DEVIReg Smart thermostat binding
I have to announce another delay in development. My company gave me a business trip to Tel-Aviv, Israel, till 31st of January. I will be online of course but i won’t have too much time to do the OpenHAB development. I love travelling, i love new places, i’ve never been there yet, so i’ll hang out somewhere for the most of my time outside of work.
It’s really a great New Year present for me from my company.
So far i’ve got a prototype of CLI tool for config download.
Back from Israel and bought one more DeviReg Smart for my kitchen. Before installing i will try to play with it on the LAN when not configured. There is a small hope to enable local link, this would avoid all the problems with the cloud.
Unfortunately, local link mode is completely useless on these devices :frowning: It is possible to make a local connection only when the thermostat is in access point mode. It opens up for approximately 30 seconds after powerup; the thermostat represents itself as an open “Smart Thermostat” wifi network. Yes, anyone can connect. Yes, even if fully configured. After the timeout the thermostat switches to client mode and shuts off local port.
Consequences:
  1. It is possible to connect only within 30 seconds after powerup
  2. If connection is lost, reconnecting is possible only after powercycle.
  3. Your control host has to be a wifi client and thermostat is an access point
  4. Situation with multiple thermostats is unclear because you would end up in multiple wifi networks with the same SSID.
Conclusion:
Totally unusable, Devi forces you to use their cloud even you’re standing next to your door. :frowning:
To tell the truth, i decided to stick to Devi installation only because:
  1. The only potential alternative on the local market could be Electrolux ETS 16; but i don’t know if they impose the same restrictions or not
  2. I have already invested a lot of my time into reversing Devismart and got usable results
    Thanks Danfoss, we know you care! :imp:
Yes, DeviReg is cloud only, shame on Danfoss. To be fair, there are hundreds if not thousands of devices which do it the same way :frowning:
Promising work here @Sonic!!
Me on my hand is looking for the same result, only for HomeAssistant, but i believe an eventual solution would beneficial for both. I’m not an expert in either Python or Linux (yet), but I’m willing to both learn and help if that is an option. I have some experience from C++ programming and network management.
Well, you can have a look at the actual binding source code. It already successfully works at my home with two regulators. The only missing part is device discovery, without which it’s very problematic to configure your devices in OH.
And yes, since HA is written in Python, you’ll need to add a Python binding to OpenSDG library. You are welcome to do that.
Meanwhile i decided to write a pure Java implementation of OpenSDG. Managing dependencies between OSGI and C libraties turns out to be not very friendly. Fortunately there is a pure Java NaCl implementation to base on
A bit short of time, but working on discovery process. This will make the binding usable by non-experts.
The discovery now works! Needs supplemental CLI tool; i use curl for the time being
Coming close to public test release. So, guys, what OS / CPUs are you running OpenHAB on ? I am now working on packaging OpenSDG library and want to know what to consider first
debian (buster, amd64) :slight_smile:
So, it has finally happened and i am inviting everyone to test it.
Grab the release here: Release Initial release · Sonic-Amiga/org.openhab.binding.devireg · GitHub and put the archive into /usr/share/openhab2/addons
Before doing that on Linux system you need to install a C library. Go to Release 1.0.0: Add Debian packaging · Sonic-Amiga/opensdg · GitHub and download OpenSDG for your architecture. Only the main binary (opensdg_1.0.0-1) is enough.
Then see the README.md file on the main page (GitHub - Sonic-Amiga/org.openhab.binding.devireg: DeviReg binding for OpenHAB) and have fun. I’m waiting for feedbacks and comments.
Hmm.
the link http://YOUR_OPENHAB_HOST:8080/devireg/ does not work :confused: (404 not found)
I had to install libsodium23 first, then installed opensdg_1.0.0-1_amd64.deb vie dpkg sucessfully,
After that, moved the jar to addons.
davireg binding shows up in paper ui Configuration Bindings, I’m able to manually create a thing, but no sucess with the first step to get credentials.
openHAB2.5.0 release build here…
@Udo_Hartmann well, “this is why we test” :slight_smile:
Indeed it needs libsodium, but it should also ask for protobuf-c. Is it installed on your system?
I will recheck dependencies of the .deb by this time. And could you also send me openhab.log ?
BTW, how can you create a thing? The “PeerID” is both Mandatory and Read-only. On my test 2.5.1 environment you can never click “Add” because the field is empty; and you cannot type there because it’s read-only
And also please check the binding config. There should be valid keys (64 hex digits) and “OpenHAB” user name.
Well, it didn’t ask for probuf-c.
When using apt-search, I get this list:
golang-goprotobuf-dev - Protocol buffer support for the Go programming language
protobuf-compiler-grpc - high performance general RPC framework - protobuf plugin
libprotobuf-java - Java bindings for protocol buffers
protobuf-compiler - compiler for protocol buffer definition files
python-protobuf - Python bindings for protocol buffers
python3-protobuf - Python 3 bindings for protocol buffers
libprotobuf-c-dev - Protocol Buffers C static library and headers (protobuf-c)
libprotobuf-c1 - Protocol Buffers C shared library (protobuf-c)
protobuf-c-compiler - Protocol Buffers C compiler (protobuf-c)
which one is the correct one?
When I wrote “manually create thing”, this was a bit misleading :wink: In fact I got the mask to fill the data, I never tried to create it for real, as I did not get the credentials…
openhab.log (only the devireg part):
2020-03-02 15:34:20.340 [ERROR] [org.openhab.binding.devireg         ] - bundle org.openhab.binding.devireg:2.5.1.202003020702 (268)[org.openhab.binding.devireg.internal.DeviRegHandlerFactory(278)] : The activate method has thrown an exception
java.lang.UnsatisfiedLinkError: no opensdg_jni in java.library.path
        at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1860) ~[?:1.8.0_232]
        at java.lang.Runtime.loadLibrary0(Runtime.java:871) ~[?:1.8.0_232]
        at java.lang.System.loadLibrary(System.java:1122) ~[?:1.8.0_232]
        at org.opensdg.OpenSDG.<clinit>(OpenSDG.java:5) ~[?:?]
        at org.openhab.binding.devireg.internal.DeviRegBindingConfig.update(DeviRegBindingConfig.java:36) ~[?:?]
        at org.openhab.binding.devireg.internal.DeviRegBindingConfig.update(DeviRegBindingConfig.java:72) ~[?:?]
        at org.openhab.binding.devireg.internal.DeviRegHandlerFactory.activate(DeviRegHandlerFactory.java:74) ~[?:?]
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_232]
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_232]
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_232]
        at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_232]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[bundleFile:?]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[bundleFile:?]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[bundleFile:?]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [bundleFile:?]
        at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [bundleFile:?]
        at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) [bundleFile:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [org.eclipse.osgi-3.12.100.jar:?]
        at java.security.AccessController.doPrivileged(Native Method) [?:1.8.0_232]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [org.eclipse.osgi-3.12.100.jar:?]
        at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) [bundleFile:?]
        at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [bundleFile:?]
        at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [bundleFile:?]
        at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [bundleFile:?]
        at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [org.eclipse.osgi-3.12.100.jar:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [bundleFile:?]
        at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) [bundleFile:?]
        at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) [bundleFile:?]
        at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [bundleFile:?]
        at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) [bundleFile:?]
        at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
        at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
        at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [osgi.core-6.0.0.jar:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [osgi.core-6.0.0.jar:?]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-6.0.0.jar:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [osgi.core-6.0.0.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.container.Module.start(Module.java:467) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.12.100.jar:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [org.eclipse.osgi-3.12.100.jar:?]
2020-03-02 15:34:20.424 [ERROR] [org.openhab.binding.devireg         ] - bundle org.openhab.binding.devireg:2.5.1.202003020702 (268)[org.openhab.binding.devireg.internal.DeviRegHandlerFactory(278)] : The activate method has thrown an exception
java.lang.NoClassDefFoundError: Could not initialize class org.opensdg.OpenSDG
2020-03-02 15:34:20.454 [ERROR] [org.openhab.binding.devireg         ] - bundle org.openhab.binding.devireg:2.5.1.202003020702 (268)[org.openhab.binding.devireg.internal.DeviRegHandlerFactory(278)] : The activate method has thrown an exception
        at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [bundleFile:?]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [osgi.core-6.0.0.jar:?]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [osgi.core-6.0.0.jar:?]
        at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [osgi.core-6.0.0.jar:?]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [osgi.core-6.0.0.jar:?]
        at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [osgi.core-6.0.0.jar:?]
log is truncated :wink:
@Udo_Hartmann libprotobuf-c1 should be what you need. And yes, the log says that the binding crashes upon loading due to missing libraries. After installing it perhaps you’ll need to restart the OH, or it won’t understand that it needs to reload the binding.
Apparently not all dependencies are automatically discovered. I already have them installed on my systems because i develop, so it was easy for me to miss.
I’ve just checked on my Linux laptop; the dependency is not missing in the .deb file. And dpkg lists both of them when you try to install it.
However, i’ve noticed also that on failure the binary file is still there, it just says that it cannot configure the package. So perhaps you’ve manually satisfied the first dependency and forgot the second.
However armhf package is screwed indeed. I’ll fix it.
In fact, as I tried to install, apt says it’s already installed :slight_smile: so this is not the missing library.
Hm, okay… Today or tomorrow i’ll try to install OpenHab on my Linux laptop and try there. This is strange.
