Design Pattern(?): Multi-Sensor Confidence Aggregation
Design Pattern: Multi-Sensor Confidence Aggregation
Problem: You want to derive a reliable result from multiple sensors, e.g., presence detection, window status, light sensors. Individual sensors can be wrong.
Solution:
  • Calculate a confidence value for each sensor item.
  • Use a rule that makes an aggregated decision based on all sensors (e.g., weighted average or Bayesian).
  • Trigger actions only when a certain threshold is exceeded.
Advantages:
  • Higher reliability.
  • Flexible for any combination of sensors.
1. Concept
Assume we have the following sensors:
Sensor Item Name Weight (Confidence)
Motion Sensor MotionSensor 0.7
Window Contact WindowSensor 0.5
Light Sensor LightSensor 0.3
Goal: If the aggregated confidence > 0.6, then “Presence detected” is considered true.
Note: The illustration contains errors.
2. Implementation in Rule DSL
// Items
// Switch MotionSensor "Motion Sensor" <motion>
// Switch WindowSensor "Window Open" <contact>
// Number LightSensor "Light" <light>
// Rule in Rule DSL
rule "Multi-Sensor Confidence Aggregation"
    Item MotionSensor changed or
    Item WindowSensor changed or
    Item LightSensor changed
    // Individual sensor confidences
    var Number motionConfidence = if(MotionSensor.state == ON) 0.7 else 0.0
    var Number windowConfidence = if(WindowSensor.state == CLOSED) 0.5 else 0.0
    var Number lightConfidence  = if((LightSensor.state as Number) > 100) 0.3 else 0.0
    // Aggregation (Weighted Sum)
    var Number aggregatedConfidence = motionConfidence + windowConfidence + lightConfidence
    logInfo("MultiSensor", "Aggregated Confidence: " + aggregatedConfidence)
    // Action only if threshold > 0.6
    if(aggregatedConfidence > 0.6) {
        logInfo("MultiSensor", "Presence detected!")
        // e.g., turn on light:
        // LightSwitch.sendCommand(ON)
    } else {
        logInfo("MultiSensor", "No presence detected.")
Explanation:
  • if(... == ON) checks the sensor state.
  • aggregatedConfidence can be more complex (e.g., weighted average, Bayesian).
  • Actions occur only if a threshold is exceeded.
3. Implementation in Python (Jython Scripting)
from core.rules import rule
from core.triggers import when
from core.log import logging
log = logging.getLogger("MultiSensor")
@rule("Multi-Sensor Confidence Aggregation Python")
@when("Item MotionSensor changed")
@when("Item WindowSensor changed")
@when("Item LightSensor changed")
def multi_sensor_confidence(event):
    # Individual sensor confidences
    motion_conf = 0.7 if str(items["MotionSensor"]) == "ON" else 0.0
    window_conf = 0.5 if str(items["WindowSensor"]) == "CLOSED" else 0.0
    light_conf  = 0.3 if float(items["LightSensor"]) > 100 else 0.0
    # Aggregation
    aggregated_conf = motion_conf + window_conf + light_conf
    log.info(f"Aggregated Confidence: {aggregated_conf}")
    if aggregated_conf > 0.6:
        log.info("Presence detected!")
        # e.g., turn on light
        # events.sendCommand("LightSwitch", "ON")
    else:
        log.info("No presence detected.")
Explanation:
  • items["MotionSensor"] returns the current state.
  • Conditional assignment for confidence.
  • Aggregation as the sum of confidences; threshold check.
  • Python allows more flexible calculations (e.g., Bayesian, complex formulas).
4. Extensions
  1. Dynamic weighting: Sensors can have different trust levels.
  2. Bayesian aggregation: P(Active | Sensor1, Sensor2) for probabilistic decisions.
  3. Historical data: Average over time to reduce false alarms.
  4. Flexible thresholds: Different thresholds for actions (e.g., lights, alarms, notifications).
Bayesian Multi-Sensor Confidence Aggregation Example for openHAB in Python (Jython)
1. Idea
We use Bayes’ Theorem:
bayes theorem
  • Each sensor provides a probability of correct detection (True Positive / False Positive).
  • Aggregation is performed independently over all sensors.
2. Example in Python (Jython)
log = logging.getLogger("MultiSensorBayes")
# Sensor metrics (probability of correctness)
SENSOR_CONFIDENCE = {
    "MotionSensor": {"tp": 0.9, "fp": 0.1},   # True Positive / False Positive
    "WindowSensor": {"tp": 0.8, "fp": 0.2},
    "LightSensor": {"tp": 0.7, "fp": 0.3}
# Prior probability of presence
PRIOR_PRESENCE = 0.5
@rule("Bayesian Multi-Sensor Aggregation")
def bayesian_aggregation(event):
    # Read sensor states
    states = {
        "MotionSensor": str(items["MotionSensor"]) == "ON",
        "WindowSensor": str(items["WindowSensor"]) == "CLOSED",
        "LightSensor": float(items["LightSensor"]) > 100
    # Initialize Bayes probability with prior
    prob_presence = PRIOR_PRESENCE
    prob_absence = 1 - PRIOR_PRESENCE
    for sensor, detected in states.items():
        tp = SENSOR_CONFIDENCE[sensor]["tp"]
        fp = SENSOR_CONFIDENCE[sensor]["fp"]
        if detected:
            prob_presence *= tp
            prob_absence *= fp
        else:
            prob_presence *= (1 - tp)
            prob_absence *= (1 - fp)
    # Normalize
    total = prob_presence + prob_absence
    prob_presence /= total
    log.info(f"Bayesian Presence Probability: {prob_presence:.2f}")
    # Threshold
    if prob_presence > 0.6:
    else:
3. Explanation
  1. SENSOR_CONFIDENCE: Contains how reliable each sensor is (True Positive / False Positive).
  2. State detection: True if the sensor indicates “presence”.
  3. Bayesian combination: Multiply probabilities for each sensor.
  4. Normalization: Ensures P(Presence) + P(Absence) = 1.
  5. Threshold: Action only if, e.g., probability > 0.6.
4. Advantages
  • Accounts for sensor uncertainty.
  • Scalable to any number of sensors.
  • Reduces false alarms.
  • Flexible adjustment via tp / fp values.
There is a Baysean implantation of this approach on the marketplace as a rule template. Bayesian Sensors - Activation Rule [4.0.0;5.0.0). There’s a MainUI widget to help adjust the weights and such without changing the rule. Bayesian Sensors - Details Widget [4.0.0;5.0.0). Full documentation can be found at Bayesian Sensors in OH4.
The original implementation in Jython can be found at Design Pattern: Bayesian Sensor Aggregation.
