Is there a device (with bluetooth or working with z-wave), which can indicate a status-change and send a command back to openHAB?
My problem:
My blinds are moving up and down automatically, but when i‘m in the garden, i don‘t want that my blinds go down. So the solution would be a small portable device (with batteries),
which receives a message maybe 2min before the blinds will move down. Then i can press the button to prevent the automatically move down of the blinds.
Maybe there‘s a device which is able to handle that and works with opeHAB?
MDAR
2
Haha yes that would work, but the problem is also my guests and friends should have the possibility to stop the automation. I don‘t wanna give my phone, so there should really exists one or multiple devices they can take out in the garden.
This is a pretty niche requirement. I suspect you will need to go down the DIY route to achieve it.
MDAR
5
Sounds like what you’re after is something like those funky pagers that restaurants give customers to let them know when the table is ready, but also with a single button to respond with ?
Or a short range pager with an acknowledgement button?
I read about micro:bit and it‘s really interesting. But is it possible to send a command from openHAB to the micro:bit? It‘s running Bluetooth Low Energy (BLE) and a have no experience with bluetooth. Don‘t know if a BLE-Device can receive commands!?
MDAR
9
Unfortunately, I don’t know anything more than what I’ve suggested so far.
