the switches in group to to turn on or off AT ONE TIME (millis are difference)!
Because of it the rull will try to create multiply timers (it will just have not time to process all of them at once and to check if timer exists) and will fail (((
It can works somethimes with 2 switches in group, but if you have more it will cause the fault.
Can this behavior be in someway changed?
Show your code.
You can’t send a command to a Group with this DP. You must send the command to each member of the Group individually. From what you describe I can’t tell if that is what you are trying to do.
In the DP above, there is only one timer. If you are calling Gatekeeper for each member individually, you may need you add a short Thread::sleep, 10 msec should be enough, between each call to Gatekeeper.
I’m assuming the Rules DSL version of the code. The Python version blocks on the call to addCommand so there is no chance of processing a new consensus before the looking timer is created.
Here is my code.
val ConcurrentLinkedQueue<String> commands = new ConcurrentLinkedQueue()
var String commandToQuery
var lastCommand = now.minusSeconds(1).millis
rule "Arduino 433Mhz Send Command. Query."
Member of gSocket3All received command
commandToQuery = triggeringItem.name + "-" + receivedCommand.toString
commands.add(commandToQuery)
logInfo("arduino", "Add to queue: " + commandToQuery + "// Timer State: " + timer)
logInfo("arduino", "No timer. Creating.")
timer = createTimer(now, [|
if(commands.peek !== null) {
val cmd = commands.poll
logInfo("arduino", "Sending command to Arduino 433Mhz: " + cmd + " and transformed: " + transform("MAP", "arduino2.map", cmd))
Arduino.sendCommand(transform("MAP", "arduino2.map", cmd))
lastCommand = now.millis
val deltaTime = now.millis - lastCommand
timer.reschedule(now.plusMillis(if(deltaTime<100) 100-deltaTime else 0)) // 0 will reschedule the timer to run immediately
And after the first use it crashes with
2019-12-15 19:38:14.858 [INFO ] [lipse.smarthome.model.script.arduino] - Add to queue: Socket3N2-ON// Timer State: null
2019-12-15 19:38:14.861 [INFO ] [lipse.smarthome.model.script.arduino] - No timer. Creating.
2019-12-15 19:38:14.871 [INFO ] [lipse.smarthome.model.script.arduino] - Sending command to Arduino 433Mhz: Socket3N2-ON and transformed: 10;NewKaku;02a0ec00;3;ON;
2019-12-15 19:38:14.877 [ome.event.ItemCommandEvent] - Item 'Arduino' received command 10;NewKaku;02a0ec00;3;ON;
2019-12-15 19:38:14.882 [vent.ItemStateChangedEvent] - Arduino changed from 20;82;GlobalTronics;ID=0010;TEMP=0000;HUM=91;BAT=OK;
to 10;NewKaku;02a0ec00;3;ON;
2019-12-15 19:38:14.891 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Arduino 433Mhz Receiver': 6
2019-12-15 19:38:14.895 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 1197 2019-12-15T19:38:14.864+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@f84189
val deltaTime
<XFeatureCallImplCustom>.reschedule(<XMemberFeatureCallImplCustom>)
} ] threw an unhandled Exception:
java.lang.IllegalStateException: Could not invoke method: org.joda.time.DateTime.plusMillis(int) on instance: 2019-12-15T19:38:14.877+01:00
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1103) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1061) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1047) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:772) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1116) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy519.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:48) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [182:org.openhab.core.scheduler:2.5.0.M4]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [182:org.openhab.core.scheduler:2.5.0.M4]
Caused by: java.lang.IllegalArgumentException
at sun.reflect.GeneratedMethodAccessor197.invoke(Unknown Source) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1086) ~[?:?]
... 27 more
2019-12-15 19:38:15.018 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.Timer 1197 2019-12-15T19:38:14.864+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
val deltaTime
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [182:org.openhab.core.scheduler:2.5.0.M4]
Caused by: java.lang.IllegalStateException: Could not invoke method: org.joda.time.DateTime.plusMillis(int) on instance: 2019-12-15T19:38:14.877+01:00
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
... 1 more
And timer do not run in loop after this.
Where do i add this delay Rich?
If i set it direct after
then the commands added witout any delay.
You have to add it to the forEach that is sending the command to the members of gSocket3All.
As I indicated in my previous reply, you cannot use a Group to trigger the Gatekeeper Rule. Not even if you use Member of, unless you are sending the command to each member individually (i.e. you cannot sendCommand to the Group Item).
To make this work properly, you need to create a proxy for the Arduino Item. This proxy Item is what triggers the Gatekeeper Rule. Then you need a proxy for gSocket3All which triggers a different rule. In that other rule, forEach over gSocket3All’s members sending the proper command to the Arduino proxy Item then add the small thread sleep too give the Gatekeeper Rule time to create the Timer before the rule triggered again.
Note, I don’t believe this is a problem at all when using the Python version.
Undersood! I will try, thanks, Rich!
But the problem above https://community.openhab.org/t/design-pattern-gate-keeper/36483/31?u=thisisio in not in all this . The rule crashes at once even if i triger only one switch.
It is somthing with deltaTime. Please, look in log.
Add logging before and after the deltaTime line to confirm what line the error is occurring on.
The error is most likely coming from the reschedule. Change to (100-deltaTime).intValue
I tried to replicate your rule to send 433MHz switches from broadlink. It doesn’t work with log below.
2020-02-03 01:21:58.360 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 23 2020-02-03T01:21:58.352+07:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@9ef60c (conditionalExpression: false)
java.lang.IllegalStateException: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(org.eclipse.smarthome.core.items.Item,java.lang.String) on instance: null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1192) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1150) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1136) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1081) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:861) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:231) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:215) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:239) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:471) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:255) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:201) ~[?:?]
at com.sun.proxy.$Proxy337.apply(Unknown Source) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [bundleFile:?]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
Caused by: java.lang.IllegalArgumentException: java.lang.ClassCastException@d4aaa
at sun.reflect.GeneratedMethodAccessor314.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1175) ~[?:?]
... 27 more
2020-02-03 01:21:58.406 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.Timer 23 2020-02-03T01:21:58.352+07:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [bundleFile:?]
Caused by: java.lang.IllegalStateException: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(org.eclipse.smarthome.core.items.Item,java.lang.String) on instance: null
... 1 more
... 1 more
Here is my rule:
val delay = 500 // Delay in milliseconds between commands
rule "OutdoorLight Sequence"
Item OutdoorLight received update
Group_OutdoorLights.members.forEach[item | deviceQueue.add(item)]
device.sendCommand(OutdoorLight.state)
} else {
timer = null
Can you give any pointer?
Add some logging to see what device and OutdoorLight.state is. This looks like attending to send a command to an item that doesn’t support that type as a command.
here is the most recent log:
2020-02-03 19:39:06.304 [WARN ] [.smarthome.model.script.OutdoorLight] - OutdoorLight state isON
2020-02-03 19:39:06.308 [WARN ] [.smarthome.model.script.OutdoorLight] - BackyardLight state isON
2020-02-03 19:39:06.312 [WARN ] [.smarthome.model.script.OutdoorLight] - Canopy state isON
2020-02-03 19:39:06.316 [WARN ] [.smarthome.model.script.OutdoorLight] - Terrace state isON
2020-02-03 19:39:06.496 [INFO ] [org.quartz.core.QuartzScheduler ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
2020-02-03 19:39:06.821 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 14 2020-02-03T19:39:06.818+07:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@10dba76 (conditionalExpression: false)
at com.sun.proxy.$Proxy315.apply(Unknown Source) ~[?:?]
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_222]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_222]
... 27 more
2020-02-03 19:39:06.846 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.Timer 14 2020-02-03T19:39:06.818+07:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
... 1 more
... 1 more
2020-02-03 19:39:07.439 [event.ThingStatusInfoEvent] - 'miio:generic:04531E42' updated: ONLINE
2020-02-03 19:39:13.202 [event.ThingStatusInfoEvent] - 'mihome:bridge:7811dc64e075' updated: ONLINE
2020-02-03 19:39:15.031 [event.ThingStatusInfoEvent] - 'mihome:bridge:7811dc64e075' updated: ONLINE
2020-02-03 19:39:15.037 [me.event.InboxUpdatedEvent] - Discovery Result with UID 'mihome:sensor_plug:158d000282b27c' has been updated.
2020-02-03 19:39:17.669 [me.event.InboxUpdatedEvent] - Discovery Result with UID 'miio:generic:065016B4' has been updated.
2020-02-03 19:39:17.800 [me.event.InboxUpdatedEvent] - Discovery Result with UID 'miio:generic:036E06C8' has been updated.
2020-02-03 19:39:23.183 [event.ThingStatusInfoEvent] - 'mihome:bridge:7811dc64e075' updated: ONLINE
2020-02-03 19:39:33.163 [event.ThingStatusInfoEvent] - 'mihome:bridge:7811dc64e075' updated: ONLINE
2020-02-03 19:39:37.844 [event.ThingStatusInfoEvent] - 'miio:generic:04531E42' updated: ONLINE
2020-02-03 19:39:43.143 [event.ThingStatusInfoEvent] - 'mihome:bridge:7811dc64e075' updated: ONLINE
... 1 more
... 1 more
Here is items configuration:
Switch Light_FF_Canopy "Canopy" <light> (Group_BroadlinkLivingItems, Group_LightsF1, Group_OutdoorLights) ["Lighting"]
Switch Light_FF_Terrace "Terrace" <light> (Group_BroadlinkLivingItems, Group_LightsF1, Group_OutdoorLights) ["Lighting"]
Switch Light_SF_Backyard "Backyard light" <light> (Group_XMSwitch, Group_LightsF2, Group_OutdoorLights) ["Lighting"] { channel="mihome:ctrl_neutral1:158d000305a01b:ch1" }
Switch OutdoorLight "Outdoor Lights Switch" <outdoorlight> (Group_Lights, Group_RulesItems)
I still unable to understand why command is not sent.
Without knowing where the log statments are placed it’s hard to interpret their meaning.
All I can recommend it try passing the OutdoorLight.state with toString.
this solves my problem! So it seems that item.state is not usable to send command, I have to use item.state.toString to send even ON OFF command.
