No, file a GitHub issue in core and make it as specific as possible (one for each request). If someone else has to design the specifics it’s very unlikely it will ever be picked up, simple because a lack off time, unless a developer has the same request. So for your suggestions also propose how that would look like in actual configuration. This would greatly increase the change that it will be implemented or at least have a better discussion.
I have no indication anybody involved in core development is even considering to remove text file configuration.
End of support for 1.x bindings. Of this I was afraid when I read about 3.x
The reason why I started using Openhab was because of the Nikobus 1.x binding. If this doesn’t work anymore in 3.x then I will never use it and stay on 2.x. Pitty.
And as this binding is a very niche one, I am afraid nobody will migrate it to 2.x 3.x . Doubt I am knowledge enough to do it myself. Will take a look though.
Thx very much Guys Up till recently I was still running 2.1. No reason for me to update as it worked perfectly. After updating the repository I could update to 2.5. Now running the latest Nikobus binding.
If you were running a version that old, you should check to see how many of your other bindings now have a 2.x version. There has been a lot of development that has occurred in the past 2 1/2 years.
That will not happen as I need serial to run over 30 DIY devices running a custom protocol on serial. See the thread below. BTW I don’t believe other home automation packages have serial port support, Openhab is the only one as it has been around the longest.
Is the 2.5.1 stable version out for updating with openhabian.config right now?
If I do a “sudo apt-get upgrade -s” on a openhabian installation the 2.5.1 version isn’t found…
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen… Fertig
Paketaktualisierung (Upgrade) wird berechnet… Fertig
Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
triggerhappy
Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
Die folgenden Pakete sind zurückgehalten worden:
nodejs
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
Hi, tried to update to version 2.5.1 with openhabian-config tool.
Unfourtnately the version isn’t found by openhabian-config.
If I use function “03 | openHAB Stable Install or upgrade to the latest stable release of openHAB 2”
only Version 2.5.0 is found.
